Old 05-13-2013, 10:29 AM   #57
nix
nix's Avatar
Drives: AVO BRZ
What do you think about another pickup on the other side, or using a pump to equalise the 2 sides without going return?
nix is offline
Old 05-13-2013, 10:35 AM   #58
vgi
Drives: frs
Originally Posted by Don@Accelerated View Post
I'm sure atleast one of them has run into this. I seem to recall FBM using some kind of surgetank setup last year for something.
I think its pretty safe to say i'm the only one daily driving around at 600hp unless someone wants to prove me otherwise!
Well, Visconti's posted number of 250whp is pretty low. A lot of stage1 kits hit this number.
vgi is offline
Old 05-13-2013, 10:37 AM   #59
vgi
Drives: frs
@SmsAlSuwaidi @Visconti: thanks guys.
So let me just wrap my mind around it: it looks like the problem has been noticed before but no one besides Don cared to dig down to the root cause either ignoring the problem or hacking ecu with injector open time hoping this is good enough to keep fuel flowing. Did I get this right?
I understand the smaller shops may not have had enough resources, but the big game players' extensive R&D and claimed cumulative mileage with the cars running their kits - were all their tests and claimed cumulative testing mileage done on full tank and/or dyno running only? Sorry for raving, still trying to get this into my head
vgi is offline
Old 05-13-2013, 10:40 AM   #60
Don@Accelerated
Don@Accelerated's Avatar
@250whp he's referring to the guys that SCCA or Road Race having those issues.
We had that issue last year and kept writing it off as a software issue or ABS or Traction Control kicking on.
I didn't look into the the issue until I had a fuel volume problem for the HP. If you kept a full tank always, I doubt you'd have that issue because fuel floods through the top of the plastic housing.
Don@Accelerated is offline
The Following User Says Thank You to Don@Accelerated For This Useful Post:
Sportsguy83 (05-13-2013)
Old 05-13-2013, 11:19 AM   #61
vgi
Drives: frs
yeah, sorry again. I'm just seeing recommendations for big name's FI kits because they are supposedly have been extensively tested and proved themselves... yet shops like AP (kudos to Don) are truly the ones testing the limits.
vgi is offline
Old 05-13-2013, 11:40 AM   #62
Xdragonxb0i
Drives: ex500r
Seems like it would be easier to replace the gas tank. And Remove the hump
Xdragonxb0i is offline
Old 05-13-2013, 11:52 AM   #63
vgi
Drives: frs
or if space allows it, connect both sides underneath with a fat enough hose/pipe and let gravity do its job. although that would cover only side-to-side issue
vgi is offline
Old 05-13-2013, 12:50 PM   #64
Don@Accelerated
and make it front wheel drive!
The Following 3 Users Say Thank You to Don@Accelerated For This Useful Post:
Calum (05-13-2013), DriftEightSix (05-13-2013), sw20kosh (05-13-2013)
Old 05-13-2013, 02:54 PM   #65
sw20kosh
Drives: 2013 Black FR-S
lmao
lets remove the hump!!! errr...
sw20kosh is offline
Old 05-13-2013, 05:30 PM   #66
vgi
Drives: frs
or mid-engined . i thought what he meant tho was making custom tank with possible relocation. doubt tho it would be easier than a 3 pump setup
vgi is offline
Old 05-13-2013, 07:33 PM   #67
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
If I recall right there is a member on here.
He has a video of a particular corner set where he's floggin through.
Had the same symptom almost every time in that particular spot.
Don't know if they figured it out but, ABS, TCS, and/or VSS was their assumed perp.
He was Stock Power.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline
Old 05-20-2013, 09:51 AM   #68
Don@Accelerated
We ever find this video?
Old 05-20-2013, 10:13 AM   #69
M1K3
M1K3's Avatar
Drives: vrooom...
Don here is the Thread about the issue: Engine cutting power after hard cornering...
M1K3 is offline
Old 05-20-2013, 02:14 PM   #70
dabocx
dabocx's Avatar
Drives: Scion FRS
Anyone have a picture or diagram of the stock fuel tank? Curious to see how its shaped
dabocx is offline
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 11:00 AM
FRS Fuel System Component Walkthrough DeatschWerks Engine, Exhaust, Transmission 8 09-21-2012 01:09 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 06:03 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
Deatschwerks BRZ Fuel System Review xwd Engine, Exhaust, Transmission 0 08-11-2012 04:47 PM
