| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2013 asphalt frs
Amsoil
Did my first oil change today. Used amsoil, factory filter and a dimple magnet drain plug. Engine is noticeably quieter with the new oil. Amsoil is Highly recommended!
#2 |
Drives: 2004 Subaru Forester 2.5XT
Uhhh, congratulations? Did you use the non-API certified Signature Series or the API certified XL/OE line? 0W-20?
-Dennis |
#3 |
Not my first oil change, just this car. I used the signature series
#4 |
Drives: B9 S4/ND2
I've got the 5w30 Signature series sitting in the garage for my next change. Good stuff if you get a deal on it.
#5 |
Drives: Raven Black
When I change out the old conventional oil from my car and replace it with new conventional oil the car is noticeable quieter. Conventional oil is highly recommended!!!
#6 |
Red wine
Drives: Subaru BRZ(R.I.P)
Uhhhh, what? The BRZ/FRS require Full Synthetic motor oil.
#7 |
Drives: DGM BRZ limited
Imma guess he was referring to how basically no matter what brand new oil is better than old oil.
#8 |
Drives: Raven Black
I was poking fun at the OP. and his reasoning for "highly recommending" Amsoil. Doing any oil change after the oil is spent will make the engine feel smoother and run quieter. yes I know Amsoil is great oil..... the FR-S/BRZ doesn't "require" full synthetic. |
#9 | |
Drives: WRB BRZ
By putting a different weight/viscosity oil, the motor might not be able to perform as effiencient as before. 0-20 is what is recommended, so synthetic it is. This is probably gonna turn into another one of those oil threads unfortunately.
In the garage:
1988 BMW E30 M3 2003 Ducati ST4s ABS 2006 Subaru Legacy GT Spec B #444/500 (For Sale) 2013 Subaru BRZ WRB Limited - Acquired 9/15/12 |
#10 |
The "old" oil only had 1500 miles on it. Still like the amsoil!
#11 | |
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#12 | |
There's not a whole lot of difference between the Signature Series 0W-20 and 5W-30. I believe the XL and OE lines are pretty close as well. I would probably choose the 10W-30 between SS, XL, and OE. Personally, I've tried the 0W-30 SS (and have done uoa's) oil and I prefer a more robust oil for a forced induction application. You definitely don't want to go too thin and you don't won't to go thicker than necessary. If you want to run it to around 7,500 miles, my pick would probably be the Series 3000 HDD 5W-30. A very robust old school anti-wear package (high ZDDP) and a good High Temp High Shear of 3.5 cP. There have been some very good WRX uoa's on this oil. At 5k miles oil change intervals or less, the Dominator 5W-20 would be a good choice IMO. It may even be able to go longer with a used oil analysis with a TBN. You can also just call up Amsoil technical support and see what they say. Has anyone done uoa's on FI cars here? -Dennis |
#13 | |
The amsoil dealer and my performance shop said stay 0-20 I got the signature series and I'm now a preferred customer.
#14 | |
![]() Lower NOACK means less evaporation and likely less risk of deposits forming. http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2968339 You should also check your oil level weekly and do a used oil analysis after about 3-4k miles. I wouldn't even change the oil since you may be able to run it longer than that. And go with Oil Analyzers Inc for the uoa. As a preferred customer, you'll pay $17.95 for the non postage paid analysis. OAI includes TBN, oxidation, and nitration for that price. You don't get any of those in a $25 Blackstone uoa. You can order it directly from Amsoil. -Dennis |
| Anyone want 0.65 liters of Amsoil SS 0W20? | Laika | NY / NJ / CT / PA | 0 | 03-31-2013 06:53 PM |
| AMSOil distributors in Aust? | Panman | AUSTRALIA | 4 | 09-18-2012 04:37 AM |
