Old 05-06-2013, 07:53 PM   #239
SteveH
Drives: 2013 FR-S Whiteout 6MT
Had the dealer service the oil leak two weeks ago. I've only put about 300 miles on the car because of all the rain the last couple of weeks, but no leaks yet. The plate feels like it was totally degreased, so maybe carefully degreasing both surfaces is the key to getting good adhesion of the sealant.
SteveH is offline   Reply With Quote
Old 05-09-2013, 03:11 PM   #240
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
2013 BRZ 6MT
Build Date: 3/23/2012
Current Mileage: 15,000
Recently started smelling burnt oil. Right Rear cam plate, dry as a bone. Front timing cover (passenger side), not so much. Pics to come...
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 05-09-2013, 08:42 PM   #241
Opie
Opie's Avatar
Dry rear cam plate:
Wet lower front timing cover:
Old 05-09-2013, 11:17 PM   #242
NickFRS
Drives: 2013 Asphalt FRS
hmmmmm going to check my car in a few
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 05-16-2013, 01:41 PM   #243
Raceseng
Raceseng's Avatar
We could cnc machine a plate with a dual viton o-ring grooves. I'm going to check our car to see if we are having the same problem.
Please respond if you would be interested in a billet aluminum cam plate. Thanks!
Raceseng is offline   Reply With Quote
The Following 3 Users Say Thank You to Raceseng For This Useful Post:
charged86 (06-02-2013), Clipdat (05-16-2013), Marrk (05-17-2013)
Old 05-16-2013, 01:55 PM   #244
Blu-Steel
Drives: 2013 FR-S, Black 6 Speen Manual
I am interested.
Blu-Steel is offline   Reply With Quote
Old 05-16-2013, 02:05 PM   #245
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
OMG, yes please!
Originally Posted by humfrz
I'm old and lazy
Old 05-16-2013, 02:45 PM   #246
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
interested for sure.
sure74 is offline   Reply With Quote
Old 05-16-2013, 02:49 PM   #247
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
Originally Posted by norsamerican View Post
Let us know what you find out.
About a month later and a few hundred miles (one decent expressway trip and quite a bit of around town driving) my plate is still clean. Fingers crossed it's fixed for good.
Chimpo is offline   Reply With Quote
The Following User Says Thank You to Chimpo For This Useful Post:
norsamerican (05-16-2013)
Old 05-16-2013, 04:17 PM   #248
Raceseng
Raceseng's Avatar
No oil leaking from our car but I only have 2,000 miles on it. It appears our plate has a large bead of silicone around the whole perimeter. We have the plate off and are going to see if an o-ring solution will solve the problem.
Old 05-16-2013, 06:32 PM   #249
Dezoris
Dezoris's Avatar
Please develop something, as a flat plate with silicone will eventually leak as the seal is not something designed to last. All manual trans cars will eventually seep from here. Its not a matter of if its when. Constant expansion/contraction of the silicone, vibration along with 200F oil constantly flowing to bottom of plate will eat away.
This is an easy $75 per plate for you that most anyone will buy until OEM TSBs it with a new part.
The Following User Says Thank You to Dezoris For This Useful Post:
Old 05-16-2013, 06:35 PM   #250
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
Dealer cleaned the plate off last week I'm keeping an eye on it.
Old 05-16-2013, 07:11 PM   #251
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
My opinion is that it's the gasket between the two halves that provides the leak path. You can see it in the factory sealer.
Old 05-16-2013, 08:08 PM   #252
Lonewolf
Lonewolf's Avatar
Drives: Moped
If Toyota can't figure this out soon enough, I would be interested...
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 04:41 PM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 05:43 PM
Leaking front left shock Xauterus AUSTRALIA 10 11-06-2012 05:15 PM
Tires keep leaking EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-29-2012 04:03 AM
Brake Light Leaking Covered in Condensation Smokinbuffalo BRZ First-Gen (2012+) — General Topics 9 06-12-2012 05:43 PM
