Old 05-06-2013, 11:45 AM   #15
BunnyRZed
BunnyRZed's Avatar
Drives: BRZ Limited [37J]
In modern cars we have octane & knock sensors that can retard the timing in order to compensate for lower octane fuels. You'll lose a little performance but nothing to worry about. Just pump the correct octane next time you pump gas.
BunnyRZed is offline   Reply With Quote
The Following 10 Users Say Thank You to BunnyRZed For This Useful Post:
Bg8780 (05-13-2013), BRZerk (03-27-2014), FRiSson (05-06-2013), ftc~brz (03-27-2014), Guff (05-11-2013), King Tut (05-06-2013), Mickeyt86 (05-11-2013), Ryeong86 (05-11-2013), SkullWorks (05-06-2013), strat61caster (05-07-2013)
Old 05-06-2013, 11:51 AM   #16
DarkSunrise
DarkSunrise's Avatar
Originally Posted by nabil_frs View Post
Hey guys so my dad accidentally put 87 instead of the premium 91 he only put 20$ so about 16L but i noticed a pinging noise more then usual and i asked him and he realized he put the wrong gas in the tanks half empty now but WHAT DO I DO!!!! HELPPPPPPPP
That pinging noise you hear is detonation, which is not good for your pistons.
If your tank is half empty, drive gently to the nearest gas station and fill it up with 93. Take it somewhat easy on that next tank until you can fill up with 93 again. Should be fine after that.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
amram (03-31-2014)
Old 05-06-2013, 11:52 AM   #17
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by foxhu View Post
you should put a sign at your tank saying 91+ ONLY!
Already there
Originally Posted by Narcoden View Post
Mine came with a sticker in the fuel door that says to use premium. I don't know the exact wording but there is a sign that says to use higher octane already.
+1. To the OP--Assuming your father is apologetic about this, he owes you a tank of PREMIUM. The car will be fine, one tank of 87 won't make a difference in the long haul. Just drive the car like your grandparents for the remainder of this tank (no heavy acceleration, no revving of the engine, etc.). On the plus side, you may get slightly higher than average gas milage even with the regular gas.
The Following 2 Users Say Thank You to HunterGreene For This Useful Post:
amram (03-31-2014), ftc~brz (03-27-2014)
Old 05-06-2013, 12:04 PM   #18
NOHOME
Drives: RAVEN
Most likely you have induced irreparable damage to the engine. Consider scrapping the car.
OK, sorry, could not keep a straight face...
Your car is fine. How are you even hearing a knock when the computer has sensors that will detect the first hint and then pull timing out of the curve?
I doubt that even running 87 octane long term would harm the engine; most likely just lose a few of the high load horsepower.
NOHOME is offline   Reply With Quote
Old 05-06-2013, 12:22 PM   #19
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Fill the tank with 91 octane and don't freak out next time. As mentioned the car has a knock sensor that will retard timing when needed.
Old 05-06-2013, 12:22 PM   #20
sierra
Drives: Skoda Yeti DSG diesel 4x4
93+ is the recommended octane rating in the US.
91 can be used when it's not available, without detriment but it's going to lose power and can't be good long term because it's designed to run on 93 octane or higher.
87 would void the warranty and almost certainly cause engine damage.
sierra is offline   Reply With Quote
Old 05-06-2013, 12:55 PM   #21
HunterGreene
Hail Magnet
First part is right, your second statement is completely wrong. There have been numerous users on here who have had 87 in their initial tank from the dealer that have not shown any long-term effect. A single tank of 87 will not void your warranty, nor cause catastrophic engine damage.
The Following 3 Users Say Thank You to HunterGreene For This Useful Post:
andrew20195 (03-31-2014), Rampage (03-28-2014), strat61caster (05-07-2013)
Old 05-06-2013, 01:14 PM   #22
FT86Dubai
FT86Dubai's Avatar
Drives: 2013 Toyota 86
Just drive it gently, no throttle blipping or hard acceleration and prevent driving it in hot after noons. It'll be fine.
2013 Toyota 86 (Sold it and regretting)
FT86Dubai is offline   Reply With Quote
Old 05-06-2013, 02:05 PM   #23
FRiSson
Drives: FR-S MT
Geez.... overreaction. Toyota knows that there are some times when you won't be able to get premium gas. Hence, the engine will react to detonation by retarding the spark.
Just think dilution. You have 89-90 in the tank now, since your father filled only half a tank. When it goes down to one quarter tankful, you can boost that to 91 by adding 93. Problem solved. Just go easy on the engine, particularly under load such as going up hills and you won't induce detonation. Relax.
FRiSson is offline   Reply With Quote
Old 05-06-2013, 02:12 PM   #24
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Thanks, Cpt.Leaflet-Reader, but it's clear you haven't a clue how petrole engines work, particularly the electronics that control fuel and spark.
thanks for dropping by.
The Following 5 Users Say Thank You to 7thgear For This Useful Post:
CamryDS (05-06-2013), Gixxersixxerman (05-11-2013), schtebie (05-06-2013), Shneegle (05-08-2013), SkullWorks (05-06-2013)
Old 05-06-2013, 05:51 PM   #25
fistpoint
Drives: Supercharged Golf Cart
I bet you triple the US national debt that 99.9% of everyones vehicle here had its first tank of gas with 87 octane.
Dealers NEVER put the correct grade unless you happen to be standing right next to them when they fill it, and even then you might not be able to persuade them.
fistpoint is offline   Reply With Quote
Old 05-06-2013, 06:00 PM   #26
HunterGreene
Hail Magnet
I was lucky, I had a sales lady that pays attention to the little sticker inside the fuel door. Either that, or she was just covering her ass. I was inclined to believe her.
Old 05-06-2013, 06:17 PM   #27
was385
Drives: MT WRB BRZ Limited, 2007 911s
Put in 93 and dilute out the lower octane gas. You'll be fine.
was385 is offline   Reply With Quote
Old 05-06-2013, 06:42 PM   #28
fistpoint
I told the sales manager about the fuel requirement and he replied that they put 87 in ALL their cars, regardless of make or model.
I turned around and pointed to the Porsche 911 Turbo and Lexus LFA sitting 30 feet behind me...he replied: "those are the owners cars". I then replied: "and I bet you my new car he put the correct gas in them...".
The Following User Says Thank You to fistpoint For This Useful Post:
SirBrass (03-27-2014)
Downforce: you're doing it wrong. ATL BRZ Cosmetic Modification (Interior/Exterior/Lighting) 28 04-12-2013 02:31 AM
What's wrong with my HID kit? seven Cosmetic Modification (Interior/Exterior/Lighting) 17 11-28-2012 08:36 PM
am I doing something wrong? shiud Scion FR-S / Toyota 86 GT86 General Forum 20 07-17-2012 06:21 PM
Was I in the wrong? D4ng3r Off-Topic Lounge [WARNING: NO POLITICS] 18 06-15-2012 02:46 AM
Wrong Fuel Hawx AUSTRALIA 22 12-11-2011 07:08 PM
