Old 05-07-2013, 11:14 AM   #43
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
There is an octane booster at Canadian tire that boosts the octane level 6 numbers or 60 points that will get you back to 93.
http://m.canadiantire.ca/mt/www.cana....jsp?locale=en
Gords_zenith is offline   Reply With Quote
Old 05-07-2013, 01:08 PM   #44
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by sierra View Post
It's strange that many people spend a lot of money on this car to increase the performance yet some are defending using cheap fuel as being of no consequence to the performance or longevity of the engine..
It isn't of consequence because automakers figured out 20 years ago that if they don't prepare for that kind of idiocy engines will fail and the ensuing shit-storm is damaging to their reputation.
Sensors detect knock; timing gets pulled, knock reduces, repeat until no knock occurs. Loop.
Is there some damage to the engine? Possibly. Is it going to explode over the next 200,000 miles of regular driving if taken care of properly? Highly unlikely. Engines are designed to be tough and withstand the modern driver, stop fear mongering and start learning.
Edit: Personally I do not trust additives, at best snake oil that does no damage, half a tank won't hurt anything, I'd put 100 bucks on 10k miles of regular gas not hurting anything either.
ineedyourdiddly
Vic4uf (10-30-2017)
Old 05-08-2013, 11:30 AM   #45
Richard Cranium
Ted
Drives: Raven FR-S
So what say you to the people in the Midwest that only have access to 91? 93 pumps are *extremely* rare in Nebraska and Iowa and most of the ones that are 93 are E10.
2013 Scion FR-S - Sideways and Smiling
Bone-yard: 2010 Toyota Tacoma, 2008 Honda Civic SI, 2002 Audi A4 1.8T Stage 3 K04, 1999 Honda Civic SI
Richard Cranium is offline   Reply With Quote
Old 05-08-2013, 11:32 AM   #46
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
your engine will adjust
it won't perform at its peak efficicency but it's not going to die either.
Old 05-08-2013, 02:18 PM   #47
WRXGuy1
WRXGuy1's Avatar
Drives: 2013 WRB BRZ Premium 6MT
Dealers don't even seem to realize these cars need premium gas. When I got mine I said to the salesman as he was leaving to fill it up "you're putting in 93 right?" and he replied "These cars need 93"?".
2013 BRZ Premium WRB MT - Picked up 5/31/12
WRXGuy1 is offline   Reply With Quote
Old 05-11-2013, 01:39 AM   #48
Grymm86
Grymm86's Avatar
Drives: BRZ Limited DGM
Diesel pump shouldn't fit into the receiver on the gas tank.
shouldnt, but it does.
Grymm86 is offline   Reply With Quote
Old 05-11-2013, 01:55 AM   #49
g0lden
Drives: 2013 Scion FR-S Argento
dilute the 87 and top the car off with 93. Take it easy and keep your foot out of the gas until next fill-up.
g0lden is offline   Reply With Quote
Old 05-11-2013, 04:21 AM   #50
Khánh
Khánh's Avatar
Drives: sc00ter
I've been driving around with 91 since my first fill-up... premium here in Cali is 91...
Khánh is offline   Reply With Quote
Old 05-11-2013, 04:46 AM   #51
jstans84
Drives: Scion FR-S
Go to the nearest airport and have them fill the rest of the tank with jet fuel. That will combine with the regular octane and even out to between 91-93.
jstans84 is offline   Reply With Quote
Old 05-11-2013, 07:04 AM   #52
sierra
Drives: Skoda Yeti DSG diesel 4x4
If you want to completely stuff your engine put in jet fuel[Avtur] which is a kerosene type fuel more like diesel than petrol/gasoline.
I think you meant aircraft piston engine fuel or Avgas which is high octane petrol/gasoline.
sierra is offline   Reply With Quote
Old 05-11-2013, 07:25 AM   #53
Nezz
86DESU
Nezz's Avatar
Drives: 86 GTS, S13, CB9
Ooh, jesus. Yeah, AVGAS LL110 or UL105 if you can get that instead. Don't put the full leaded shit in there. And jet fuel is a fantastic way to mangle car engines.
Careful. It's contagious!
Nezz is offline   Reply With Quote
Old 05-11-2013, 07:26 AM   #54
Nezz
86DESU
Nezz's Avatar
So run E10? Only way I can get 100 octane is E10. No chirping for me, either.
Old 05-11-2013, 07:58 AM   #55
CSI:86
86 = First New Car
Drives: 2013 Pegasus White Toyota 86 GTS MT
The pinging is just detonation. Your ecu will detect this and pull timing thus reducing horsepower. I have accidentally filled up with 95RON/91AKI on a really early morning and redlined it to get to work quickly at almost every stoplight. On the drive home, it was pinging. So i drove gently and brought 2 bottles of octane booster and filled up with 98RON/93AKI. And the pinging was gone almost instantly after.
There should be a sign on the fuel cap that say something like "PREMIUM 98RON FUEL RECOMMENDED"
CSI:86 is offline   Reply With Quote
Old 05-11-2013, 08:27 AM   #56
sierra
Just detonation!!! Detonation is what melts pistons.
If you can hear it then it's outside the range of the knock sensors because they will detect it and adjust before you can hear it.
I'm surprised that 95RON made it pre-ignite because the book does say it can be used if 98 is unavailable but 98+ is what it's tuned for. 98 RON only on the filler cap, so I don't know how they can sell it in US states with only 91AKI available?
Be careful using octane booster. I think it can damage the catalytic converters?
Downforce: you're doing it wrong. ATL BRZ Cosmetic Modification (Interior/Exterior/Lighting) 28 04-12-2013 02:31 AM
What's wrong with my HID kit? seven Cosmetic Modification (Interior/Exterior/Lighting) 17 11-28-2012 08:36 PM
am I doing something wrong? shiud Scion FR-S / Toyota 86 GT86 General Forum 20 07-17-2012 06:21 PM
Was I in the wrong? D4ng3r Off-Topic Lounge [WARNING: NO POLITICS] 18 06-15-2012 02:46 AM
Wrong Fuel Hawx AUSTRALIA 22 12-11-2011 07:08 PM
