#15 |
Drives: BRZ Limited [37J]
In modern cars we have octane & knock sensors that can retard the timing in order to compensate for lower octane fuels. You'll lose a little performance but nothing to worry about. Just pump the correct octane next time you pump gas.
| The Following 10 Users Say Thank You to BunnyRZed For This Useful Post: | Bg8780 (05-13-2013), BRZerk (03-27-2014), FRiSson (05-06-2013), ftc~brz (03-27-2014), Guff (05-11-2013), King Tut (05-06-2013), Mickeyt86 (05-11-2013), Ryeong86 (05-11-2013), SkullWorks (05-06-2013), strat61caster (05-07-2013) |
#16 | |
If your tank is half empty, drive gently to the nearest gas station and fill it up with 93. Take it somewhat easy on that next tank until you can fill up with 93 again. Should be fine after that.
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | amram (03-31-2014) |
#17 |
Hail Magnet
Already there
+1. To the OP--Assuming your father is apologetic about this, he owes you a tank of PREMIUM. The car will be fine, one tank of 87 won't make a difference in the long haul. Just drive the car like your grandparents for the remainder of this tank (no heavy acceleration, no revving of the engine, etc.). On the plus side, you may get slightly higher than average gas milage even with the regular gas. |
#18 |
Drives: RAVEN
Most likely you have induced irreparable damage to the engine. Consider scrapping the car.
OK, sorry, could not keep a straight face... Your car is fine. How are you even hearing a knock when the computer has sensors that will detect the first hint and then pull timing out of the curve? I doubt that even running 87 octane long term would harm the engine; most likely just lose a few of the high load horsepower. |
#19 |
NASA SpecE30 Racer
Fill the tank with 91 octane and don't freak out next time. As mentioned the car has a knock sensor that will retard timing when needed.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | ftc~brz (03-27-2014) |
#20 |
Drives: Skoda Yeti DSG diesel 4x4
93+ is the recommended octane rating in the US.
91 can be used when it's not available, without detriment but it's going to lose power and can't be good long term because it's designed to run on 93 octane or higher. 87 would void the warranty and almost certainly cause engine damage. |
#21 | |
Hail Magnet
| The Following 3 Users Say Thank You to HunterGreene For This Useful Post: |
#22 |
Drives: 2013 Toyota 86
Just drive it gently, no throttle blipping or hard acceleration and prevent driving it in hot after noons. It'll be fine.
2013 Toyota 86 (Sold it and regretting)
#23 |
Drives: FR-S MT
Geez.... overreaction. Toyota knows that there are some times when you won't be able to get premium gas. Hence, the engine will react to detonation by retarding the spark.
Just think dilution. You have 89-90 in the tank now, since your father filled only half a tank. When it goes down to one quarter tankful, you can boost that to 91 by adding 93. Problem solved. Just go easy on the engine, particularly under load such as going up hills and you won't induce detonation. Relax. |
#24 | |
i'm sorry, what?
Drives: Canada
thanks for dropping by.
| The Following 5 Users Say Thank You to 7thgear For This Useful Post: | CamryDS (05-06-2013), Gixxersixxerman (05-11-2013), schtebie (05-06-2013), Shneegle (05-08-2013), SkullWorks (05-06-2013) |
#25 |
Drives: Supercharged Golf Cart
I bet you triple the US national debt that 99.9% of everyones vehicle here had its first tank of gas with 87 octane.
Dealers NEVER put the correct grade unless you happen to be standing right next to them when they fill it, and even then you might not be able to persuade them. |
#26 | |
Hail Magnet
#27 |
Drives: MT WRB BRZ Limited, 2007 911s
Put in 93 and dilute out the lower octane gas. You'll be fine.
#28 | |
I turned around and pointed to the Porsche 911 Turbo and Lexus LFA sitting 30 feet behind me...he replied: "those are the owners cars". I then replied: "and I bet you my new car he put the correct gas in them...". Last edited by fistpoint; 05-06-2013 at 06:08 PM. |
| The Following User Says Thank You to fistpoint For This Useful Post: | SirBrass (03-27-2014) |
| Downforce: you're doing it wrong. | ATL BRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 28 | 04-12-2013 01:31 AM |
| What's wrong with my HID kit? | seven | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 11-28-2012 07:36 PM |
| am I doing something wrong? | shiud | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 07-17-2012 05:21 PM |
| Was I in the wrong? | D4ng3r | Off-Topic Lounge [WARNING: NO POLITICS] | 18 | 06-15-2012 01:46 AM |
| Wrong Fuel | Hawx | AUSTRALIA | 22 | 12-11-2011 06:08 PM |
