JonMotoring
Old 06-11-2013, 04:36 PM   #10165
SpyderMS
SpyderMS's Avatar
Drives: 2014 BRZ - Crystal Black Silica
Anyone have any tips on washing your car in AZ? I tried washing in the evening but no matter what I do I get water spots/streaks everywhere. I've read taking it to auto-washes isn't the best idea for the paint but I'm really considering it if I can't get my car clean
SpyderMS is offline   Reply With Quote
Old 06-11-2013, 04:37 PM   #10166
40flash
John 1:12
40flash's Avatar
Drives: Pearl white BRZ Limited
Originally Posted by nelsmar View Post
It looks so tall from this angle ;(
Doesn't look too tall to me. Looks great. What wheels are these? Size and offset?
40flash is offline   Reply With Quote
Old 06-11-2013, 04:39 PM   #10167
EZWood
BAMF
EZWood's Avatar
There are filters you can put on your hose. You have to experiment. I don't have this issue, but my car is white and I use microfiber to dry my car so that helps with streaking also.
The Following User Says Thank You to EZWood For This Useful Post:
SpyderMS (06-11-2013)
Old 06-11-2013, 04:39 PM   #10168
WithNolock
Drives: Scion FR-S
June 22nd @ Tucson cart track
1. redleader
2. ninjun
3. SpyderMS
4. Mattles
5. bignrich
6. 40flash
7. CaptainJack
8. Jasper
9. @WithNolock
10. GotM
11.
12.
13.
14.
15.
If you're still getting "mention" tags, Its because you haven't confirmed whether or not you're still going to make it.
Looks like we've got enough for our own run group, assuming every one on the list makes it. We still have plenty of room for more people, the track owners will split the whole group into smaller run groups and just extend the night longer (on track til 11 possibly) so everyone has a chance to get four 20 minute sessions in.
Sorry, didn't see my mentions for some reason. I'm still in.
WithNolock is offline   Reply With Quote
Old 06-11-2013, 04:42 PM   #10169
WithNolock
Drives: Scion FR-S
[ame="http://www.amazon.com/Meguiars-G14422-Ultimate-Quick-Detailer/dp/B000RXNLK6"]http://www.amazon.com/Meguiars-G14422-Ultimate-Quick-Detailer/dp/B000RXNLK6[/ame]
After I wash and dry my car I do a once over with this. Only way to keep your car streak/spot free with the crap ass water we have.
The Following User Says Thank You to WithNolock For This Useful Post:
Old 06-11-2013, 04:45 PM   #10170
Boblhead
Drives: Asphalt FR-S
Wash you car early morning, if you have a air compressor use that for the nooks and crannys around your headlights and taillights and around your side mirrors (these are the major water build up spots for me) ill also keep some quick detail spray just incase I've missed or have to fix a streak. Microfiber clothes are what i use to dry as well
Edit if I'm not being lazy i will fill up a keg with reverse osmosis water and i will rinse my car with that and it drys itself with 0 streaks
Sent from my XT907
Boblhead is offline   Reply With Quote
The Following User Says Thank You to Boblhead For This Useful Post:
Old 06-11-2013, 04:57 PM   #10171
Sivtec
Sivtec's Avatar
Haha you ran into the same problem I had. I would say if you do it yourself, do it EARLY in the morning... like really early...
Me personally, I said **** it. I just get my car washed by these guys:
http://www.azdetailing.com/
They are considered an "Elite" detailer and when you visit their shop, you will know why
They use a triple dilution/oxidation (something like that) of their water.
The Following User Says Thank You to Sivtec For This Useful Post:
Old 06-11-2013, 05:09 PM   #10172
nelsmar
Park in the shade. Before drying get the car very wet and then use a dedicated towel for the body, as in not one you shower with. This should be washed alone as to not get dirt and contaminants in it to damage your paint.
Wash a portion of the car at a time, such as front to back. This way if it took to long to dry the front you can simply re-wet the rear. The trick is to dry it by hand, not by the air. If its just a small portion use a microfiber cloth that is very wet and squeeze it to get that portion wet, or wipe.
