Old 06-14-2013, 02:59 PM   #281
ft_sjo
Drives: GT86
That plug does not look like it's seen an excessively lean condition.
Old 06-14-2013, 03:15 PM   #282
romin
romin's Avatar
Drives: BRZ, STI, 535, Tiffin Allegro
It appears everyone is having seal, plug, and coil issues with cylinder one???
Has anyone had a fail on any of the other three cylinders?
My 2,3, and 4 seals looked great.
romin is offline   Reply With Quote
Old 06-14-2013, 03:27 PM   #283
xjohnx
Grip>Slip
xjohnx's Avatar
i'm getting some slight popping when rev matching on shifts.definitely sounds like it's coming from the exhaust though. Running nameless overpipe/downpipe/hfc and nameless axleback. Stock ECU now.
I'm assuming it is unrelated, but can anyone ease my nerves and confirm?
Old 06-14-2013, 03:31 PM   #284
Dezoris
Dezoris's Avatar
There is definitely something odd about this situation.
Broken plugs, burnt destroyed injectors, damaged engines and coil packs malfunctioning.
I can't believe tuning is the single culprit here.
Old 06-14-2013, 03:32 PM   #285
ft_sjo
Drives: GT86
Coil packs fail on all kinds of engines. It's the mistake that most manufacturers do where they bolt the coil pack to the engine itself rather than running it remote with plug leads/wires.
Det can break plugs. Det can damage injector seals. Det problem fixed by re-cal. End of discussion.
Old 06-14-2013, 03:35 PM   #286
xjohnx
Grip>Slip
xjohnx's Avatar
Except it's not available to any of us yet.
@Art_Mighty (06-29-2013)
Old 06-14-2013, 03:39 PM   #287
ft_sjo
Drives: GT86
I'm running it on my car, thanks.
Old 06-14-2013, 03:45 PM   #288
xjohnx
Grip>Slip
xjohnx's Avatar
Want a cookie? It's not available from Subaru (not sure about Scion) in the US. Contrary to your prior assertion, until a fix is made available to us by the manufacturer, it has not been fixed.
Old 06-14-2013, 04:09 PM   #289
OrbitalEllipses
Drives: Attitude
ft_sjo's just been trolling the DI leak threads for a few days now.../ignore.
Old 06-14-2013, 04:14 PM   #290
ft_sjo
Drives: GT86
You ladies can club together all you want. Have any of you actually asked Subaru to flash your car with A01 yet?
Old 06-14-2013, 04:47 PM   #291
romin
romin's Avatar
My Subaru service rep told me they couldn't flash my ECU.
He said they didn't have that capability - Which we all know is a complete lie.
The rep told me the only way to update my ECU was to purchase a new one for $1000.
At that point I drove away and haven't been back to that dealer since.
Old 06-14-2013, 05:08 PM   #292
CSG Mike
CSG Mike's Avatar
They don't know what that is (or don't acknowledge that it exists).
Old 06-14-2013, 05:40 PM   #293
ft_sjo
Drives: GT86
I find most dealerships a bit shitty. Threaten the parent body with legal action if you're not getting an adequate response.
Old 06-15-2013, 10:24 AM   #294
andrew20195
Drives: 2013 Subaru BRZ
You should call the Subaru customer help line and tell them what the dealership told you. It's one thing to say that there isn't an available update for your ECU. It's just plain wrong to try and sell someone a part they don't need.
andrew20195 is offline   Reply With Quote
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 04:26 PM
Need Help - 2 codes thrown jpit Issues | Warranty | Recalls / TSB 3 04-20-2013 12:41 AM
Bulb codes JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 1 02-17-2013 03:25 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 05:03 PM
