Old 05-21-2013, 06:56 PM   #1
hushypushy
ビーアールゼット
hushypushy's Avatar
Drives: WRB BRZ '18
3rd-4th gear grind...but only near redline
Tried searching...even Googled it. Found nothing.
So, one of the minor "issues" that I've already gotten over is that the transmission basically needs to be shifted perfectly in order to go in smoothly. What I mean is, a lot of cars are pretty forgiving...you push the clutch in, move the lever, release the clutch--no problem.
But with the FR-S, I feel like you really have to make sure the timing of the clutch and shift are perfect. When that's good, there's a beautiful mechanical shift as your reward...but if you do it wrong, you get a crunchy feeling as the car goes into gear.
During normal driving, my transmission is fine. I've gotten adjusted to the timing and I can drive it everywhere without a crunch. BUT! I've recently discovered it won't go into 4th gear correctly if I shift from 3rd at or near redline.
If I rev 3rd out to about 6500 RPM and then shift, I can usually (but not always) get a proper shift. But if I hold on till 7000 or later, it ALWAYS grinds. It's not always the same feeling either...sometimes it almost goes in right, and sometimes it's a nauseating crunch that reminds me of dealing with abused old Honda transmissions.
I know it's easy to blame the driver, but I assure you the problem is not with me. I can start from a roll and get nice clean shifts at redline from 1-2 and 2-3, but then I get the crunch from 3-4.
Any ideas or thoughts? I want to get some feedback to see if anyone else is experiencing this before I just take it in to the dealer.
hushypushy is offline   Reply With Quote
Old 05-21-2013, 10:16 PM   #2
Cal3000
Drives: Panda FR-S
This same exact thing happens to me. I have the Vtune and i can rev all the way to 7,800K. The higher you go in rpm, the harder the grinding sensation. To me, this is a bad design by Toyota. Let's get a recall. Soon our sycros teeth will be worn if this is to persist.
Cal3000 is offline   Reply With Quote
Old 05-22-2013, 01:19 AM   #3
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Hmmm, I have never experienced grinding at all even at 7400 rpm from 3rd to 4th, must've been a rookie who assembled your tranny.
LeeMaster is offline   Reply With Quote
Old 05-22-2013, 12:03 PM   #4
avg
Drives: BRZ Limited Manual
Me neither, I would try to have it looked at.
avg is offline   Reply With Quote
Old 05-22-2013, 12:51 PM   #5
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
I have never experienced grinding in 3rd to 4th, but then I don't often do redline in 3rd gear.
shu5892001 is offline   Reply With Quote
Old 05-22-2013, 02:22 PM   #6
Silp3
Silp3's Avatar
I have the same issue. It only happens during aggressive shifts from 3rd to 4th.
Silp3 is offline   Reply With Quote
Old 05-22-2013, 06:21 PM   #7
5AD86D
5AD86D's Avatar
Let me help you guys here...There is a Toyota Bulletin on the issue currently and we have already done one of these at my dealership. Take it to your dealer. So you know whats to be expected...they will PROBABLY end up replacing your complete transmission. The issue is with the shifter which shakes and is causing damage to your transmission because of some bearings inside the shifter(i think thats what it said lol). This bulletin DOES apply to certain VIN numbers but you all sound like you apply. I'm not at work so I cant post the bulletin but you will be taken care of. You should be fine after.
5AD86D is offline   Reply With Quote
Old 05-22-2013, 06:21 PM   #8
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
I've got this problem as well. Since day one. I've learned to take the 3-4 nice and slow and it doesn't grind. Really sucks at the dragstrip tho, especially in the 1k' because the 3-4 is just before the line with stock power levels, cant run out 3rd w/o bouncing the limiter and to shift slowly means you coast across.
Kwaziekeller is offline   Reply With Quote
Old 05-22-2013, 06:27 PM   #9
5AD86D
5AD86D's Avatar
It's more prevalent on the FR-S's purchased closer to first release.
Old 05-22-2013, 10:53 PM   #10
Kwaziekeller
hmmm... wanna say I'm 934 lol (too lazy to walk to my car and look at the VIN)
Old 05-22-2013, 11:10 PM   #11
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
can someone post the bulleting i get 3rd gear grinds at normal daily driving
Old 05-22-2013, 11:46 PM   #12
NickFRS
Drives: 2013 Asphalt FRS
there is a TSB for this???
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 05-22-2013, 11:50 PM   #13
oTaGGeDo
oTaGGeDo's Avatar
Drives: Currently driving a 2013 turbo Tc
Please post the tsb
oTaGGeDo is offline   Reply With Quote
Old 05-22-2013, 11:54 PM   #14
#87
I usually post drunk
#87's Avatar
I've grind it a couple times but I'm pretty sure its just me not have the clutch fully depressed and not a design issue. 3 -> 4 is a short shift so I think it just have to pay more attention and maybe be faster.
#87 is offline   Reply With Quote
Motul gear 300 or Redline MT90? BRZ NA Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 70 11-30-2016 03:02 PM
Steering grind Kregar Issues | Warranty | Recalls / TSB 19 08-11-2014 02:47 PM
redline kendalldwhite Scion FR-S / Toyota 86 GT86 General Forum 5 08-26-2012 02:12 PM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 07:37 PM
Fr-s vs. Saturn Sky Redline - would your rather Gabriel FR-S / BRZ vs.... 7 06-07-2012 12:57 AM
