Old 03-04-2013, 05:20 PM   #1
JDMrolla
JDMrolla's Avatar
Drives: AE86 and white FRS
Injen Intake possible causing CEL
I believe my injen intake is cause the CEL light to come on, took it to dealer with factory unit back in place to get in check, code said to much air intake. my question is that if i put the injen intake back on and get it tuned will it fix the issue? I did not have it tuned before.
JDMrolla is offline   Reply With Quote
Old 03-04-2013, 06:16 PM   #2
Skywgn1
Skywgn1's Avatar
Drives: 2013 Scion FR-S (manual)
I've had mine since September without a tune and have never had a CEL.. That said you might need the tune.
Customize the piss out of it and call it yours!
Skywgn1 is offline   Reply With Quote
Old 03-04-2013, 09:03 PM   #3
JDMrolla
JDMrolla's Avatar
Yeah i've had mine for quite awhile with no problems, It happened one other time as well tho, It seems to only happen after driving for at least an hour, but during a daily commute no problems,, i also have no problems with idle or anything.
Old 03-04-2013, 10:24 PM   #4
ML
ML's Avatar
Drives: 13 White MT FR-S
I have the intake and a tune and it has not gave me a light.
Old 03-04-2013, 11:23 PM   #5
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I never have any problems with mines either. How many miles have you driven with the Intake before the CEL first came up? I have a feeling you didnt clamp either the pipe that goes in the throttle body or air filter properly and letting extra unfiltered air into your system. But if you firmly believe you did, then you may need a tune for yours.
LeeMaster is offline   Reply With Quote
Old 03-05-2013, 03:01 AM   #6
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
i had the intake without a tune for a month and no CEL. got a tune and still no CEL. you may have installed it incorrectly or just got a bad unit.
l0aded is offline   Reply With Quote
Old 03-05-2013, 06:25 AM   #7
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
I had problems with bogging, CEL, and stalling because of a defective Injen intake. My second one hasn't given me an issue, even after 2+ hour trips, although I am starting to think that the car is dramatically losing power after sitting at idle for a while because of the open airbox design.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 03-05-2013, 07:15 AM   #8
mad_sb
your fuel trims got out of whack and maxed out most likely. The maf will need to be rescaled to work with the intake you have.
Unless they are using a machined billet maf housing, placement of the sensor can very a little bit from unit to unit affecting the airflow readings. On top of that some cars stack up fuel trims completely stock (mine was one of them).. add the two together and you get air flow out of range cels.
Old 03-05-2013, 10:04 AM   #9
JDMrolla
JDMrolla's Avatar
I had it on since November. I do take a lot of very short trips, always ran fine with it tho, no idle or lag issues. I was also running the cusco oil catch can, not sure if that makes difference....the unit has clean welds so i dont think the there is an issue with the unit itself. everything is clamped down good, dont see how i could do it any better......thinking im going to go with the tune, and just order a drop in for the mean time.
Old 03-05-2013, 12:18 PM   #10
mad_sb
OR you could check the fuel trims and see what is actually going on. What code was it throwing? Due to the way these cars transition from closed to open loop you can easily stack up a big fuel trim in a hurry. If you threw a code based on hitting a max or min trim just reset the ecu and monitor the trims while you save up for a tune.
Old 03-05-2013, 03:55 PM   #11
FrsSwag
Drives: Frs,civic
i dont think the injen intake needs a tune to work properly. it must not be working right. There are more threads about this with other people.
FrsSwag is offline   Reply With Quote
Old 03-05-2013, 08:40 PM   #12
welllam
Drives: STi
Need to know if your system is sucking more air in the system. If yes, that means ur system has Max out the fuel addition but still cannot compensate the extra leakage.
Tighten up all the bolts or zipties and check for leaks at tubes connecting your catch can. I had leaked before after installing air oil separator on my STi due to a busted zip ties.
Sent from my GT-N7105 using Tapatalk 2
welllam is offline   Reply With Quote
Old 03-05-2013, 10:50 PM   #13
JDMrolla
JDMrolla's Avatar
^thanks going to try all suggestions
How can I check the fuel trim, and how could I fix it, I don't have my own scanner but the dealer said the codes were P0171 and P117B
Old 03-05-2013, 11:10 PM   #14
mad_sb
P0171 is system too lean.. so you maxed out the + fuel trims. You can pickup the torque app and a cheap bluetooth obdii adapter from ebay to monitor them with.
There are a number of usb obdii adaters and inexpensive obdII software scanners for laptops.
In the end you will need a tune if you want to run the intake. Short term you can reset the ecu when the trims stack up.
Or you can order a cable and get the techstream software that allows you to do all kinds of cools stuff like customize the drl's and door locks etc as well as look at all the diagnostics etc for less than $30:
http://www.ebay.com/itm/Newest-MINI-...69e2ee&vxp=mtr
Check out my thread on the fuel trim subject
WTB: Injen intake Obja Engine, Exhaust, Bolt-Ons 3 01-10-2014 09:20 PM
WTB Injen Intake supramkivtt2jz Engine, Exhaust, Bolt-Ons 0 02-14-2013 10:34 AM
Does anyone in NE have an Injen intake 2forme New England 2 10-28-2012 05:22 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
