Old 06-07-2013, 10:06 AM   #113
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by 2forme View Post
Is it required to aggressively shift the vehicle for this issue to occur? Reason I ask, is I've seen one start misfiring who's owner very rarely, if ever, aggressively shifts.
Not really. .6 seconds isn't that aggressive of a shift. It's not a lazy shift but it's far from a power shift too. Can someone datalog the following? Run the car up near redline is 2nd, get off the gas, then floor it again, within .2-.6 seconds and see if this occurs then? I bet it does. I use that type of driving to set the car (or unsettle it) by moving weight around, etc...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
2forme (06-07-2013)
Old 06-07-2013, 10:35 AM   #114
Stevo22
Stevo22's Avatar
Drives: GR86
I guess I should not have said speed shifting, because you are correct .6s is not super fast. Also from what I read in the TSB from south africa, Toyota said that you had to be shifting at a specific rpm or higher (near redline) and landing in an rpm above like 5200 in the next gear. The way I read the TSB is that you need to have a both of these occur at the same time. Is that correct or is it either one independently? Also I do not know how to read the transient ignition retard table, but it looks like it is the same after 4000 rpm. So could it be happening anytime you are shifting above that?
Stevo22 is offline   Reply With Quote
Old 06-07-2013, 10:48 AM   #115
s2d4
s2d4's Avatar
Originally Posted by Stevo22 View Post
This is a post from one of the other threads about this topic. I think it is important for everyone to see this if they have not already. I also think the reason that an after market tuner would not catch this is to my knowledge (which is limited) you get your car into a certain gear and do a "pull" on a dyno and they tune according to that. Rinse and Repeat until the tuning is done. During this process you do take the engine to redline, but do not "speed" shift through the gears at redline. Therefore they would never look at the transient ignition retard numbers because they would not see the detonation.
It should also be noted that @Sithspawn did another log after updating the transient ingnition table and stated that the detonation was gone.
So what about the instance of it happening in the middle of tuning? Did the tuner just let it knock excessively to come out with the same result?
Old 06-07-2013, 10:53 AM   #116
2forme
We get what you're trying to do. This isn't the thread for it. It's not tuner dependent.
Old 06-07-2013, 11:18 AM   #117
xjohnx
Grip>Slip
xjohnx's Avatar
I thought it was a valid question. If it's the transient spark tables, why would it happen during tuning? I haven't seen any dyno tuning methods where you'd be on-off-on the throttle in a similar manner that is described in the TSB or used to induce oversteer.
Old 06-07-2013, 11:21 AM   #118
s2d4
s2d4's Avatar
Can we leave the dramatic mind game conspiracy theories out of this thread? Not going to bother playing gem with you.
Keep it on topic please. He made a statement, there just happened to be a case that differ, hence the question. What is the explanation for the difference in that case?
Old 06-07-2013, 11:30 AM   #119
brillo
Drives: 2013 Firestorm FR-S
Was it possible that activity previous to the tunning weakened the seals and they let go while tuning due to the pressures? Just thinking of possible scenarios, not saying that I'm right in this particular case.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 06-07-2013, 07:56 PM   #120
mad_sb
Drives: 2013 Asphalt FR-S
If detonation is what is killing the seals, that can happen during tuning, during a wot pull on the interstate, pulling away from a long traffic light etc etc it is not something that only happens as a result of the conditions in the tsb.
Certainly, the omission of transient retard beyond 5,000 rpm will cause most cars to experience shift knock at some time or another... but that is not the only time knock can occur.
IMO, the seals are simply a poor design and will continue to fail even after the update for some un lucky folks with knockzillas under the hood. That's not to say that fixing the transient retard issue is not valuable, it certainly is, and both subaru and toyota should do a recall / all regions tsb on the issue at a minimum.
The Following 3 Users Say Thank You to mad_sb For This Useful Post:
ATL BRZ (06-07-2013), Carwhisperer (06-07-2013), xjohnx (06-07-2013)
Old 06-07-2013, 09:29 PM   #121
Carwhisperer
Drives: A lot of supercars.
They are going to have to sooner than later.. I know over a dozen people in my area that owns a 86 and 4 of them are having/had the issue, not including myself.
Carwhisperer is offline   Reply With Quote
Old 06-07-2013, 09:42 PM   #122
FT_Monk
Drives: Over the hill WRX
That plastic piece acts as a seal in a location near the combustion chamber? Even if there is no knocks it will deteriorates just from continuously sustaining temperature cycling.
FT_Monk is offline   Reply With Quote
Old 06-07-2013, 09:55 PM   #123
Carwhisperer
I haven't seen anyone with the DI seal issue before April, which is when mine and a few others started. Has anyone else? I was right over 20k miles.
Old 06-08-2013, 02:55 AM   #124
Marrk
Drives: Honda Fit
I thought that we were in agreement that the seals and the design of the seals were, in fact, a standard issue and widely used across several manufacturers of DI engines.
Marrk is offline   Reply With Quote
Old 06-08-2013, 04:35 PM   #125
BRZnut
Drives: BRZ DGM Limited
So are we saying that in its current design we should keep the RPMs below 4K to prevent seal failure?? Drive in in break in mode for the life of the car???
Old 06-08-2013, 05:41 PM   #126
Dezoris
Dezoris's Avatar
We can all have our backseat opinions. Detonation at high RPM combined with high engine temps and sustained heat would make complete sense why a $10 seal would fail.
Thing is we won't know until people start running new or modified flash seals and pulling injectors after hard mileage.
The Following User Says Thank You to Dezoris For This Useful Post:
mad_sb (06-08-2013)
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 07:33 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 05:26 PM
Direct Injector's Leaking Carwhisperer Scion FR-S / Toyota 86 GT86 General Forum 1 05-11-2013 10:31 AM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 05:43 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 06:03 PM
