Old 05-29-2013, 06:04 PM   #141
Chaetagnath
Drives: Whiteout FRS
Originally Posted by goodcjw2 View Post
good to know your progress
I haven't figure out how to make the immobiliser bypass work properly, can you provide any tips on that topic? Thanks in advance.
First, be sure one of your keys is placed in the box properly. The chip should be in the circle of wire thingy.
like this:
Screw the top back on tightly, the key should not move in there. Next, immobilizer is this device sitting on the ignition (it is held on by clips on the top which can be gently pushed aside to remove):
The wire from the bypass that is in a ring, must be taped around the edge of the immobilizer like so:
Wrap it tightly around, and tape it REALLY well. You do not want that thing ever slipping off, especially if you are stashing it elsewhere in the dash (which is what I did).
Be sure the immobilizer is connected to the original harness from your car. Plug the other end of the copper ring wire into the immobilizer bypass box (the blue plug). Then, plug the harness which runs from the immobilizer bypass box to the easygo module in correctly (see the wiring diagram). It should work now. Of course, you still have to do something about the steering wheel lock, I'll post something on that later.
Chaetagnath is offline   Reply With Quote
Old 05-31-2013, 12:11 AM   #142
jacobzking
Drives: White FRS
please let us know what you guys do about the steering column lock
jacobzking is offline   Reply With Quote
Old 06-01-2013, 04:18 PM   #143
Chaetagnath
Essentially you have three options for the steering wheel lock.
A. Have a copy of your key made (a non-chip key, should cost less than 2 bucks). Mark the key about half a centimeter where it sticks out of the ignition, cut the key off at that point, reinsert and use needle nose pliers to turn it to the on position. Cover, and never touch again.
B. Remove the entire ignition assembly. This requires some skill, as you must get that bolt off somehow (see this video [ame]http://youtu.be/rMv79GFUh-s[/ame]), or dremel through the cover folding it onto the steering wheel column (which is what I ended up doing in frustration).
C. Remove the steering wheel lock itself. Now, this is something I can't entirely vouch for, but might end up being the best way for a clean solution. I figured this out after dremeling off my ignition assembly, so I don't know how easy it is to do when it is still attached to the car. I am currently travelling so I won't be able to post pics for a couple of weeks, but here is how it would work:
Remove the steering wheel column cover. Take off the immobilizer. On the back side of the ignition cylinder (midway of where the key will be), there is a small hole with a button. The hole is hard to see, there are some metal prongs sticking out, it is not in those columns, it is a flat hole between them. You need to insert your key, and turn it to the on position (or it might be ACC, I can't remember offhand). In that position, use a pick or other narrow tool, and insert it into the small hole in the back. If the key is in the right position, the button will push in. Pull on the key, and the ignition will slide forward a little bit. Next, look for a small hole on the other side (you should be able to see it facing you as you sit in the seat). Insert a probe into that hole, and pull on the key more, the ignition should just slide right out.
Now, look into the chamber where the ignition was, on the bottom there is a spring, and two pieces of metal that slide back and forth (this is the steering wheel lock). This is the lock. You may be able to use long narrow needle nose pliers to remove the spring and the metal pieces. Then reinsert the ignition and you should be good to go.
Old 06-02-2013, 03:11 AM   #144
cfusionpm
Drives: Firestorm 6MT Scion FR-S
I think I'll just stick to using a standard key..... /shrug
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 06-02-2013, 09:48 PM   #145
luluma
luluma's Avatar
Drives: 2013 Scion FRS
I am interested with the OEM look, what is the OEM panel part numbers?
can we buy a complete set from Subaru ? and place it into Scion?
luluma is offline   Reply With Quote
Old 06-17-2013, 07:21 PM   #146
Chaetagnath
Finally put together my DIY for the EasyGo kit. It can be found here if you are interested. http://www.ft86club.com/forums/showthread.php?t=39313
The Following 2 Users Say Thank You to Chaetagnath For This Useful Post:
civicdrivr (06-18-2013), draggin_az (06-17-2013)
Old 07-08-2013, 01:48 PM   #147
nunonuna
nunonuna's Avatar
My driveway is around a blind sweeping corner that people love to speed through so I dont wanna take extra time. And I mean the bypass takes 2 minutes so why not. doesnt hurt anything
Could you please let us know how to bypass clutch?
I just installed it and can't start remotely because of clutch.
nunonuna is offline   Reply With Quote
Old 07-08-2013, 04:10 PM   #148
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Mind you this wasn't on my FRS, but an still. I just tapped two of the 3 wires together that ran to the clutch. If you first combo doesn't work, then try the other way. Sorry I can't be more helpful but that's what I did.
Old 07-08-2013, 06:51 PM   #149
Chaetagnath
http://www.i-club.com/forums/hawaii-...bypass-217999/
Old 07-08-2013, 07:11 PM   #150
Blake
Drives: Ravin Scion FR-S
I bought this and had it installed yesterday! It all works, EXCEPT the remote engine start doesn't yet. The guy said it'll start and then die and keep trying to re start. He has to talk to them at EasyGo to figure out what needs to be done. However, the push start works great and so does the keyless entrance on the handle! The locks also automatically unlock when you turn the car off...nice!
Blake is offline   Reply With Quote
Old 07-08-2013, 07:17 PM   #151
nunonuna
nunonuna's Avatar
Originally Posted by Chaetagnath View Post
Thanks~ you always help me since I asked you first question.
That looks simple and easy, but isn't that gonna bring CEL up?
I heard someone got CEL because computer detected it as the clutch pedal is always pressed in.
Old 07-08-2013, 08:10 PM   #152
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Question
Sweet. Low on the mod list, but definitely the kit to get it sounds like. Thanks
I think it requires an inverter system though does it not?
Old 07-08-2013, 09:59 PM   #153
Chaetagnath
Hmm...I don't know, I've never actually done this. If thats the case, I'm not sure how you would get around it.
Old 07-08-2013, 10:10 PM   #154
nunonuna
nunonuna's Avatar
Well.. I might wait and try research more and live without remote start until the winter. The only reason I want it is for the winter tho~
BRZ keyless entry/ignition and auto climte control system how-to video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 26 11-21-2013 02:58 AM
How secure is the Keyless Entry and Start system? SeattleJeremy BRZ First-Gen (2012+) — General Topics 31 09-23-2013 12:23 AM
Keyless Locking bdbx18 Electronics | Audio | NAV | Infotainment 4 12-16-2012 06:38 PM
Keyless ignition for my FRS Gixxersixxerman Electronics | Audio | NAV | Infotainment 1 12-01-2012 12:09 AM
BRZ Keyless entry? Motopythons CANADA 7 06-03-2012 06:56 PM
