Old 05-20-2013, 07:54 PM   #29
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
If the rack is electronic why can't we use something like ecutek to modify it to make it a stiffer feeling?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 05-20-2013, 08:17 PM   #30
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
There is a difference between "stiffness" (or steering effort) and feel.
Old 05-20-2013, 08:21 PM   #31
Captain Snooze
Drives: Red Herring
Originally Posted by EarlQHan View Post
but that's the only difference between the 991 911 and GT3's steering.
I beg to differ.
Different tyres, bushes and springs. I'm not sure about the suspension geo.
Originally Posted by wparsons View Post
I rolled mine out of a driveway without starting it and it's WAY tougher to steer than any other car I've ever owned rolling out of the same driveway.
This.
Maybe these solid steering rack bushes would assist:
http://turninconcepts.com/product_in...oducts_id=1260
http://turninconcepts.com/product_in...oducts_id=1270
Review for the aluminium bushes here:
http://www.ft86club.com/forums/showthread.php?t=27727
Old 05-21-2013, 12:11 AM   #32
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
TiC steering rack bushings do help give the car more feel of what the tires are doing...I just installed mine this weekend that I purchased from the initial group buy many months ago. Really wish I had done so sooner! Running the stock tires slightly stretched on lighweight Enkei Fujins (17x7.5 with +40mm offset) and I love how the handling is now more than ever with the bushings installed. I notice that there seems to be more front negative camber as well, which is reasonable due to the fact that the steering rack is slightly higher than it was with the stock rubber bushings - slightly pushing the tie rods up and out more. Front camber seems much closer to what the rear suspension is (with completely stock suspension/ride height.) Really makes the turn in superb and so precise in comparison to stock...
Personally, 'tire feel' is not a big deal to me, as long as the chassis is communicating the tire grip and car balance that's all I really want. That said the FRS has plenty of tire feel to me with the stock tires.
You'll need to get rid of all the isolating elements from the between the tires and steering rack if you want to feel the tires to the maximum potential of the vehicle - which means replacement of factory rubber bushings with stiffer, more rigid materials. Front control arms with spherical bearings would be the extreme way to go all out and reduce isolation points to the absolute minimum - making as direct an energy pathway from the tires to steering wheel as possible. A well engineered chassis bar would probably help out some as well.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 05-21-2013, 01:55 AM   #33
s2d4
s2d4's Avatar
I think everyone's overthinking this and you're not utilizing what's already there. The cleanest and best way to improve feel is to hack the PS ECU and change the algorithm. Now, how hard or easy this is is anybody's guess, but that's the only difference between the 991 911 and GT3's steering. Same rack, same PS motor, just a different setting.
I was under the impression that the 86 has the icky fluids at the time. but you mentioned changing algorithm to me in the past and a basic google search came up with this.
http://www.autospeed.com.au/cms/A_111532/article.html
It is basically is a piggyback setup and one can tailor it to what they want, not that hard to do either.
Ultimately it isn't really what I was after, I really wanted the full lock-1 turn so the suggestion of machining a new rack and pinion is a much better option.
Old 05-21-2013, 12:27 PM   #34
EarlQHan
Drives: Subarus
I beg to differ.
This.
I meant in terms of the rack. Those should help make the steering effort more direct and may improve feel, but the electric motor does damp small impurities in the road and to change the level of damping the electric motor provides will need to be done at the PS unit.
For quicker steering, you definitely need a new rack with a different gear ratio. This typically does make the steering heavier since there is more torque required at the steering wheel, but I wonder if the electric PS can compensate leaving the feel the same. Or if there's the possibility of overloading the motor and burning it out. I don't know and I don't think it will be an issue, but just something to ponder.
EarlQHan is offline   Reply With Quote
The Following User Says Thank You to EarlQHan For This Useful Post:
s2d4 (05-21-2013)
Old 05-21-2013, 12:55 PM   #35
wparsons
wparsons's Avatar
The manual already states that the motor might overheat and increase steering effort in hot weather and lots of low speed driving with lots of steering, decreasing the ratio in the rack by about 30% (stock it's 1.5 turns from center to lock) will probably put too much load on the motor.
flickr
Old 05-21-2013, 01:47 PM   #36
s2d4
s2d4's Avatar
Part of the R&D and testing of course.
The quaife kit for AE86 and the AW11 is actually the same, sell like hot cakes worldwide... If you guys do one, I would buy it.
Old 05-21-2013, 04:34 PM   #37
Trettiosjuan
Drives: GT86
Is it possible that the rack is stiff when brand new? Perhaps explaining my relative disappointment compared to other testimonies?
I had another car that had this effect, not much feel in the beginning, after 6000miles or so, it loosened up and really started talking to me...
Trettiosjuan is offline   Reply With Quote
Old 05-22-2013, 05:41 AM   #38
Xauterus
Drives: GTS 86 Galaxy Blue
I think you will find a big difference once you change to stiffer springs. A bigger front sway bar will also sharpen the steering feel. I have just got the whiteline rack mount bushes and look forward to see how much they sharpen the feel along with the perrin lower arm bushes.
As I understand the engineering of the front lower arms they wanted the car to basically under steer in initial steering then by making the bush flex it turned in better. Changing that bush should make a difference to that initial turn in softness you may be feeling.
Xauterus is offline   Reply With Quote
Old 06-03-2013, 09:14 AM   #39
koevasi
koevasi's Avatar
Drives: 1
Could you please expand on this a bit more? I thought the sizing, etc. was identical? Mine's being shipped over at the moment and hopefully I can do the install this weekend.
koevasi is offline   Reply With Quote
Old 06-03-2013, 09:22 AM   #40
Trettiosjuan
Drives: GT86
Steering rack/rod geometry has no influence on camber, only toe in various flavours (different dynamoc situations). Let us know how the upgrade feels!
Old 06-03-2013, 10:00 AM   #41
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Hej 37:an, tjänare! :-)
Are you still basing your judgement on that single test drive?
I would seriously consider doing another, in a GT86 with at least 5000km on it.
I am saying this because in my case, the steering wheel "feel" has either improved a lot or I have become more attuned to it.
Basically, I love the way my 100% stock GT86 talks to me. It's a beautifully engineered car IMHO.
The Following User Says Thank You to Sarlacc For This Useful Post:
PowderfaceTr. (06-16-2013)
Old 06-03-2013, 02:59 PM   #42
Trettiosjuan
Drives: GT86
Tjena
Actually I did already and it didn't bother me as much as before. So now I think I will be happy with a stock set-up! I guess one will adapt, I also suspect it was because the first car was so new it was a bit stiff, the latest one had some miles already, bit hard to tell for sure...
Although I would want to try the steering rack bushings, seems too easy mod to not try...
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 04:41 PM
Feel sorry for guys in LA Pscylo Southern California 16 08-21-2012 11:26 AM
does rwd LSD feel the same as fwd lsd? pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 07-13-2012 09:04 PM
Steering Wheel Feel ap5512 BRZ First-Gen (2012+) — General Topics 8 12-08-2011 12:16 PM
Stock suspension adjustability? #87 Scion FR-S / Toyota 86 GT86 General Forum 4 01-02-2010 05:36 PM
