#5027 | |
That guy
Drives: Ultramarine mt FR-S
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
#5028 |
#5029 |
Drives: Black 86 GT
It's worked every time for me so far ... but I still check it just in case!!! It would be great if someone like Ecutek could fix it up to ensure it is fully reliable for us all.
#5030 | |
Drives: '13 WRB 6MT BRZ Limited
2013 BRZ Limited WRB
#5031 |
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Why I use the 3 pulls? Because it save me lot of time.
I open door same time I'm seating down I pull three time on the Start button, As soon as I'm seat down I press press clutch and press one more time to start engine and as I engage first gear I pull cruize control to double check it stayed on my E85 tune and then put seat belt on as I released clutch to move on. Maybe I'm hyper active but I have no time to loose for seat down press two time then select E85 map then start engine. I'm already far by that time
#5032 |
Drives: 86
Just flashed my car on the weekend on STG1 pump gas map (only mod i have is Perrin panel drop in and Perrin header back). car seems to be fine and there are stronger pull from 2500rpm then hit the torque dip then pull strong again from 4000rpm.
however i seem to hear some knock sensor sound around 3000 - 4000rpm. is it normal or is it the DI sound? i don't think i heard this before flashing....... would data logging capture this? ambient temp was around 22 degrees C (around 72 degrees F), water and engine oil temp were warm and normal. thanks. |
#5033 | |
Drives: 2013 Asphalt FR-S
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
#5034 |
Drives: 86
thanks for your reply. it's more like ta-ta-ta-ta sound so i doubt very much its intake sound. this sound is quite common with my previous rides on lower octane gas but i don't think i've ever heard this on my 86 before ecu flash.
#5035 | |
#5036 |
Drives: 86
#5037 | |
John |
#5038 |
Drives: STi
Can this sound be reduced by blocking the sound tube?
Sent from my GT-N7105 using Tapatalk 2 |
#5039 |
#5040 |
Drives: 86 (FR-S)
| LED Front Signals with Resistor Flash Correctors | DarrenDriven | Cosmetic Modification (Interior/Exterior/Lighting) | 38 | 09-20-2012 03:05 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
| How to embed a flash gallery? | DarrenDriven | Site Announcements / Questions / Issues | 2 | 04-24-2012 08:43 PM |
| Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors | blur | BRZ First-Gen (2012+) — General Topics | 130 | 09-01-2011 02:42 PM |