You can also use a squeegee for large pieces such as the roof, and hood. This can be used to "push" the water off quickly, and then quickly use a dry towel to get the rest.
Having a quality wax coat at all times helps, as the water will bead together rather than going into a thin sheet and covering the entire car with water spots.
You can also instead of using water on spots that dried use a quick detailer as that will make the region damp, and then dry with a microfiber cloth.
Thanks! Enkei RPF1 in SBC (custom order only) 18x9.5 +38 (non production sizing, there were ~40 sets made in this size by a few shops).
They poke out quite a bit unless its cambered like that. And i would rather a +42 or +45 offset so i could ease the camber a bit and go with a wider tire personally. But I am more one for more grip & play than park and display. Though I do like how it looks. -0.5 camber in the rear and about 2-3mm more drop on the front would look wonderful if I wasn't eating tires up for fun. :P
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
Old 06-11-2013, 05:29 PM   #10173
SpyderMS
SpyderMS's Avatar
Ok cool. I have microfiber towels but this last time I tried to use my leaf blower after watching a YouTube video on detailing, and either I didn't use it correctly or using it in the AZ heat doesn't work well, so will keep using the towels instead. Found a filter on Amazon that I will try out as well.
Originally Posted by WithNolock View Post
http://www.amazon.com/Meguiars-G1442.../dp/B000RXNLK6
Awesome, I had this in an Amazon Wish List to potentially buy, so I will definitely order a bottle of it. I'm using their Gold Class car wash shampoo as well.
Thanks! I don't have an air compressor but I do have a leaf blower which works pretty well for that. I tried using it on the entire car but not with very good results. Will look into the reverse osmosis water... never heard of that...
Will try early in the morning... I hate waking up but I hate how my car looks right now even more, lol. As for AZ Detailing... I looked at their pricing page and saw why they're considered the 'Elite' detailer, LOL. That's far too heavy on my wallet to consider, at least for regular washes.
Thank you, will keep all of this in mind
Old 06-11-2013, 06:17 PM   #10174
redsuns03
Lol detailing questions finally I have decent knowledge with sharing
First off avoid washing your ride around 1pm to 4pm unless you can wash it under a shade. So it will still be somewhat damp.
How I clean mine before going to show off my car is:
Pressure rinse top to bottom
Pressure rinse the wheels and the area inside.
Washing the tires and rims with 1 micro fiber towel per side. (Double bucket it)
Foam gun the whole car
Pressure rinse
Double bucket with car shampoo using a micro fiber mitt.
Pressure rinse
Use DRYING micro fiber towel per section
Follow up by using black detail spray with a dry micro fiber towel
Then use another clean one to completely dry the car.
Then if I decide to polish and wax, I do that during 2am or 5am so it's cool enough for it to work.
Sent from my SGH-T999 using Tapatalk 2
The Following User Says Thank You to redsuns03 For This Useful Post:
Yruyur (06-11-2013)
Old 06-11-2013, 06:21 PM   #10175
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
I've used this guy for powder coating. Did good work for me a quite reasonable.
http://www.section8powdercoating.com/
Thanks I called another local place and they wanted 175, hahah yeah the strut bar only costed 95 shipped new. I think I will try my hand at $10 metalcast spray paint
FR-Shadow is offline   Reply With Quote
Old 06-11-2013, 06:27 PM   #10176
Yruyur
Yruyur's Avatar
Pressure rinse
Pressure rinse
I would add
Wash with car shampoo top then upper sides then use another mitt for the low section of the car sides.
Pat dry not using any side to side motion. A good microfiber cloth with get most water off by just touching the towel. I hold the towel at two points and just touch the car.
This will get 90% of the water off
Only at that point do I dry the remaining amount using a liberal amount of detailer spray. Always want some type of lube if touching the paint.
The Following User Says Thank You to Yruyur For This Useful Post:
SpyderMS (06-12-2013)
Old 06-11-2013, 06:40 PM   #10177
redsuns03
I would add
What I noticed on the detailing threads the ones that are very meticulous have black 86s lol
Old 06-11-2013, 06:43 PM   #10178
Yruyur
Yruyur's Avatar
Or asphalt lol.
redsuns03 (06-11-2013)
