Old 02-05-2013, 08:25 PM   #29
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by DNAPoPo View Post
Looks great, I'm comparing these to Eibach Pro Kit as well since they are basically the same amount of drop. The Eibachs are just a whole lot cheaper and easier to get is the only advantage so far.
Slight difference in drop, the ProKit gives 25mm drop whereas the Sti items are 15mm. But yea the eibachs are much cheaper.
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
DNAPoPo (02-05-2013)
Old 02-08-2013, 06:47 AM   #30
Panman
Panman's Avatar
Drives: 86 GTS
Originally Posted by ZC6BRZ View Post
The ride is great. slightly firmer than stock but not much. It rotates better, and handles better as well. No regrets, great purchase! Definitely recommend them for a good OEM+ setup.
Any issues with fitment? Were the springs captive without compression?
Panman is offline   Reply With Quote
Old 02-08-2013, 11:19 AM   #31
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
no issues. What's captive w/o compression mean?
ZC6BRZ is offline   Reply With Quote
Old 02-08-2013, 05:54 PM   #32
Panman
Panman's Avatar
Drives: 86 GTS
Spring is trapped in the top of the shock when it's hanging free (isn't loose on the shock body before you fit it to the car.)
Old 02-08-2013, 06:33 PM   #33
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Yes c wo c
The Following User Says Thank You to ZC6BRZ For This Useful Post:
Panman (02-08-2013)
Old 02-08-2013, 07:29 PM   #34
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
The shocks are the same for FRS and BRZ. Tested by more than 1 source.
- Andrew
Im buying your RCE Yellows soon for my FRS i find them to be the best springs out right now. and they wont mess up the factory struts. i read something you guys posted anything more than 20MM can cause damage to the factory struts so i like the 20mm drop and the 250LBS spring rates on them plus i like RCE A lot keep up the good work guys!
DanoFA20 is offline   Reply With Quote
The Following User Says Thank You to DanoFA20 For This Useful Post:
Racecomp Engineering (05-03-2013)
Old 02-08-2013, 10:05 PM   #35
Jaylyons1
Jaylyons1's Avatar
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
That looks great! Just what I'm looking for too! I'm not trying to slam my car but do want to get a little bit of a drop. Anything over an inch is just too much.
Jaylyons1 is offline   Reply With Quote
Old 02-11-2013, 07:04 PM   #36
icemanbrz
Drives: 2012 F25 X3 xDrive35i M-Sport
Where did you buy the spring?
icemanbrz is offline   Reply With Quote
Old 02-13-2013, 11:13 AM   #37
DSOmegaX
DSOmegaX's Avatar
Mine are arriving tomorrow from japanparts.com . I believe this is the only source of them in the US for now.
Old 02-17-2013, 01:21 PM   #38
ft_sjo
Drives: GT86
Does anyone know the rates of these springs? (particularly the higher rate)
Old 03-04-2013, 12:08 AM   #39
Panman
Panman's Avatar
Drives: 86 GTS
Installed these in my 86 - Definitely a good upgrade. Certainly rotates quicker, ride is not compromised and drop is noticeable but not excessive as I have the factory Aero kit (Australia) and cant drop too much.
The Following User Says Thank You to Panman For This Useful Post:
Jaylyons1 (03-23-2013)
Old 05-03-2013, 03:30 PM   #40
BRZebra
Would those of you with the STI springs kindly share how much they affected your wheel alignment?
Did you install any other suspension parts or just the springs?
BRZebra is offline   Reply With Quote
Old 05-03-2013, 11:10 PM   #41
Panman
Panman's Avatar
Drives: 86 GTS
I had mine aligned when I had them fitted - back to factory specs which it did with no problems. No other parts in mine except the springs at this point.
BRZebra (05-27-2013)
Old 05-04-2013, 08:55 AM   #42
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
front : no camber change
rear : -1.5~1.8.
I installed Pink springs with STI flexible tower bar. (& front camber bolt too)
definitely better handling with good ride quality.
Yobiwan is offline   Reply With Quote
The Following User Says Thank You to Yobiwan For This Useful Post:
OEM BRZ springs? jm1681 Brakes, Suspension, Chassis 1 11-03-2012 08:14 AM
Anyone use the JDM/Sti springs? G4mb17 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-25-2012 08:10 PM
HELP:Q about springs Obja Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 10-08-2012 02:12 PM
trd springs or no? FT86R Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 09-30-2012 03:52 PM
STi Springs illmatic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-14-2012 01:19 PM
