Old 12-17-2011, 11:31 PM   #29
JDLM
JDLM's Avatar
Drives: 2009 BMW 335i
The coupe version of the WRX has been rumored since 2010
AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma
JDLM is offline   Reply With Quote
Old 12-18-2011, 02:28 AM   #30
nrclptcnsmniak
Professional Athlete
Drives: Marty's Hover Board
I would be really glad if the BRZ STI came NA then I wouldnt beat myself up for not waiting. If the BRZ STI comes with 250 hp then it gives me hope for the FA engine and pumping out a few more ponies from a standard BRZ.
I'm the type of guy who loves his girlfriend.
nrclptcnsmniak is offline   Reply With Quote
Old 12-18-2011, 03:54 AM   #31
[es vi: eks]
Drives: Subaru Legacy
Originally Posted by old greg View Post
That is the normal Subaru formula, just not for an STI. What you want is a BRZ Spec C Type RA
Wouldnt it be a BRZ Spec C Type R?
I thought almost every coupe was a Type R and the 4 door verson was a Type RA.
I'm sick of these mother f***ing earthquakes on these mother f***ing plains.
[es vi: eks] is offline   Reply With Quote
Old 12-18-2011, 04:18 AM   #32
nrclptcnsmniak
Originally Posted by tranzformer View Post
How much more weight could they realistically knock off, 30-50kg?
this is what I was thinking. makes me wonder whats really in store for the STI version besides suspension.
I dont see why a brake upgrade would be necessary or wheels. Or anything that adds weight. Power sure but if they want to keep weight down perhaps theyll just do suspension or something similar to an exige in comparison to an elise. Aluminum control arms? Thicker sway bars? who knows
Old 12-18-2011, 05:01 AM   #33
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
No turbo means lower price paying for things I'd end up doing anyway: lower suspension, basic power mods, aero parts, etc. Should cost less compared to adding OEM performance/visual mods to a base model in the end. And hopefully nicer tail lights tailored for widebody panels!
Old 12-18-2011, 05:07 AM   #34
nrclptcnsmniak
^agree
Old 12-18-2011, 06:30 AM   #35
fatoni
i dont think the exige has anything that an elise doesnt other than aero which may or may not be a good thing
Old 12-18-2011, 06:46 AM   #36
Levi
Drives: Toyota
CF roof FTW!
Levi is offline   Reply With Quote
Old 12-18-2011, 11:40 AM   #37
EJ20
EJ20's Avatar
Drives: NA8C, GDB, and R50
Originally Posted by Snoopyalien24 View Post
Well, this is from a Subie tech from another forum, talking about the FB
"hey to whom ever was wondering about the fa engine that doesnt already know. not that im special lol but im a subaru technician and in my fb engine training module we discussed direct injection and the fb was already bossed for it, as far as the heads and intake go. so subaru has long since planning this. i had slipped away with toyota for awhile back in 08 and got a very little insight then. but from what i can see the difference in the fa and fb is the fuel managment and compression...and likely cam profiles. however i can tell you my instructor told us that the fb wouldnt really be good for a high boost application...likely nothing stronger rods and pistons would not cure. when we opened this little baby in class i found it to be one of the closest tolerance engines ive ever seen! 15% coolant flow to the block and 85% to the heads with high volume not high pressure oil pump. kinda reminds me of porsche. hot running rotating assembly with nice cool heads. lots of o-rings instead of gaskets. all in all....makes an ej look like an ea82."
For those who don't understand much about engines (like me lol) another member discussed a little more about what this meant
Maybe its too early to ask this, but did he tell if using fb25 sb and fa20 heads work or not??
I like the idea of having an FA25 with ~250hp time only will tell
EJ20 is offline   Reply With Quote
Old 12-18-2011, 12:10 PM   #38
ZDan
ZDan's Avatar
Drives: '23 BRZ
The Porsche 911 GT3 RS 4.0 gets 85 lb-ft/liter but that relies on Porsche tech from the RSR. It is possible to get more than 75 but it costs $$$.
Originally Posted by Levi
LOL. The Ferrari 458 Italia makes 540 Nm @ 6.000 RPM from a 4,5l V8 that revs till 9.000 RPM. This is 120 Nm/l.
In the world most of us live in, 75 lb-ft/liter n/a is still about it.
Despite the existence of cars that claim 85 and 88 lb-ft/liter (458 Italia), a tune isn't going to take the FR-S from 150 lb-ft to 170-176 lb-ft, I can *promise* you this.
What you *can* expect is for similar n/a torque/hp gains per mod $$$ as an S2000. I.e., meaningful additional n/a gains are going to be relatively costly...
Old 12-18-2011, 12:18 PM   #39
old greg
Rocket Surgeon
Drives: PSM GGA OMG
I guess, my Subaru knowledge doesn't go back that far.
But for me 'Type R' is just too strongly associated with Honda and ricers to ever be acceptable on a Subaru. In fact, if such a badge came from the factory on one of my cars, I'd pull it off just on principle.
old greg is offline   Reply With Quote
Old 12-18-2011, 12:19 PM   #40
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Navi View Post
No its not, factory tunes always calculate in fuel economy, durability and emissions.
Fuel economy is not taken into consideration for WOT operation. For some safety margin, the factory tune should be slightly richer than optimal. Power dropoff on the rich side of the curve is not very substantial, so leaning it out from factory to *optimal* still isn't going to buy you much for most cars like this.
They also compensate for bad quality fuel.
By pulling timing when knock is sensed. When knock isn't sensed, full timing. Probably a bit conservative, but in my experience there's usually a pretty broad range of ~4degrees where the engine will make the same power, so there's no cost to running advance at the lower end of that range. And below that, the dropoff with less advance is not precipitous.
There will be room for more performance, don't worry.
Some room, but not much.
I'd expect that with a low restriction intake and exhaust and custom tune, you might see +5% torque and +10% power, after spending $1000s. You will barely feel this (but you'll certainly HEAR it!)
Old 12-18-2011, 12:58 PM   #41
aesthetect
form follows function
aesthetect's Avatar
Drives: 240Z, E90 M3, tacorunner
^ maybe im misunderstanding you but tuning the car to slight rich from stoiciometric tends to produce more torque. slightly lean giving a bit better fuel economy. either way youre definitely right in the fact that theres not likely to be a lot of gain to be had by modding this factory FA 2.0 NA.
Details on your source?
For what it's worth, staying NA is the only way I'd consider the STI version of the car. This car should not follow the normal subaru formula. Everyone wants a lighter and turbo STI which will never happen together. I want a NA, slight bump in power, big bump in suspension/handling and a nice chunk less weight.
couldnt agree more
aesthetect is offline   Reply With Quote
Old 12-18-2011, 01:02 PM   #42
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
I don't disagree with you. I was just stating that some street cars with NA engines have been able to gt more than 75 lb-ft/L. Not saying Subaru will do that but just that it was possible.
tranzformer is offline   Reply With Quote
ITB, how much more power? 1660 Engine, Exhaust, Transmission 119 01-22-2014 05:38 AM
What is your prediction on FT86 power and Subaru 086a power? 86Fan Scion FR-S / Toyota 86 GT86 General Forum 88 08-26-2013 11:49 PM
Power Seats? Swancoat Scion FR-S / Toyota 86 GT86 General Forum 23 12-15-2011 05:09 PM
Maybe the FT-86 doesnt need massive power........ TriggerTRD Scion FR-S / Toyota 86 GT86 General Forum 67 06-30-2011 11:58 PM
is your new M3 down on power? NESW20 Other Vehicles & General Automotive Discussions 6 12-27-2009 10:03 AM
