Old 06-13-2013, 01:49 PM   #1
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Premature low fuel light
Does anyone else think their low fuel indicator light comes on way way waaaaaaaaaay too early? If I fill up as soon as the light comes on the car only takes just over 10 gallons. I just filled up an hour ago, after driving around with the fuel light on for the last 40 miles, and the tank only took 11.1 gallons. Since our gas tank holds 13.2 gallons (50 liters) it would be much more helpful if the light didn't come on till somewhere around 1.5-2.0 gallons were left.
I'm trying to learn to ignore or or just go another 50 miles before filling up but I feel like this is going to burn me eventually
Anyone else notice this?
Old 06-13-2013, 01:53 PM   #2
The359
X Rated
The359's Avatar
Drives: 2017 BRZ Series.Yellow
I too was surprised that the light came on well before the indicator was even on E. I do recall it stating somewhere in the manual (or maybe the quick reference guide) that when the light comes on, there is 1.5 gallons in the tank.
NULLA TENACI INVIA EST VIA
My BRZ
The359 is offline   Reply With Quote
Old 06-13-2013, 02:49 PM   #3
WolfpackS2k
Yeah I thought the manual said the light comes on when there are 2 gallons left. But mine is coming on with over 3 gallons left, which is over 20% of the tank's capacity!
Old 06-13-2013, 02:52 PM   #4
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
If you see your fuel gauge at the off position, that's pretty much the empty position. I ignore the fuel light until I actually dip right below the redline. Even then I've never put 13 gallons in. Like a pilot does, trust your gauges.
Keep in mind, running a car until it's dry can be bad for the car.
DoomsdayJesus is offline   Reply With Quote
Old 06-13-2013, 02:52 PM   #5
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Call me crazy.... but I like knowing I have a decent reserve when the light comes on. My old A4 did it at 3 gallons so i have no issues with the FR-S doing it
supramkivtt2jz is offline   Reply With Quote
The Following User Says Thank You to supramkivtt2jz For This Useful Post:
zaptorque (06-14-2013)
Old 06-13-2013, 02:54 PM   #6
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
hmmmm. Didn't even know it had a low fuel light. It's never come on.
FRSFirestorm is offline   Reply With Quote
Old 06-13-2013, 02:55 PM   #7
qoncept
qoncept's Avatar
I'm trying to hit 400 miles on a tank but I just can't keep going once that light comes on. The most I've put in is 11.2 gallons.
qoncept is offline   Reply With Quote
Old 06-13-2013, 03:00 PM   #8
WolfpackS2k
$20 says your A4 has a considerably larger fuel tank than the BRZ.
Everyone wants a decent reserve. But your fuel light coming on when you have 3 gallons left means you can go another 75-90 miles before empty. That's a lot given most people only get 300-350 miles per tank.
Old 06-13-2013, 03:03 PM   #9
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
If it really bothers you, put a piece of black tape in front of the light and keep an eye on the gauge.
Old 06-13-2013, 03:10 PM   #10
WolfpackS2k
I'm just saying man...your previous comment is apples to oranges.
Old 06-13-2013, 03:12 PM   #11
thill
Reminds me of a Seinfeld episode..
[ame="http://en.wikipedia.org/wiki/The_Dealership"]The Dealership - Wikipedia, the free encyclopedia[/ame]
The Following 3 Users Say Thank You to thill For This Useful Post:
kevinnivek8877 (06-18-2013), Marchy (06-13-2013), WolfpackS2k (06-13-2013)
Old 06-13-2013, 05:38 PM   #12
reeves
Get the torque app + elm 327 bluethooth OBD II reader (~$25), then you'll never have to guess ever again. http://www.ft86club.com/forums/showt...300#post588300
The fuel light comes on at exactly 2.4 gallons left every time for me.. that means you can go for another 70-80 miles if you cruise lightly.
Old 06-13-2013, 05:41 PM   #13
DeeezNuuuts83
Drives: 2006 Evo IX SE
Generally, the low fuel indicators of cars come on when there are about two gallons or so left. I'd prefer for it to come on earlier rather than when it is truly close to empty.
DeeezNuuuts83 is offline   Reply With Quote
Old 06-13-2013, 05:47 PM   #14
dtrop
Drives: Wrb 2014 limited brZ
It's generally not good to let your tank run close to empty....
dtrop is offline   Reply With Quote
The Following 2 Users Say Thank You to dtrop For This Useful Post:
DeeezNuuuts83 (06-13-2013), supramkivtt2jz (06-14-2013)
Low Fuel Light. Draco-REX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 64 11-07-2015 08:33 PM
Will installing sub frame and tranny mount bushings cause premature wear? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-16-2013 03:56 PM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 10:06 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
