go_a_way1
Old 05-06-2013, 02:38 PM   #1275
aqua8701
jAmoMz!
aqua8701's Avatar
Drives: 2013 DGM Limited BRZ
Is 225/45/18 going to be too much tire with sportline springs?
"...And if they got a problem with it, tell them I said it!"
http://www.ft86club.com/forums/showthread.php?t=35563
aqua8701 is offline   Reply With Quote
Old 05-06-2013, 03:12 PM   #1276
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Originally Posted by FRankenStein View Post
Before adapters. Possible rocket bunny kit on its way if they work though
If you run 10mm adapters you could get it to fit up front but with a but load of negative camber, fender pull, and stretching tires. Definitely doable though... Rears are definitely more of a concern IMO... Stock body and actually making em sit inside the fender or close to it would be tough.
Also if you go with RB kit you're going to end up getting pretty big spacers to get the fitment anywhere close to flush(30mm+). Know I see a lot of guys running 10.5 +22's in the rear and still end up getting spacers that push em well into the negative offsets.
Here's a good reference for you(for the rears) and stock body:
10.5 width with a +32 et, you can see how much poke there is... Add a 10mm or 15mm adapter and it only gets harder
http://www.ft86club.com/forums/showthread.php?t=23831
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 05-06-2013, 03:52 PM   #1277
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Too tall, your gearing will be (my Yoda impression); you will loose fuel consumption and more importantly, acceleration.
A 225/40R18 is perfect diameter to replace with the OEM size. If you are going with a wider wider (8" or more), then you can go with a 245/35R18 or 255/35R18 depending how aggressive you want to get.
Daily driver only or autocross/track too?
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
aqua8701 (05-06-2013)
Old 05-06-2013, 07:09 PM   #1278
aqua8701
jAmoMz!
aqua8701's Avatar
The only autocross in my area not held on days I work is BMW drivers. I've heard they're a cool bunch and won't mind but so far only DD.
I kind of figured 45 would be off based on what I've seen on the other 86s but I figured I'd ask as I was going to get a really good deal on the tires. Oh well
Old 05-06-2013, 07:13 PM   #1279
jshadeck
jshadeck's Avatar
Will this fit? (width, offset and tire size Qs)
Wouldnt u lose accel but GAIN mpg due to the taller tire? Since a taller tire would go further each rotation, at the same speed, the taller tire will have the engine at lower rpms...
A 225/45 is 5.5% larger than stock
A 225/40 is 1.6% larger than stock
A 225/35 is 1.6% smaller than stock
A 225/40 with a slight stretch (IE on a 8 or 8.5 rim) would probably reduce that 1.6% down to stock diameter or so. I have a 235/40 which is 3.1% larger but they are stretched on a 9.5 rim, my speedo is almost dead on.
PS the 235s came w the rims, once they burn off im planning to go wider.
jshadeck is offline   Reply With Quote
Old 05-07-2013, 03:18 AM   #1280
GTS86
GTS86's Avatar
Drives: Black GTS86 Aero
To the wheel gurus on this forum.. I need some advice.
I'm looking at a set of 18x8JJ 5x100 with the inscription "22 ET 75HUB VR”
I presume this means they are a +22 Offset with a HUB diameter of 75mm? So they should fit but might require a spacer to correc the Offset?
If so can anyone recommend the correct size spacer for a fairly "flush" fitment?
Thanks guys!
GTS86 is offline   Reply With Quote
Old 05-07-2013, 10:06 AM   #1281
RavSpec
Drives: Rx7
Thanks guys!
Need 75 to 56 hub rings. Not sure who makes them.
This spec is fairly flush.
RavSpec is offline   Reply With Quote
Old 05-07-2013, 01:08 PM   #1282
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Thanks guys!
Spacer won't correct that. The wheels will poke out a bit. Spacers will only push it out more. You have to remove material from the wheel to increase offset (tuck wheel more). Not all wheels can take that machining safely. Probably best to find a higher offset and add spacers if needed to fine-tune.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 05-07-2013, 01:15 PM   #1283
Touge86
Touge86's Avatar
Drives: 2013 DGM BRZ M/T
So i'm looking at some 17x8 +37 advan RGII's. I'm wondering if this is the ideal rim size/width for handling? and what tire specs would be best for this setup?
Touge86 is offline   Reply With Quote
Old 05-07-2013, 01:23 PM   #1284
RavSpec
Drives: Rx7
use 225/40. Will look similar to this setup.
Old 05-07-2013, 01:52 PM   #1285
Touge86
Touge86's Avatar
Should I go wider tire specs in the back as well?
Old 05-07-2013, 02:03 PM   #1286
2point0
2point0's Avatar
You can (lots of room in back), but it just limits your ability to rotate. You can go up to 245/40/17 on an 8" wide wheel. That's almost exactly the same diameter as stock, so you won't see any difference on the speedo. There's lots of debate about responsiveness and weight, which is why I'm sticking with 225s (that and a HUGE price difference).
For 225s I'd go with a 45 sidewall, but that's mostly because of lots of freeway driving (every lil bit helps!) and they fill the gap just a tad more. The 40 sidewall makes the gap look bigger, but probably not so noticeable if you're lowered. Really, they're both pretty damn close to stock.
My thought is that it's more practical to have a "square" set for ease of rotations, then add a small spacer in the rear to get the fitment you want, if desired, rather than different sizes front/back. I will probably add a 15mm spacer on my 17x8 rears. Bolt-on style, not slip on.
Old 05-07-2013, 05:16 PM   #1287
triwoody
Drives: asphalt frs
Hi wheel guys i have some questions.
I'm getting some te37sl in 18x9.5 +40 square
Im currently lowered on eibach pro kit
the tire setup im planning on running is 245/40/18
or 245/35/18
will i need spacers or camber bolts in the front? and also which of the two tire sets would be ideal?
Thank you guys for the info
triwoody is offline   Reply With Quote
Old 05-08-2013, 12:54 PM   #1288
aqua8701
jAmoMz!
aqua8701's Avatar
225/40/18 on 18/7.5 +45 offset with 1.4" drop,(eibach sportline)...
Any issues or will this be perfect fit?
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
