go_a_way1
Old 04-28-2013, 12:49 PM   #1233
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by white_knight View Post
So, based on the fact that most stretched setups round off, I'm guessing the tyre must be a considerable amount wider than the rim to achieve the squared-off look?
Post a few pics/links to confirm/deny.
It may be how you are interpreting things.
ill86 is offline   Reply With Quote
Old 04-28-2013, 03:13 PM   #1234
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
I'm Looking into purchasing 57Xtremes 18x8.5 +33 F and 18x9.5 +40 R. What would be the best Tire Fitment? I was looking into 225/40 or 235/40 for the front and 245/40 or 255/40 for the rear? Will be running KW V3 Coilovers on .8" drop F/R
DesertFrs is offline   Reply With Quote
Old 04-28-2013, 04:10 PM   #1235
ill86
ill86's Avatar
Drives: iG FR-S
Acceptable range of tire:
Front 8.5" - 215mm ~ 255mm
Rear 9.5" - 245mm ~ 285mm
If it were mine:
Front - 225/40-18
Rear - 255/35-18
Or
Front - 235/40-18
Rear - 265/35-18
A 255 or 265mm should go to a 35 sidewall with the front tires you had listed. 40 is too tall.
Old 04-28-2013, 06:53 PM   #1236
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Example of 'rounded' profile (this is my current setup) (235/40/18 + 18x8.75):
Example of 'squared' profile (not sure what this setup is):
white_knight is offline   Reply With Quote
Old 04-29-2013, 01:48 AM   #1237
ill86
ill86's Avatar
Drives: iG FR-S
Attachment 35535
Attachment 35537
Stretched fitment most likely. Although it can also be the design of the tire.
Old 04-29-2013, 11:21 AM   #1238
thiha
Drives: Toyota GT 86
Originally Posted by OmarGC View Post
It will... I suggest 245/35(keeps your speedo happy) or even a 255/35. Also, what kind of suspension are you on?
Stock suspension currently I dont want to upgrade my suspension since the car is only for daily use. But I do plan on purchasing spring in the future though. Btw
anyone here running XXR 531? I always love dish wheel and 531 looks good to me. What do you think of 18x9.5 35+ for both front and rear. Will that fit too?
thiha is offline   Reply With Quote
Old 04-29-2013, 02:56 PM   #1239
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
The size you mentioned above on stock suspension is going to poke outside your fender wells ESP on stock suspension/no camber... I just saw you're in Australia so I'm sure you're aware about those kind of laws.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following User Says Thank You to OmarGC For This Useful Post:
ill86 (04-29-2013)
Old 04-29-2013, 07:17 PM   #1240
sam_o
Drives: Toyota 86
Hi from Oz. I've been deciding on a setup for everyday for about six weeks now and have decided on the following:
Work Emotions Kiwami Ultimate
Front: 19X9.5 +33 (235/35)
Rear: 19X10.5 +35 (255/35)
I've tried the tyre app calculator but want to confirm how much poke this will cause.
MCA Red Series coilovers have been installed and is lowered approx. 1.5 inches.
Your help would be much appreciated.
sam_o is offline   Reply With Quote
Old 04-29-2013, 07:20 PM   #1241
RavSpec
Drives: Rx7
It will be 19x9.5 +38 and 19x10.5 +32
1.5" not going to cut it. Poke by alot in the rear.
I have a pic of 19x10.5 with -2mm camber and 235/35 pics uploaded on the wheel section.
I also have the 19x9.5 +38mm pics somewhere there as well.
Not a great setup for only 1.5" drop.
I'll suggest 19x9.5 +38 all around.
Mark.
RavSpec is offline   Reply With Quote
Old 04-29-2013, 07:21 PM   #1242
RavSpec
Drives: Rx7
19x9.5 +38 all around with 235/35 tires
http://www.flickr.com/photos/jdmwheel/8204497048/
19x10.5 +32 all around with 235/35 tires
http://www.flickr.com/photos/jdmwheel/8252159679/
Old 04-29-2013, 07:24 PM   #1243
RavSpec
Drives: Rx7
If it were mine:
Front - 225/40-18
Rear - 255/35-18
Or
Front - 235/40-18
Rear - 265/35-18
Agree.
i'll do 225/40 and 255/35
Old 04-30-2013, 03:21 AM   #1244
sam_o
Drives: Toyota 86
Mark.
Thanks heaps for this. So +38 it is. Out of curiosity, does anyone know the specs of the GT86 by Frey. Not much info on this setup.
Old 04-30-2013, 08:34 AM   #1245
white_knight
Any issues running 18x9.5 +40 all round, 255/35/18 with Eibach Pro Kit (no camber adjustment)?
Old 04-30-2013, 03:44 PM   #1246
triwoody
Drives: asphalt frs
same question as him, but 235/40/18, will i need a spacer in the front?
triwoody is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
