Old 04-29-2013, 11:11 PM   #113
ayau
Drives: Some rust bucket
I think my rear to front ride height ratio is lower in the rear compared to the OEM ratio. At the default "0" beam height, it seems to point way too high/far. I have to set it to "1" or else I'll blind oncoming traffic. Maybe I'll raise the front a little. :dunno:
Old 04-29-2013, 11:12 PM   #114
Hanakuso
Originally Posted by ayau View Post
Yes, it matters. The bolt aims toward the front of the car (nut is on the left side when looking straight at the wheel rotor).
If you have the factory top bolt, it can only go in one way (the factory way). I have the OEM crash bolts at the top to get additional camber at the wheel hub. It's the ideal way to gain negative camber without affecting the coilover geometry/angle.
Cool ill have to check that again. I could of sworn my left and right were pointing different ways.
Do you notice any extra noise with your set? I hear some camber plate chunking but not too much
Hanakuso is offline   Reply With Quote
Old 04-29-2013, 11:17 PM   #115
ayau
Originally Posted by Hanakuso View Post
Cool ill have to check that again. I could of sworn they my left and right were pointing different ways.
I did notice a huge clunking noise but that was my fault because I forgot to torque the nuts holding the coilover springs, lol.
I don't really notice it now as much. My Direzza II tires generate quite a bit of noise and it's difficult for me to notice. I'll have to pay attention more tomorrow to see if I can hear it.
My trunk is also completed gutted. No lining, spare, etc. That will also generate a little more road noise as well.
I'd double check your front and rear top hat nuts to ensure they're properly torqued. The rear 17mm nuts are 22 ft lbs, and the 13mm fronts are 17 ft lbs.
Old 04-29-2013, 11:21 PM   #116
ayau
Is there an "optimal" ride height range for the R2 coilovers?
Paging @Jackson.
Old 04-29-2013, 11:25 PM   #117
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
My hearing isn't the best, but no noise here.. nothing abnormal anyways.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-29-2013, 11:59 PM   #118
Hanakuso
Damn maybe I didn't install it correctly. I think on one side I torqued the bolts that hold the strut first, then the 3 nuts on top
Old 04-30-2013, 01:22 AM   #119
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
Its always top first then bottom. Same goes for the rear but you jack up the rear.
RAWR BRZ is offline   Reply With Quote
The Following User Says Thank You to RAWR BRZ For This Useful Post:
Hanakuso (04-30-2013)
Old 04-30-2013, 01:32 AM   #120
ayau
Does it really make a difference once everything is torqued to spec? I install all nuts/bolts finger tight before I torque them to spec.
Old 04-30-2013, 10:48 AM   #121
Jackson
Jackson's Avatar
Drives: E46 M3 (daily) / EG Civic (track)
Paging @Jackson.
One inch front and rear seem to work best.
Jackson is offline   Reply With Quote
The Following User Says Thank You to Jackson For This Useful Post:
ayau (04-30-2013)
Old 04-30-2013, 04:05 PM   #122
RAWR BRZ
I dont know technically why but in the pictorial for installation and instructions from Mark at Eibach. I would trust them that there is a reason why for these specific steps.
Old 04-30-2013, 04:12 PM   #123
ayau
I'm curious to hear what @Dave-ROR or @CSG Mike has to say about the order in which you torque the bolts (front top to bottom).
Old 04-30-2013, 04:14 PM   #124
Hanakuso
I think what Rawr is saying is the order you install, since the installation guide didnt have any torque specs.
I usually hand tighten things, then go back and torque it down.
Old 04-30-2013, 04:18 PM   #125
ayau
I think I'm confused now.
Are we talking about the order in which you fasten the bolts?
For example, for the front coilovers, you'd mount the 3 nuts for the top plate first, then thread the 19mm bolts through the knuckle?
If the bolts aren't torqued at the top first, then're going to wiggle when you install the 19mm bolts at the bottom.
Old 04-30-2013, 04:21 PM   #126
Hanakuso
In my case, I went through the steps with hand tightening, then torqued it down depending on which bolt it was.
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
Eibach Multi-Pro R2 Coilover Review donutfilling Suspension | Chassis | Brakes -- Sponsored by 949 Racing 254 05-08-2016 11:56 AM
Eibach Multipro R1 and front and rear sway bar installed Pekingduck Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 12-30-2013 10:59 AM
***Time to freak out, Eibach coilover pricing available**** JoeBoxer Brakes, Suspension, Chassis 154 05-16-2013 05:30 PM
Eibach Coilover Options - SEMA 2012 Coverage FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 01-25-2013 07:19 AM
