#15 | |
ビーアールゼット
Drives: WRB BRZ '18
If you can post the TSB, please do so. |
#16 | |
Drives: 2013 FR-S Ultramarine
#17 |
#18 |
ビーアールゼット
Drives: WRB BRZ '18
I thought you said it was a new TSB regarding gear grinding? I see that you posted the rattly shifter TSB, which has been out for a while. My shifter has a tiny rattle, and my VIN is higher than what's specified in that TSB, so I don't think that one applies to me.
#19 | |
Drives: 2013 Firestorm FRS
More info on this? I found your post on tsb, but it was about the shifter, not the transmission |
#20 | |
#21 |
Oh yea...he mentioned that it would probably be more noticeable around redline and obviously progress to lesser rpm's over time. Thats why I'm thinking the shifter issue may have something to do with that. Again I'll ask him about it and get more details tuesday.
#22 |
Ok I spoke with the tech about this again today and he stated that this particular customer's vehicle would grind while shifting between 4th and 5th gear at RPM's above 6k from what he remebered.(job was 3 months ago now) He said it did not matter whether it was downshifting or upshifting but at speeds above 50mph and higher RPM it was evident. He was pretty busy so I didn't get to ask about synchros(just to go in depth) or any other technical stuff but he said the shifter caused the problem.
#23 |
Drives: 2013 Asphalt FRS
Hate to bring it topic back up but I now started to have 4th gear grind (going from 3rd to 4th gear). But its only at high RPM. I don't beat on my car, I do like to do a little sprint driving but not beat the hell out of it. Has anyone found out if this can be fixed by the dealer?
#24 |
Drives: 2013 Raven FR-S
i have this problem and already took the car to toyota. i don't even beat on the car to get the 4th gear grind. it's in correlation to transmission speed, not engine speed. if i'm in 5th or 6th going 70 mph on the freeway and try to downshift to 4th, it grinds terribly and won't go into gear easily at all. i was told i have to wait till a special tech guy comes back into town to look at the problem, but was told i was getting a new transmission altogether
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
#25 |
Drives: 2013 Toyota 86
Alright, so I'm about 98% sure I have this issue too. In third gear, at or above 6500 rpm, I get a grind when shifting up to fourth without letting the revs fall considerably. This is not something that happens here and there but EVERY time these conditions are met.
In dubai, I have taken the car to 2 dealerships to have this issue looked at. Both took the car put for a test drive and both came back and told me that they see what I am talking about and that it is NORMAL! How could this possibly be normal? |
#26 |
Drives: 2013 FR-S Hot Lava
I have the grinding issue but with with the 2nd-3rd shift.
RPMS don't matter, shifting slow or fast doesn't matter. I can feel the teeth grinding. I can feel something pushing back. This doesn't happen on a downshift into 3rd.. Taking mine in tomorrow to have it test-driven.
Live to drive another day
#27 |
Drives: Scion FR-S
Mine grinds into 4th as well at high RPMs. Hesitant to try to take it to Toyota due to the turbo.
#28 | |
| Motul gear 300 or Redline MT90? | BRZ NA | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 70 | 11-30-2016 03:02 PM |
| Steering grind | Kregar | Issues | Warranty | Recalls / TSB | 19 | 08-11-2014 02:47 PM |
| redline | kendalldwhite | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 08-26-2012 02:12 PM |
| 3rd gear grind | Mo707 | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 07-29-2012 07:37 PM |
| Fr-s vs. Saturn Sky Redline - would your rather | Gabriel | FR-S / BRZ vs.... | 7 | 06-07-2012 12:57 AM |
