Old 05-10-2013, 06:22 PM   #295
Kodename47
Kodename47's Avatar
Drives: UK GT86
@vtmike here's the results. All done in 1 hour, same map (Litchfield tune), same roads and each individual pull done at the same part of road. 2x 3rd gear and 1x 4th gear full throttle pulls. Closed is with the main resonator hole blocked, resonated is with the main resonator in use, open is with the hole open into the engine bay. The stock snorkel is in use.
MAF:
AFR:
MAP:
What this does show quite clearly is that, even with the same airbox and MAF location, changing something as small as the resonator impacts on the airflow readings. This can be seen in certain areas and the resultant AFR changes. It's clear that no more air is being used, yet some areas are leaning out and that correlates with lower MAF readings. TBH, I included the MAP graphs but I'm not 100% sure how to interpret them.
I'm yet to determine whether the ECU could learn and adapt to these changes which are really visible in the range I mentioned previously. Obviously a remap for each config would mean that the hesitation I was experiencing would go away (like @NickFRS), but I'm not sure that any particular config is "best" for performance. I also don't seem to lose any noticeable sound through using the resonator.
I've been temped to design a 2nd feed (or snorkel if you will) that uses the resonator port and snakes across the bay to a cold air pocket but again, I fear that this may not gain much, if anything.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 3 Users Say Thank You to Kodename47 For This Useful Post:
Imrac (05-02-2016), leicaboss (02-11-2014), Teseo (03-01-2024)
Old 05-11-2013, 12:00 AM   #296
NickFRS
Drives: 2013 Asphalt FRS
After my tune it sounds like I have a CAI under the hood. I'll have someone take video tomorrow. And yea my car was running rich before the tune. But now everything looks good after the custom BRZedit protune. wrapped my header a bit ago and installing it tonight. I'm getting retuned on wed now. I'll get some data.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 05-11-2013, 09:55 AM   #297
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Looks to me like the dip in, which would be initial hesitation is affected but that after that the differences are just noise.
Would make sense that the resonator would act as an air resivour and affect off throttle response. But not overall power.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 05-11-2013, 10:00 AM   #298
StormTrooper
@Kodename47
I removed mine for visual and under hood clutter... Same thing with the inlet tube , getting rid of the sound generator gayness was a priority.
GR86 MT premium
Old 05-11-2013, 10:42 AM   #299
vtmike
vtmike's Avatar
Drives: Scion FR-S
Looks like resonated is the best option.
vtmike is offline   Reply With Quote
The Following 2 Users Say Thank You to vtmike For This Useful Post:
ddevl_86 (03-31-2021), why? (01-31-2017)
Old 05-11-2013, 02:25 PM   #300
Kodename47
Kodename47's Avatar
Drives: UK GT86
Probably, yes. Looking at the MAF graphs, it's interesting to see where "noise" is generated depending on what config. The resonator seems to be a fine middle ground. Having it open to the bay is very noisy sub 2.5k but then seems to be the smoothest line, having a closed box seems to be similar, except the noise is 2.5-3k. Both cause the MAF to read lower though so may need MAF adjustment on the ECU. I may go ahead with my plans and see what happens.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-11-2013, 03:35 PM   #301
vtmike
vtmike's Avatar
Drives: Scion FR-S
I recently ordered the trd intake. I'm hoping it provides more accurate maf readings and seems to make power and torque throughout the entire powerband while increasing throttle response. Not to mention it removes the resonators.
Old 07-10-2013, 12:03 PM   #302
robispec
Drives: Black frs project
Sure are alot of nice options here!
robispec is offline   Reply With Quote
Old 01-20-2015, 03:16 PM   #303
vien
Drives: subaru brz
any updates?
vien is offline   Reply With Quote
Old 10-26-2016, 06:45 PM   #304
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
airwaves are probably colliding
the resonators likely help with the airflow
IMO, its best to remove the sound generator with Perrin silicone tube and a drop in; this should improve the noise and throttle response (slightly)
there is a lot of engineering that goes into design.
neilvosko is offline   Reply With Quote
The Following User Says Thank You to neilvosko For This Useful Post:
Old 03-30-2020, 06:11 AM   #305
gpvecchi
gpvecchi's Avatar
Hallo, sorry to re-up the thread, but during these years there had been many tests.
It seems that snorkel mod gives some gain, but main resonator?
Did someone tested the Apex'i Intake D Plus? Many Japanese people use it. I even found that airbox intake is quite restricted...
Old 03-31-2021, 02:34 AM   #306
ddevl_86
theddevilinme
ddevl_86's Avatar
Drives: 2013 Scion FRS [H8R]
Proven by Mishomoto with these fine words:
https://www.ft86club.com/forums/showthread.php?t=61621
"Utilizing the Mishimoto induction hose and a high-flow panel air filter, and with the noise amplifier removed, we were able to gain 6 horsepower and 3 torque over the all-stock setup. We also saw a loss in power with the resonator removed, so the resonator should be retained if you are using the factory airbox setup."
Trust the engineers, they know stuff. And just to beat a dead horse, its your car - do what you want.
Additionally, after reading 27 pages of comments on if removing the resonator box is beneficial or not, it is my final conclusion that you lose some power in the lower rpms, and is not a great mod if you drive in that range.
However, if you dont mind a bit of power loss (ha) but want a cleaner engine bay, cap it off. I'd only do so to show my sweet red Perrin light weight crank pulley. Who needs a giant black box blocking that view!? Now if I only didnt also read 13 forum posts and 100 comments on light weight pulleys and their benefits, or lack thereof... glad I didnt buy into the hype.
We're all just living to die - might as well enjoy the ride!
ddevl_86 is offline   Reply With Quote
Stock resonator removal? jm1681 Engine, Exhaust, Transmission 33 10-11-2019 06:58 PM
MT Stock Shift Knob, Stock Intake w/Snorkel Vicious LED Interior Parts (Incl. Lighting) 1 02-09-2013 03:14 PM
Length of stock resonator? jm1681 Engine, Exhaust, Transmission 5 10-26-2012 07:25 AM
WTB Stock OEM Airbox/snorkel brichard0625 Engine, Exhaust, Bolt-Ons 1 10-20-2012 09:21 AM
WTB: Stock AirBox SkullWorks Engine, Exhaust, Bolt-Ons 1 08-15-2012 09:09 AM
