| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: 2013 WRB BRZ Sport Tech
how would 18x9 or 18x9.5 square set up compare to a 17x9 square setup? thanks
#16 |
Drives: 13 Whiteout
See sig...b/c Racecar!
2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned. Less parking more racing |
#17 | |
Ontario's FT86
Drives: 2016 Lexus GS-F
![]() People don't recommend 18x9 or 18x9.5 because they are generally very heavy, >22 lbs, which can decrease the performance a lot. But if you get light weight rims, it would be ok. 18x9.5 TE37s weight around 17 or 18 lbs IIRC. So in that case, it's actually lighter than a lot of the 17s in the market like rota, xxr, tsw. |
| The Following User Says Thank You to shu5892001 For This Useful Post: | Lverasky (04-20-2013) |
#18 |
Custom User Title
Drives: Asphalt FR-S MT
Are you on stock suspension? I was told that 9's couldn't fit in the front without coilovers.
#19 |
Ontario's FT86
#20 | |
#21 |
#22 | |
Ontario's FT86
I would choose between te37 and tc105. If you can soak up the beans for TE37 then go for it. If not then go with 17x9 tc105s. That was my selection when I ordered rims. |
#23 |
im thinkimg a +35 or +38 offset, dont want the wheels to be sunken or poking, just want the hella flush look!!! i really want to avoid the poke, dont want shit off the tires hitting the side of my car.
#24 |
Ontario's FT86
Yea those offset should be safe for 9 or 9.5 wheels. I would do 35 in a 9 wheel and 38-40 for a 9.5 wheel
| The Following User Says Thank You to shu5892001 For This Useful Post: | DAN_BRZ (04-18-2013) |
#25 |
RedBunny w/ Wing
What offset will fit with stock suspension..if I go with 17x9" square
#26 |
Ontario's FT86
#27 |
RedBunny w/ Wing
If I go with 17x9 +35 square..that is no need to lower the car ..right? I can just stay with stock suspension?
#28 |
Ontario's FT86
| Wheel Directory: ESM 004 17x9.0 +38 | Scott | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 25 | 06-26-2017 04:54 AM |
| Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** | LSD Motorsports | Groupbuys | 246 | 08-29-2013 01:35 PM |
| WEDSSPORT TC105N 17x8.0/17x9.0 and 18x8.5/18x9.5 *** with Special. Ed Sticker *** | RavSpec | Wheels and Tires | 47 | 06-22-2013 11:49 AM |
| FS in FL: Drag DR-31 17x9" Square setup 5x100 (or 5x114.3) +38 | GTB/ZR-1 | Wheels and Tires | 1 | 12-06-2012 07:22 AM |
