go_a_way1
Old 04-25-2013, 07:58 AM   #1219
beardy
Drives: GT86 Pearl White
Hi! Got a question about the Volk TE37SL wheels. On Rays site they are listed with a bore of φ65. As far as I know, the hub bore size on the 86 is φ56.1, so how have people fitted SL's on their brz/frs/gt86's? hubspacers? and if so, where can you get them?
/Beardy
beardy is offline   Reply With Quote
Old 04-25-2013, 09:00 AM   #1220
RavSpec
Drives: Rx7
/Beardy
You don't really need "hub rings", but yeah hub rings can be purchase in most wheel shop.
65 to 56mm is what u need.
I usually supply them to my customer free when they purchase wheels.
RavSpec is offline   Reply With Quote
Old 04-25-2013, 09:17 PM   #1221
GTS86
GTS86's Avatar
Drives: Black GTS86 Aero
Yeah that's what I thought.. damn it!
Originally Posted by 2point0 View Post
Spacers would make that MORE negative. Only way to add offset (+) would be machining off some of the wheel's hub surface (if it can be done on that wheel) or I think if it's a 3pc wheel, you can swap the rims around and change the offset, but I've never dealt with those wheels and can't say for sure.
GTS86 is offline   Reply With Quote
Old 04-27-2013, 01:21 PM   #1222
b2autodesigns
b2autodesigns's Avatar
Drives: 1991 Galant VR4
In for pictures on car
b2autodesigns is offline   Reply With Quote
Old 04-27-2013, 03:32 PM   #1223
Readytoxplod
Tire Destroyer
Drives: Firestorm+snail
I have 18x8 +45 wheels and I lowered it 1.4 inches(Sportlines).
Do I need adjustable camber in the rear? Or crash/camber bolts in the front? I'm new to all this, but my camber looks different now... Also needs spacers in the back.
322whp/273wtq
Readytoxplod is offline   Reply With Quote
Old 04-27-2013, 06:20 PM   #1224
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Only you can answer what you need.
Are you happy with the camber you got from lowering?
Do you want more adjustment?
ill86 is offline   Reply With Quote
Old 04-27-2013, 09:20 PM   #1225
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by KriSD21 View Post
Would this set of wheels fit on stock tires and stock height for the FRS? Total noob. I'm assuming it'd require different tires and/or fender rolling?Wheel Diameter (Inches) - 19"
Wheel Width (Inches) - 9.5/10.5"
PCD Bolt Pattern - 5x114.3
Offset - +15F, +15Rmm
Hub Bore - 73mm
You are a complete noob lol
Stock tires are 17
You want 19s
Our bolt pattern is 5x100
Offset is too much
Hub bore you need hub rings
The Following 2 Users Say Thank You to whitefrs For This Useful Post:
CamryDS (04-28-2013), ill86 (04-27-2013)
Old 04-27-2013, 11:22 PM   #1226
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
I've seen some setups here where the tyre profile 'squares off' into the tread and others where it 'rounds off'. Does this have more to deal with the tyre size in relation to the rim, or the actual design of the tyre?
white_knight is offline   Reply With Quote
Old 04-27-2013, 11:27 PM   #1227
ill86
ill86's Avatar
Drives: iG FR-S
Both. Mostly the former for our application.
Old 04-28-2013, 01:21 AM   #1228
white_knight
So, based on the fact that most stretched setups round off, I'm guessing the tyre must be a considerable amount wider than the rim to achieve the squared-off look?
Old 04-28-2013, 08:20 AM   #1229
thiha
Drives: Toyota GT 86
Do you think 18x8.75 +33 will fit? What tyre is suitable for wheel? Thank you~!
thiha is offline   Reply With Quote
Old 04-28-2013, 08:34 AM   #1230
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
It will... I suggest 245/35(keeps your speedo happy) or even a 255/35. Also, what kind of suspension are you on?
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-28-2013, 10:37 AM   #1231
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Any issues running coilovers, 18x9.5 +45 and 35/255 all around ?
adprokid is offline   Reply With Quote
Old 04-28-2013, 12:08 PM   #1232
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
It really does depend on the tire. My Continental DW are very rounded even though they are 245s on a 9 inch rim. Some guys are getting the same look from a 225-wide Hankook V12 because it has squarer sidewall.
Slick is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
