Old 05-23-2013, 06:14 PM   #1
autobrz
Drives: Mazda 3
Is it true I have to wring out the motor if I want to accelerate?
I feel like the reason why I feel like the brz is really really slow is because I'm used to driving cars that make more torque and peak power at lower rpms. I probably just need to use more throttle (because mine is auto) to get more power out of the FA20.
The annoying thing is the intake resonator makes the cabin pretty loud at high rpms. It's discouraging me from going to the high revs. I gotta plug that up, soon!
autobrz is offline   Reply With Quote
Old 05-23-2013, 06:24 PM   #2
5th 86
Drives: 2013 BRZ SPORT TECH
Thats what the stereo is there for, to hide the crappy engine sounds
5th 86 is offline   Reply With Quote
The Following User Says Thank You to 5th 86 For This Useful Post:
Enraged21 (05-24-2013)
Old 05-23-2013, 06:26 PM   #3
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Yes this is usually the cas with high revving motors ie fc20 except our cars actally make more tq down low than normal 4 bangers do
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 05-23-2013, 06:27 PM   #4
edocura
edocura's Avatar
Drives: 2013 BRZ Limited
Send a message via MSN to edocura
In general, I find the FRS/BRZ similar to a small CC motorcycle.. you just need to get the revs up to be in the power band. I don't have any experience with the AT model so I have no idea what tips there are to keep engine in the right gear/rpm but I'm sure you can find that info here.
Usually, it doesn't start waking up until 4.5k to 5K stock..
And, yes, definitely plug up the sound tube. It cost me ~ 1-2 bucks and it makes a huge difference (and the stereo sounds twice as good instantly). Plus, if you get a tune or mods, you get to actually hear the engine realistically.
edocura is offline   Reply With Quote
Old 05-23-2013, 06:32 PM   #5
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Just buy the Perrin intake tube for just over $100 bucks and delete all the junk
http://www.perrinperformance.com/brz...brz-inlet-hose
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 05-23-2013, 06:34 PM   #6
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
Yes. You have to beat the piss out of it to get it moving. "Proud of Boxer"? Ummmm...no.
Some will fall in love with life and drink it from a fountain
That is pouring like an avalanche comin' down the mountain
sho220 is offline   Reply With Quote
The Following User Says Thank You to sho220 For This Useful Post:
WolfpackS2k (05-24-2013)
Old 05-23-2013, 06:45 PM   #7
Skywgn1
Skywgn1's Avatar
Drives: 2013 Scion FR-S (manual)
You can also purchase the Dynosty sound tube delete kit. 30-40 bucks
Customize the piss out of it and call it yours!
Skywgn1 is offline   Reply With Quote
Old 05-23-2013, 06:51 PM   #8
DatApex
Drives: 2013 WRB BRZ Limited
So, just like pretty much every other performance motor, then. F1 cars make peak power at around 12,500rpm.
EDIT: Just looked it up, it's actually 19,000rpm in modern F1 cars.
DatApex is offline   Reply With Quote
Old 05-23-2013, 08:34 PM   #9
infinite012
Drives: 13 DGM BRZ Ltd
If you're coming from a V6/V8/V10/V12, you will not get used to having so little torque near idle.
If you're coming from a turbo 4 cylinder, you will be used to having so little torque near idle, but never get used to having no power up top.
If you're coming from a regular 4 cylinder, you're right at home.
infinite012 is offline   Reply With Quote
The Following 7 Users Say Thank You to infinite012 For This Useful Post:
autobrz (06-25-2013), chenshuo (05-24-2013), Eurasianman (05-29-2013), racecaresuaceb (05-27-2013), radroach (05-24-2013), sho220 (05-24-2013), slates74 (05-25-2013)
Old 05-23-2013, 08:51 PM   #10
Mitch
form follows function
Drives: RIP '13 BRZ
I downgraded on power to switch to this platform. Instead of missing the extra oomph, just enjoy the chassis for its brilliancy. Kill the sound tube if you don't like it. Fastest acceleration will come from wringing the engine out. I honestly can't think of any modern cars that benefit from shifting before redline, but I've seen it in the past on cars with restrictive intake manifolds. It's a simple calculation if you have Excel, by the way. Just need a torque curve and gear ratios (weight, tire rolling radius, coefficient of drag, and frontal area if you want to see everything, and want to compare to other cars). Reminds me I need to make a thrust chart for this car.
Mitch is offline   Reply With Quote
Old 05-23-2013, 09:08 PM   #11
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
The car I'm coming from was 4cyl 2.0t and make 288 WTQ at 3700 (peak) and makes over 200WTQ from 2,100 on. So I'm used to a 4cyl turbo that had gobs of torque near idle.
I don't regret my slowmobile, sometimes it's more fun to work hard to go fast... err I mean less slow!
Old 05-23-2013, 11:54 PM   #12
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
Hahaha, you should see how it feels up at 8k feet. It frequently feels not very fast. I'm excited to see what it will drive like at sea level.
Ganthrithor is offline   Reply With Quote
Old 05-24-2013, 12:07 AM   #13
spdfreak
spdfreak's Avatar
Drives: GBS BRZ Limited
I definitely beat on this motor more than I did my mazdaspeed6. Just to get it to move similarly in traffic I tend to get it up to 6k rpm in 1st otherwise I'll hit that torque dip in 2nd.
That's not necessarily a bad thing. It's just a different style of driving. The thing really moves when you hit those upper rpm. I swear this car rewards abuse.
spdfreak is offline   Reply With Quote
The Following 2 Users Say Thank You to spdfreak For This Useful Post:
autobrz (05-24-2013), M-17 (05-24-2013)
Old 05-24-2013, 12:54 AM   #14
Lonewolf
Lonewolf's Avatar
Drives: Moped
Is it true that I need to lubricate before I penetrate?
Some of the threads here lately...crimony
The Following 5 Users Say Thank You to Lonewolf For This Useful Post:
Ben_G (05-24-2013), edward (05-24-2013), enigma (05-24-2013), infinite012 (05-24-2013), Ingen (05-24-2013)
crimony, dry intercourse
How true is this? sav AFRICA 9 02-09-2013 05:26 AM
A Dream Come True kthxbai Scion FR-S / Toyota 86 GT86 General Forum 23 12-13-2012 09:23 AM
The true meaning behind the 86/Frs The Robot Cow Scion FR-S / Toyota 86 GT86 General Forum 34 01-22-2012 06:16 PM
is FT-86 a 2+2 or a true coupe? stlgrym3 Scion FR-S / Toyota 86 GT86 General Forum 18 11-27-2011 04:25 PM
Please be true Mouse Other Vehicles & General Automotive Discussions 33 09-15-2010 03:01 AM
