#407 | |
#408 | |
Enough said right there, I spent some more time in our test car today (Currently running the most recent version of the 91 non-intercooled kit.) and let me say that your first sentence sums it up quite well. Driving this car without seeing the graph, one would easily think the car makes a fair bit more power peak then it actually does due to it's amazing transient response and torque delivery. Robi has been gushing about his E85 setup, which is stronger, but let me say that the base 91 kit is no slouch either. |
| The Following 5 Users Say Thank You to mines13 For This Useful Post: | Carwhisperer (05-23-2013), Opposed (05-23-2013), roddy (05-23-2013), Sonolin (05-23-2013), Subzero (05-23-2013) |
#410 |
Drives: Black frs project
"Nothing to see here move along folks"
But I can't get this stupid smile off my face dangit |
| The Following User Says Thank You to robispec For This Useful Post: | CSG Mike (05-24-2013) |
#411 |
Drives: ~
Man, I swear I'm addicted to this thread like a soap opera. Just read through this entire thing, can't wait to see what unfolds for the Innovate kit! At this point, anyone keeping up with this thread is pretty much dedicated to this kit, right? lol
#412 |
That Guy
Drives: 2013 asphalt FRS MT
I'm dedicated to a certain amount of area under the curve. I'm still watching nameless, with their +45 ftlbs of torque in the middle of the dip and forthcoming intake manifold, itb's etc. Let alone a couple other FI offerings.
#413 | |
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#414 |
I Love custom Turbo kits
Drives: Limited BRZ
I agree. I felt the exact same way. I think for the power you want, get a turbo.
#415 | |
E46 M3.... May not have same power but has a big weight advantage... Meh, just internet armchair guesses
#416 |
Drives: '12 C63 P31, '23 GRC
If you need E85 to run with a Cayman S that is very disappointing. Cayman S is 2950lbs and 295hp. If this supercharger can't pump out 300hp (crank) on 91 octane fuel I'll be quite miffed.
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#417 |
Drives: it has 4 wheels and a motor
what's up with all this 91oct crap? why isn't anyone testing 93oct.
| The Following User Says Thank You to nonicname For This Useful Post: | ft_sjo (05-24-2013) |
#418 | |
Drives: SSM LT MT BRZ
The SC is likely capable of moving in excess of 300CFM of air, that isn't really the issue, The issue is the detonation resistance of the motor, you can't simply throw more air at a stock block and match it with fuel and expect it not to ventilate the crank case. Robi is running E85, which (more or less) offsets the lack of intercooler (he chose not to run) you can swap to a smaller pulley spin the SC faster and get the airflow, but chemistry is chemistry, 91 octane sucks compared to the 109 AKI (anti knock index) this like everything else comes down to you have to pay to play, if you want to make 150hp per liter on a high compression cast piston motor, 91 aint gonna cut it, well...not with any area under the curve, you can make a good peak number but you'll have to keep the torque (cylinder pressure) down in the low RPM's to avoid breaking stuff, SC's (proper ones with twin screws) have a direct co-relation of airflow to RPM (significantly more so than a turbo or centi-SC) so you get a similar boost at every RPM data point not an increase that looks like a parabolic curve...it's more akin to increasing the size of the motor, but stresses rise similarly aswell, this is why alot of the BIG HP cars run turbo's and not SC's, engines don't like to see double the factory torque at idle lol |
#419 | |
That's all theoretically though . Once it hits those numbers I'll definitely be impressed.
#420 | |
Drives: 2013 Black FR-S
A. Non-intercooled + E85 B. Intercooled + pump does (~250 whp). Now I want to see what C. Intercooled + E85 + 10 psi does...
| Bullet/Sprintex/Innovate on the bullet website | JoeBoxer | Forced Induction | 333 | 04-18-2013 10:07 AM |
| Still searching for an FR-S? 2 available in Little Rock | Moshpit37 | Southwest | 9 | 01-02-2013 10:32 AM |
| Bullet SC 86 | Loki556 | AUSTRALIA | 9 | 08-08-2012 01:39 AM |
| Searching Inventory in the SE | Erroneous | Southeast | 40 | 07-23-2012 04:40 PM |
