Drives: 2013 Scion FR-S Asphalt
I have been a long time reader and have always been holding out on buying as im deploying in September and did not want to leave a new car sitting for 8 months, but then i gave in. Did not wake up expecting to buy a car today, but after work I saw the dealer down the road had an asphalt one in manual and a few hours later I went from this to this:
![]() ![]() I will miss the sex box, box nasty, ice cube, toaster, what ever you want to call it What should i do to her when i leave her for a few months? Take the batt out? Let the gas and oil sit or drain it? I know gas breaks down over a period of time. Car cover? what about my rotors? I dont want to come back to surface rusted brakes. The last time i left my XB for a few months the relay for my key-unlock- button got stuck so i had to use my key to get into my car -_- |
#2 |
Keep Calm And Drift On~
Drives: Scion FR-S WhiteOut 6 Speed Manual
Great buy and good luck on your future endeavours.
What sort of storage options are you looking at? I feel this will effect on how you should store your FRS. Regardless of the form of storage I think the biggest problem will be the eventual brake down of your fuel . I suggest filling up with ethanol free gas and have about 1/4 th of s tank max.(so the pump is not exposed) Then add a bottle of staybill (correct my spilling) It's a fuel additive that preserves the fuel for extended time periods of fuel. Anyone like to chime in? This is just my 2cents |
#3 | |
Apostle
Drives: JesusMobile
You don't need to do much. Pull the battery and change the oil. I would add some fuel stabilizer and just put it in storage. When you start it back up, make sure you pull the fuel injector relay, and run the car for 60-90 seconds to prime the fuel pump and build oil pressure. Put both back in and start the car up. The only other major step some people like to do is cover plastic parts with aluminum foil to keep it safe from animals. They like to nest!
I've stored my miata two winters, without fuel stabilizer, and it was fine. I told my friend to do the same relay trick for restarting his S2K after he got back from deployment. He didn't use fuel stabilizer but siphoned out the old gas and put in some new stuff and he was fine. You can put in some more air, or just store it on crappy tires. If you have the space, some people like to the car on jack stands. Here's the Miata.net storage guide if you want to be OCD: http://www.miata.net/faq/faq3.html Quote:
#4 |
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
First and Foremost. THANK YOU FOR YOUR SERVICE!
When my Brother in Law deployed he left behind his precious new Jeep. Fortunately, he lived only a few hundred miles away and together we decided he would leave his Jeep with us. We parked it in our Garage and drove it 2 miles every Sunday until he returned. He was deployed for 27 weeks and when he returned, It was Washed, Waxed, Oil Changed and had 54 more miles on it than when he left. I realize this may not be possible in your case and I do not know much about storage but if this is at all possible with someone you trust with your life, I highly recommend it. Again, THANK YOU and STAY SAFE! |
#5 |
Thanks paul, that is deff a big help. I'm looking into climate controlled storage units right now but if worse comes to worse i might just have to store it in someones driveway.
And thanks Ntron1! Just one more question. I looked after my friends accord for a few months while he was deployed. After 2 months of not starting it I noticed his fuel went from 1/4 to full. I opened the cap and pressure came hissing out. I had to start the car to relieve excess pressure and it made a loud whistling sound like a jet taking off the second i started it. Like pounds of pressure escaped at once. What caused this and will pressure build in my tank as it sits? |
| Took it out of storage for a day | dexterium | CANADA | 17 | 01-21-2013 08:41 PM |
| Winter Storage | Luke.Cariveau | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 11-18-2012 06:15 PM |
| Last shot before storage | Xangvang | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 11-07-2012 01:29 AM |
| Winter storage | Skye | BRZ First-Gen (2012+) — General Topics | 7 | 10-03-2012 09:02 PM |
| storage? | subaruferrucci | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-11-2012 03:50 PM |
