Old 05-06-2013, 03:40 PM   #1
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
EcuTek racerom feature help
i got my car flashed today and autoblip works perfectly, as did flat foot shifting at 1st. i made a stop and when i started back up now it just revs like crazy when i try it as if it's gone (yes i'm on the correct map). any idea whats up? am i just doing it wrong and was lucky at 1st?
lbroskee is offline   Reply With Quote
Old 05-06-2013, 03:42 PM   #2
CBR600RR
Drives: Raven Black
I think flat foot shifting only works above 4000 or 5000 RPM
The Following User Says Thank You to CBR600RR For This Useful Post:
lbroskee (05-06-2013)
Old 05-06-2013, 03:46 PM   #3
lbroskee
lbroskee's Avatar
ah ok, well that would b the issue then. ill have to test it out later (still need to figure out launch control too)
Old 05-06-2013, 06:40 PM   #4
CBR600RR
Drives: Raven Black
For launch control; make sure you are on the righ map.
Then make sure the car is stopped in neutral and your foot is off the clutch. Then push in the clutch, put it in first gear, them floor the throttle. Adjust the rpm with the cruise control stalk.
Oh and make sure the traction control is off.
Old 05-06-2013, 06:56 PM   #5
lbroskee
lbroskee's Avatar
that last part is what i was missing thanx. so as a map feature u wont burn clutch because i could smell it when i tried it without a tune?
Old 05-06-2013, 09:09 PM   #6
wparsons
wparsons's Avatar
If you ride the clutch it won't matter what map it's running on, you'll still smell burning clutch.
flickr
Old 05-06-2013, 10:33 PM   #7
lbroskee
lbroskee's Avatar
Well higher rpm didnt make a difference on flatfoot. Any idea @FA20Club.com?
Old 05-08-2013, 12:13 AM   #8
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
flat foot worked for me when i did the 1/4 , although the launch control doesn't work after you do a burnoout. which sucks
Scalzo is offline   Reply With Quote
Old 05-08-2013, 12:14 AM   #9
lbroskee
lbroskee's Avatar
for that i was told to remove the neg terminal from battery and it fixes it somehow
Old 05-08-2013, 12:29 AM   #10
86pro
Drives: frs
for me i use the cruise control nob, same steps just before i rev i pull back then rev. Is this a update where we dont have to pull back? O and autoblip revs hard when you drivin hard and touch the breaks lol. If your on that map your car runs hard!!!!!!! as for the smell that breaking in parts and the clutch doesnt burns as much once you feel out how to launch.
86pro is offline   Reply With Quote
Old 05-08-2013, 10:45 AM   #11
FA20Club.com
Drives: 2013 White Out FR-S
if you want swing back by the office and ill check it out for you. next time just pm or call me cause i didnt see the tag till now
FA20Club.com is offline   Reply With Quote
EcuTek RaceROM Launch Control just86 Software Tuning 47 03-14-2014 02:55 PM
Ecutek RaceRom Custom Features Manual iBRZ Software Tuning 33 07-25-2013 01:39 PM
RaceROM Features Demo'd JPxM0Dz Engine, Exhaust, Transmission 13 03-26-2013 09:39 PM
EcuTek RaceRom Flat Foot Shifting ! Visconti Engine, Exhaust, Transmission 79 11-14-2012 09:36 PM
FR-S to BRZ feature add-ons Dillano609 Scion FR-S / Toyota 86 GT86 General Forum 12 04-01-2012 11:25 AM
