#8093 |
Drives: SWP BRZ 6MT
I just checked my street tires (OE). They're pretty even, within 0.5/32nds between inside and outside of the tread (overall they're around 7.5/32nds after 10k miles). My autocross tires are another story, they wear much more on the outside, which is a sign of not enough negative camber (wearing on the inside of the tread would mean the opposite).
Setting camber for performance driving is a matter of the tires' lateral grip capacity and the roll resistance of the suspension setup (spring rates + anti-roll bar rate). Soft setups like mine (stock springs with a modest 20mm FSB) will require more static negative camber to counteract the effects of body roll on the tires' contact patch. Stickier tires will put more force in the suspension, causing more body roll. Rear negative camber tends to be a compromise, since static camber in the rear will detract from the ability to accelerate (In our RWD cars) and brake in a straight line (front camber affects braking too). Lowering the twins will cause a negative camber gain in the rear, and it's not always even between sides. Without aftermarket parts, it's kind of a crapshoot as to what any particular car will get. When setting camber for street driving, driving style is probably a much bigger influence, since you won't always be driving 10/10ths (hopefully). If the car is driven in straight lines all day on the freeway the camber wear will show up much more than a car that sees a lot of aggressive cornering. I hope this helps give you an idea of how to proceed with your setup. A controlled environment can be great for fine-tuning a setup. P.S. To really get into this, a discussion of dynamic camber is probably warranted. That's a whole big can of worms. Ugh. |
| The Following 3 Users Say Thank You to Ninjin For This Useful Post: |
#8094 |
AZ FRS 86
There is a BBQ at my place on Sunday the 12th at noon
@AZFRS86
#8095 | |
Lowered Lifestyle
Drives: Scion Fr-S
#8097 | |
And yes in towards the engine = negative camber. it also depends on how you adjusted the bolt on the lower side for camber. i pushed mine all the way in and then pulled my camber plates out. It sounds like you pushed it out. I went with the mindset that if it wasn't completely tight (although i used a torque wrench) that it would likely push more in (towards negative camber). I need to hit up Kos and get me some new bolts.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
| The Following User Says Thank You to nelsmar For This Useful Post: | SMOKETREES (04-30-2013) |
#8098 | |
Lowered Lifestyle
Drives: Scion Fr-S
#8099 | |
I was going to go to network alignment as they do free check & then i think its 10$ extra for lowered cars and its not terribly expensive. I was going to do this so i could get it checked and then go home and adjust my rear to get hopefully close to 1.5-2 degrees negative camber. (depending on the toe in). But then i realized toyota near me has an alignment rack and my friend works there so I am going to just set an appointment there.
#8100 |
P.S. you mentioned stretched tires... if your on OEM wheels i wouldn't worry about rubbing on anything unless you dropped the car excessively. The offset is beyond conservative on this car. And our wells are fairly clean with good clearance.
#8101 | |
Drives: SWP BRZ 6MT
It's not going to be as accurate as an alignment rack, but it's a lot cheaper if you already have the tools, and you can get pretty close with a steady hand and a keen eye. |
| The Following User Says Thank You to Ninjin For This Useful Post: | SMOKETREES (05-01-2013) |
#8102 |
Drives: Scion FR-S
So I was on the AZsolo forums and there is a bunch of new to us and very strict rules for road course autoX. I have asked for them so I can either post a link or email them. Spinning out and going off track will be an Extreme DNF from what I'm seeing.
Also this is what @thesleeper looks like giving directions And this is what @Sivtec looks like when he is lost lol Last edited by Accurate Race Shop; 05-01-2013 at 12:22 AM. Reason: typo |
| The Following 2 Users Say Thank You to Accurate Race Shop For This Useful Post: | Sivtec (05-01-2013), thesleeper (05-02-2013) |
#8103 |
Proud of FR Layout
Drives: 2013 Scion FR-S 6MT
alright, signed up for the AMP special event.
DDDDedit: yea typically the rules are much more strict during special events, and AMP is doubly so. Id assume 2 wheels off is an extreme DNF, maybe even asked to leave but 4 wheels off even once is your cue to go home. Its really not that bad, but as a novice myself I will definitely be asking for an instructor for my first lap at the very least |
#8104 |
Drives: Monkey-butt red FR-S
#8105 |
Drives: SWP BRZ 6MT
#8106 |
| Tags |
| arizona, fr-s, mesa, phoenix, scion, tucson, we need a subforum |
| Arizona Bill 'could' criminalize Internet Trolls | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 18 | 12-30-2013 03:54 PM |
| Accessories page for Canadian BRZ owners | percyng | CANADA | 1 | 06-15-2012 08:27 PM |
| FR-S\BRZ owners give thumbs up to AE86 owners | Oriental Life | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 06-13-2012 04:12 AM |
| Home Sweet Home, it made it today. Delivery party 5/11 though.. | MarkRacerX | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 05-14-2012 04:24 PM |
