Old 06-14-2013, 12:58 PM   #1
a2cpc
Drives: WRX
Commiting Blasphemy...I should know this
I am taking a BRZ on a driveway test today. Just out of curiosity, what would be the easiest and cheapest way to raise the car 1 inch?
a2cpc is offline   Reply With Quote
Old 06-14-2013, 01:14 PM   #2
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
To avoid bottoming out entering/exiting the driveway?
Move.
You can always install some coilovers and raise the car 1" over stock, but it'll look dumb. Not cheap, though.
If your driveway is a rolled curb/gutter you can buy this junk:
problem solved.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 06-14-2013, 01:16 PM   #3
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
Stock height you can angle anything and be fine... I am fine even with a 1 1/2 - 2 inch drop.
RAWR BRZ is offline   Reply With Quote
Old 06-14-2013, 01:32 PM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The easiest way would be not buy the BRZ and stick with the WRX. As mentioned, at stock ride height I never found a driveway that I couldn't get up without scraping if taking it at the proper angle.
Old 06-14-2013, 01:39 PM   #5
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
Put 18's on it? (I think it comes with 17's ?)
GeorgeJFrick is offline   Reply With Quote
Old 06-14-2013, 01:56 PM   #6
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
My work entrance has a steep incline that is all gouged up from cars scraping. My BRZ can tackle it straight on no problem. My '03 WRX wagon with a softer stock suspension (and a bolt on rally innovations bar) will scrape if I go too fast head on (ie 6mph instead of 3).
If you can angle, you should be fine in most cases. I angle over speed bumps - not bc it doesn't clear, but bc when both wheels on the same axle drop at the same time, there's more suspension compression and it can "thunk" if you go too fast (ie 3mph vs 1!).
OP - are you looking to ride 1" taller all the time, or just negotiating one entrance? Solution could be as mentioned to put ramps over that extrance, or a more complex solution might be some sort of air bag suspension that would allow you to raise and lower your car on command. (Not sure if they make it for our cars or how they affect handling.)
ashtray is offline   Reply With Quote
Old 06-14-2013, 01:58 PM   #7
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
back in, assuming it's a driveway lol.
mezdup is offline   Reply With Quote
Old 06-14-2013, 02:02 PM   #8
monkeedoo
Senor Member
monkeedoo's Avatar
Drives: ME CRAZY
get bigger tires
monkeedoo is offline   Reply With Quote
Old 06-14-2013, 02:26 PM   #9
dsgerbc
Drives: BRZ(sold), STI
Drive in with a lot of speed, brake hard, release just before the kink so that suspension unloads just as you go over it
Seriously though, you're gonna be fine.
Old 06-14-2013, 02:54 PM   #10
gily25
Drives: Silica BRZ 6MT
You could try backing in depending on what your parking situation is...you may want to get a back=up cam but it'd be better than raising the height.
gily25 is offline   Reply With Quote
Old 06-14-2013, 02:58 PM   #11
DantKR
Drives: Subaru BRZ LT
Need pictures to properly asses.
DantKR is offline   Reply With Quote
The Following User Says Thank You to DantKR For This Useful Post:
Squishy86 (06-16-2013)
Old 06-14-2013, 03:04 PM   #12
Flat Black VW
Flat Black VW's Avatar
Only gonna raise the car .5". Need 18s AND bigger tires. Or some 19s will give you 1"
Flat Black VW is offline   Reply With Quote
Old 06-14-2013, 03:38 PM   #13
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
All this talk about wheels... You're supposed to compensate for the wheel diameter by changing the sidewall height so that the speedo doesn't change. If what you want is more clearance changing the wheel size is the wrong way to do it.
SubieNate is offline   Reply With Quote
Old 06-14-2013, 03:52 PM   #14
Bignicky1
Drives: Slowww
Raise the car more... oh lordd
Bignicky1 is offline   Reply With Quote
Blasphemy! I know, but I need some help! slizoth BRZ First-Gen (2012+) — General Topics 9 08-14-2012 03:45 PM
