AVOturboworld
Old 05-16-2013, 02:41 AM   #2521
nix
nix's Avatar
Drives: AVO BRZ
How's the injectors working out ?
What clutch do you have ?
Injectors are going great after Simon calibrated everything. Clutch is a stage 2 pressure plate from ACS extreme, with a stage 1 floating organic disc.
Haven't looked at fuel pump pickup stuff yet, also a lot of racerom stuff to be worked out.
nix is offline   Reply With Quote
Old 05-16-2013, 02:46 AM   #2522
sw20kosh
Drives: 2013 Black FR-S
Nice fuel and results!!!
However i am still confused by your 14% statement... your 365 bhp would be what whp here in the US? Your 165 bhp would be what whp? 144 whp?
Old 05-16-2013, 03:42 AM   #2523
nix
nix's Avatar
Drives: AVO BRZ
Originally Posted by MSTiFK8R View Post
Good numbers!
which 98ron limits could you estimate based on your experience - psi\bhp-wise?
It should be knock-warning, right? meaning you can't go any further without a risk
I haven't seen much of the data yet. We didn't push 98 ron much above 10psi but up to that it was fine on normal timing. Maybe 300 whp in "nix badly converted americaland numbers".
It doesn't mean damage can't occur I'll leave it to the vendors/tuners to predict that!
Yeah I think everyone is!! Maybe I should have listed everything in DD rwkw. I just did very rough conversions to dynojet WHP to make it clearer for you guys.
The proper conversion is
1 kw = 1.341 hp
Dyno dynamics shoot out mode baseline = 108 rwkw = 144 whp
Dynojet conservative baseline = 165 whp (the one on front page is 168)
so dd rwkw x 1.341 = dd whp x 1.146 = dynojet whp
Old 05-16-2013, 03:47 AM   #2524
ft_sjo
Drives: GT86
Originally Posted by nix View Post
So in American terms I'd put the limit of the avo stage 2 hardware, with stock airbox and 2.5" exhaust at approx 400 whp
~460-480bhp on a 2.5" exhaust?
Old 05-16-2013, 03:48 AM   #2525
nix
nix's Avatar
Drives: AVO BRZ
Here's a quick snap of our final number for now at around 1 bar.
Over twice stock power or around 380 whp on a dynojet.
I'll get some full sheets, boost curve etc at a later date.
The Following 2 Users Say Thank You to nix For This Useful Post:
Sonolin (05-16-2013), Sportsguy83 (05-16-2013)
Old 05-16-2013, 04:54 AM   #2526
corvino26
corvino26's Avatar
Drives: 2013 Scion FR-S 6MT Raven
I am very excited about this kit but I do have some concerns like...
1) has anyone had any problems over heating on a daily driver since the intercooler basically block all the air flow to the radiator?
2) I don't like silicone piping and would like to have aluminum piping so is there hard intercooler piping available for this kit?
3) is it possible to put the hks ssq bov or greddy type rs bov on this kit?
4) is there a way to do away with the stock air box and pipe straight to the throttle body?
5) is this kit catless?
6) has anyone been getting a check engine light?
Any and all help is always appreciated...
Thanks in advance
corvino26 is offline   Reply With Quote
Old 05-16-2013, 05:14 AM   #2527
s2d4
s2d4's Avatar
fuel caltex e85, which is reading approx 72% here in winter time.
That is pretty crap e85 fuel.
Can you also tune for the lab/race grade e85? The % will never be that far off plus it will be mixed with bp98 instead of caltex 98, grab a couple of 200l drums, that would be the true power ceiling for e85
Old 05-16-2013, 07:06 AM   #2528
nix
nix's Avatar
Drives: AVO BRZ
Yeah we can use sucrogen e85 drums for all out power runs but the goal here is a daily driven legal, emission friendly tune so it was different blends of local pump fuels, bp98, united e85 and the crappy caltex.
The Following User Says Thank You to nix For This Useful Post:
Old 05-16-2013, 07:11 AM   #2529
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thanks in advance
1) I have done several passes back to back, and the Water temp. has not gone past 205 F
2) It's only silicone piping available at this point. It works pretty good.
3) I'll let Paul answer that one. I believe depending on how the BOV connection, you might need to weld a plate.
4) Yes, I have the Perrin CAI and it fits perfect with the kit.
5) Yes, the manifold is catless but you can still keep your secondary cat in the frontpipe.
6) No CELs.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Draco_PR23 (05-16-2013)
Old 05-16-2013, 07:51 AM   #2530
s2d4
s2d4's Avatar
I know what you are saying, I was specifically referring to your estimates on what the power ceiling could be for e85 hence that particular comment.
Old 05-16-2013, 01:02 PM   #2531
AVOturboworld
It doesn't totally block air flow to the radiator, air flows through the intercooler and then to the radiator. One of the major reasons for the dimensions of our FMIC was to balance charge cooling vs. air flow to the radiator. In a daily driver you won't see overheating issues. Even when we were climbing passes in Nevada we saw no issues, even with the a/c running.
No, we don't have a aluminum piping option. The silicone is wire reinforced, and will not burst under any pressure you can theoretically put through that engine. It's not the cheap 3-ply silicone that has given silicone a bad name.
Anything is possible, but you'd probably have to weld a flange in to do it.
It is possible to do away with the stock air box, but I'm unsure what you mean by second part.
The kit replaces the entire stock exhaust manifold, which removes that cat. The secondary cat is left in place - everything after the header can be left completely stock.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
Draco_PR23 (05-16-2013), Sportsguy83 (05-16-2013)
Old 05-16-2013, 03:41 PM   #2532
sw20kosh
Wow this is amazing results for this kit!!! 380 whp on E85 (E70)... And it spools quick!
Old 05-16-2013, 07:53 PM   #2533
Sonolin
Yea very nice dyno graph!
Sonolin is offline   Reply With Quote
Old 05-16-2013, 07:58 PM   #2534
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
@AVOturboworld
I'm really interested in your response, i bet you guys are amazed the kit managed to do this or were you expecting such numbers from E70+ ?
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
