View Poll Results: Have you had an issue with your Direct Injection System?
I have had a DI issue and was fixed under warranty (Subaru) 10 12.35%
I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) 2 2.47%
I have had a DI issue and was fixed under warranty (Toyota) 31 38.27%
I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) 3 3.70%
I have had a DI issue and denied warranty by (Subaru) 7 8.64%
I have had a DI issue and denied warranty by (Toyota) 14 17.28%
I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) 8 9.88%
I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) 6 7.41%
Voters: 81. You may not vote on this poll
Old 06-14-2013, 01:39 AM   #85
OrbitalEllipses
Drives: Attitude
I heard a pop on cold start once this winter. *gulp*
You're making me a worse hypochondriac than I already am.
Old 06-14-2013, 01:51 AM   #86
joergasm
joergasm's Avatar
Drives: Subaru BRZ 2013 - SWP 6MT
I like the english and accurate spelling they used in the report.
joergasm is offline   Reply With Quote
Old 06-14-2013, 01:54 AM   #87
joergasm
joergasm's Avatar
Sorry for the noob question, but when you guys get the DI issue, does it show up as check engine light and is displayed on the code reader?
Old 06-14-2013, 02:12 AM   #88
ft_sjo
Drives: GT86
The popping back in the inlet manifold during cold start/cat warmup is most likely nothing to do with the fuel injectors. It's to do with a very aggressive spark angle.
All this talk about parts being made wrong and tolerances is theory from the unqualified on this forum and it's having a negative impact on new owners who come on here and read this drivel. You guys really should stop this as you're going to create a bad name for our cars when it's really unjust.
Old 06-14-2013, 02:24 AM   #89
OrbitalEllipses
Drives: Attitude
The cars made a bad name for themselves...200hp? C'mon.
Old 06-14-2013, 02:59 AM   #90
rx3
Isn't the engine supposed to run late ignition during the start/warm-up phase in order to get the cat up to operating temperature in a shorter time?
rx3 is offline   Reply With Quote
Old 06-14-2013, 04:11 AM   #91
ft_sjo
Drives: GT86
Yes. Modern cars like ours will typically fire as late as 12-15 ATDC with a reasonably open throttle and appropriate fuelling to get the primary cat up to temp as quickly as possible.
It's not really a condition the engine is super happy running in (think: anti-lag, it's basically the same kind of idea), so a couple of misfires during this phase of warm-up isn't the end of the world. It's not related to transient det problems killing injector seals!!
Old 06-14-2013, 04:20 AM   #92
rx3
I've been noticing misfires as well during start and warm-up and they didn't worry me because they happened in the exhaust.
But in this case people have been talking about misfires or popping sounds from the intake/engine-bay, which should particularly not happen in the warm-up phase because of late ignition.
Old 06-14-2013, 06:42 AM   #93
ft_sjo
Drives: GT86
I am keen to hear your technical explanation.
Old 06-14-2013, 09:49 AM   #94
phm14
Loves the Smell of Track
phm14's Avatar
Drives: '13 86
Without including info on whether or not the engine management software has been altered ("running a tune"), this poll is fairly useless. It seems several individuals have suffered engine damage due to bad tunes, and are trying to work up as big a stink as they can to pressure the makers into paying for their tuners F-ups. Some claim to have the issue with stock cars, but when pressed for info, most with the DI leaks admit they paid someone to play with their ECU.
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD
http://www.ft86club.com/forums/showthread.php?t=7934
phm14 is offline   Reply With Quote
Old 06-14-2013, 09:51 AM   #95
rx3
I'm keen to hear an explanation why a 12-15 ATDC late ignition would cause a misfire in the intake and not in the exhaust given the fact that the exhaust valve opens before the intake valve.
Besides, one should at least be allowed to ask why one should pay $25 k more for a new BRZ (yes they do cost significantly more in Europe than in the US) than a new Fiat Punto when one is not allowed to drive it aggressively in order to not void the warranty anyway.
Old 06-14-2013, 10:00 AM   #96
phm14
phm14's Avatar
Drives: '13 86
Thousands of 86 owners, including myself, drive these cars aggressively every day. Go search YT for "FRS BRZ track" and watch. Saying you can't drive them aggressively because a few have run bad tunes that caused issues, and one who continued to flog his car multiple times on track after major problems were apparent and blew up his motor, is kind of like saying you can't drink from a glass because a glass may break if it's dropped.
http://www.trackjunkies.org/topic/24...nk-i-broke-it/
Old 06-14-2013, 10:03 AM   #97
phm14
phm14's Avatar
Drives: '13 86
[ame="http://www.youtube.com/watch?v=OaMWCSgPuSs"]Rent4Ring Subaru BRZ Stage 2 Nürburgring rental @ GT Events April '13 - YouTube[/ame]
Old 06-14-2013, 10:06 AM   #98
rx3
I didn't say you can't drive aggressively. I just said that Subaru voids the warranty if you go on a track or autocross it (and the injector seals happen to fail). I just find this a littlebit lame considering what they charge for this car in Europe.
direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 12:35 PM
Fuel Injector Cleaner Purdue FR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-18-2013 06:54 AM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 08:32 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
