Old 04-25-2013, 01:26 PM   #43
plucas
plucas's Avatar
Drives: Subaru
Originally Posted by cdo221 View Post
I like what you guys are doing but do you guys take cosmetic preference into account? I'm just not sure the upside down J mounting looks all that great, is there a functional reason for that sort of solution?
We will have two different single element designs to offer, one swan neck and the other normal. The one on this page is the normal mount and will be cheaper. The swan neck is a more aggressive airfoil profile which will be for a select few people who want to maximize downforce on a single element wing.
There is a valid engineering reasoning behind swan neck (J mounting). Swan necks are mounted to the top of the profile to keep the air less disrupted on the underside of the profile (low pressure side). The low pressure side is where most of the real work is being done. This is the most efficient design available beside the endplates being the mounts. However if the endplates are also the mounts (like modern F1 cars), the wing span is limited.
Oh and looks are subjective. My designs are almost all based on data and not looks.
plucas is offline   Reply With Quote
The Following User Says Thank You to plucas For This Useful Post:
cdo221 (04-26-2013)
Old 04-25-2013, 02:33 PM   #44
RYU
RYU's Avatar
Drives: really slow...
Excellent work here guys. I'm so appreciative of real engineers developing fantastic products.
One big "con" to consider for the tow-hook mounted wing would be a disqualification of some sort from some racing bodies where the wing cannot extend X amount of inches from the farthest point in the car. I don't run NASA or SCCA but I have several friends who battle with eligibility and struggle to stay in certain brackets. Anyway, it's a small issue in the whole scheme of things.
Nice work.
Originally Posted by Hancha Group View Post
Depends on the wing and placement. Theoretically, the DEW V1 generates excess of 500 lbs so I wouldn't trust the sheet metal alone. Our SEWs makes less and will likely make less in the real world and I'd bet most wings will make significantly less than ours. Paul's still working on the CFD and I'll make sure he posts the data once it's complete. It takes a lot of processing (~4 hours on our workstation, ~24 hours on Paul's PC). However, we will offer a tow hook mount and this is a rendering of what it will roughly look like (the final upright shape will change to place the wing where it needs to be):
While this solution is not ideal, there are some real benefits.
Pros:
The wing is mounted to a structural part of the chassis to better transmit the load
The load is transmitted at the rear most point of the car for better leverage
You get a multi-purpose tow hook (we plan on making a few additional options in the future)
NOTHING is drilled or cut, EVERYTHING can fully be put back to stock
Cons:
The tow hook is loaded in bending and in shear
You need to buy two tow hooks and larger uprights so,
It is heavier
It is more expensive.
If you can deal with the additional cost and additional weight this may be the perfect compromise for having a fully functioning wing at the track and removing it for daily driving.
RYU is offline   Reply With Quote
Old 04-25-2013, 02:56 PM   #45
CSG Mike
CSG Mike's Avatar
Looking forward to more developments...
Hancha Group (04-25-2013), JazzleSAURUS (03-29-2016)
Old 04-25-2013, 03:10 PM   #46
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
This is the concept I had in mind. Please excuse the poor drawing skills. It's easiest to imagine it kind of like the current STI wing but about only half as tall. I imagine it won't stand more than 6" off the trunk so it'd be just above the third brake light.
Picture of said STI for reference
Thoughts and opinions welcome. Remember, we won't really get to start development until late summer-early fall so please stay patient with us.
I would totally buy this
eddieEndo is offline   Reply With Quote
The Following 2 Users Say Thank You to eddieEndo For This Useful Post:
Spartan65 (07-03-2013), TouchMyHonda (04-25-2013)
Old 04-25-2013, 04:10 PM   #47
Hancha Group
FT86Club Official Vendor
Hancha Group's Avatar
Drives: Subarus
Nice work.
The standard upright will be based on CFD. We can make custom uprights that place the trailing edge to place the wing where it needs to be. We will also have a standard trunk mount. Just offering more solutions tailored to the customer's preference. :]
Hancha Group is offline   Reply With Quote
Old 04-25-2013, 04:22 PM   #48
Hancha Group
Drives: Subarus
Don't mind Paul, he's very passionate about getting results. I on the other hand, try to make sure the results look good, and will ask for compromises some times, but as he said it's subjective. When it comes to aero, Paul's the boss. We are a group of engineers, with each having their own specialty, and they are largely left to do their own development.
The Following User Says Thank You to Hancha Group For This Useful Post:
cdo221 (04-26-2013)
Old 04-25-2013, 05:54 PM   #49
Gunman
Drives: 2019 Mazda Miata RF
"quillars", aka swan neck pylons:
http://www.mulsannescorner.com/AcuraARX-02-4.html
Stylists generally doesn't like them, trust me...
The Following 2 Users Say Thank You to Gunman For This Useful Post:
cdo221 (04-26-2013), EarlQHan (04-25-2013)
Old 04-25-2013, 06:04 PM   #50
EarlQHan
Drives: Subarus
So much work to design something so simple lol. "Quillars" is new to me. However, depending on who you're talking with and what part of the world he or she is from, I've heard it called: upright, pylon, stand, post, pillar but all these words are interchangeable.
EarlQHan is offline   Reply With Quote
Old 04-25-2013, 09:06 PM   #51
Gunman
Depends on the racing series too. We (Riley Tech) generally refer to them as "pylons", because we already have "uprights" in the suspension. Mentioned "wishbones" while at a nascar cup team, and some guys looked at me funny, luckily our boss was a former open wheeler
/hijack back to lurking
Old 04-25-2013, 09:32 PM   #52
EarlQHan
Drives: Subarus
I don't mind lol. Very true. When I interviewed with Cranfield in the UK it was the first time I heard the word pylon used and I was just completely lost at what was being asked. The question was, "How would you design a wing pylon?"
Old 04-25-2013, 10:12 PM   #53
Gunman
We were trying to get SRT to let us go with swan neck pylons for the Viper GT car, they refered to them as "goose neck" and styling didn't like the look. I tried using the term "swan neck" hoping the more elegant swan would sell the idea...still traditional pylons
Some friends at Rollcentre Racing in the UK built this 86, and went with swan neck pylons.
Old 04-28-2013, 04:30 AM   #54
YDNA
YDNA's Avatar
Drives: Raven FR-S
what about something similar to this?
YDNA is offline   Reply With Quote
Old 04-29-2013, 02:22 AM   #55
Hancha Group
Drives: Subarus
We are not going to offer a license plate mounted solution (please see post 35), but rather a tow hook mounted solution so there's no drilling involved and it can be fully removed when you don't want to use the wing.
Old 04-29-2013, 10:55 PM   #56
empower-auto
Kouki-Monster
empower-auto's Avatar
seriously, what wing is this?
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
An introduction to Hancha Group Hancha Group Announcements, Contests, Giveaways 23 05-26-2013 12:56 PM
Hancha Rear Toe Link Hancha Group Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-05-2013 09:18 PM
Hancha Rear Toe Link GROUP BUY Hancha Group Groupbuys 3 03-30-2013 11:21 PM
PTUNING FR-S/BRZ DS-325 3" Single and Dual Cat-Back Exhaust System. Group Buy!! Mrc@ptuning Engine, Exhaust, Bolt-Ons 35 12-10-2012 12:55 PM
Wing or no wing? (rear spoiler) quik1987 Scion FR-S / Toyota 86 GT86 General Forum 123 12-12-2011 07:11 PM
