Old 05-24-2013, 02:02 PM   #1
Gixxer86
Drives: Scion FR-S (Asphalt)
What is causing this sound?
I had some suspension parts replaced in the rear on the passenger side. Now, every time i pull into a driveway or over a bump, i get a creek from the back right corner of the car as that tire goes over the bump. It only happens when just that tire is the part going over the bump. if i drive straight over speed bumps and into driveways, there is no sound at all. This leads me to believe in might be something to do with the sway bar connections on the right side..? Anyways, i didnt want to have to get under there with a torque wrench on every bolt i see, so i was hoping someone with more suspension knowledge could point me in the right direction...
Gixxer86 is offline   Reply With Quote
Old 05-24-2013, 02:16 PM   #2
OrbitalEllipses
Drives: Attitude
Because you touch yourself at night.
Mistake. Required items for working on suspension are a torque wrench and grease.
Go back, tighten everything, re-grease everything, THEN post this thread...not POST this thread then have someone tell you to tighten and re-grease everything.
Old 05-24-2013, 04:39 PM   #3
wparsons
wparsons's Avatar
What parts were replaced? Sounds like a creaking bushing that needs grease.
flickr
Old 05-28-2013, 07:59 PM   #4
Gixxer86
Basically the entire rear/right suspension. upper and lower control arms, control arm, hub assembly, e-brake assembly, tie rod, trailing arm, knuckle. the strut assembly was ok, but that whole back corner was taken apart to check for damage.
Old 05-28-2013, 09:05 PM   #5
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
I'm tempted to ask how the drifting lessons went...
Seriously though, can you recreate this sound by loading either rear corner of the car? If you can, then a helper could bounce on the car while you try to pinpoint the source of the noise and save yourself some time.
Either way, I think checking all the roll bar connections first is prudent.
The Following User Says Thank You to Ninjin For This Useful Post:
Gixxer86 (05-29-2013)
Old 05-29-2013, 02:28 PM   #6
Gixxer86
what ever could you mean?..
i tried rocking the car and bouncing that corner, but it doesnt cause the sound. I think it has to be a more sudden or harder occurrence :-/
I am thinking it has to do with the sway bar since it only happens when only the right side is compressed. if both back tires go over a bump at the same time, there is no noise. I'm going to try some spray lube on the sway bar bushings and see if that silences it. If it does, then i'll take it apart and grease it up.
Injen Intake possible causing CEL JDMrolla Engine, Exhaust, Transmission 21 09-24-2015 05:25 PM
BRZ causing sciatic pain... halp s0sl0w BRZ First-Gen (2012+) — General Topics 24 05-30-2013 10:37 PM
perrin pulley causing noise when shifting? garf Issues | Warranty | Recalls / TSB 34 04-25-2013 06:22 PM
Bluetooth causing head unit to reset? Eric1855 Electronics | Audio | NAV | Infotainment 4 01-15-2013 09:42 PM
cold weather causing windows not to go back up kidgogeta Issues | Warranty | Recalls / TSB 18 01-03-2013 11:53 AM
