alpine, ATL BRZ, ftc~brz, jamesm, King Tut, OrbitalEllipses, sklimo, SmsAlSuwaidi, Sportsguy83, whitefrs
Old 04-18-2013, 11:39 AM   #295
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by lbroskee View Post
only ppl i trust behind my wheel 1. work more then me, 2. are outta town
thats y i've been tryna find a DIY option since July is still far off, but still it's plan B
I'll let you know what I do, but its very probably my solution will not work for you because it will involve either moving the turbo discharge pipe, or getting a new one made.
Old 04-18-2013, 11:44 AM   #296
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
true, but if not im all ears
lbroskee is offline   Reply With Quote
Old 04-18-2013, 12:03 PM   #297
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
BIG Win today!! Swapped actuators for the 5 psi one and FINALLY have a working Wastegate!! Turned up the boost in the MBC, so now boosting around 8 psi. Sent some logs, now waiting for refined tune.
Can you make me a boost curve graph now?
Old 04-18-2013, 12:05 PM   #298
King Tut
NASA SpecE30 Racer
King Tut's Avatar
#2, My overpipe is hitting the frame. (See below pics). Next step is to disconnect the turbo discharge pipe and try and move it higher which will result in the overpipe connecting higher to it and probably clearing the frame completely. It is not hitting it all the time, but in high vibration situations, it hits. As a last resort, I may go and get that Turbo discharge pipe made from 3" pipe and routed to avoid the overpipe issue.
Loosen all the exhaust connections. Stick a pry bar in there where you need more clearance and then tighten everything back down. I had to work with my JDL overpipe and uppipe to get the clearance I wanted as well:
Sportsguy83 (04-18-2013)
Old 04-18-2013, 12:06 PM   #299
Sportsguy83
Drives: Limited BRZ
I haven't forgotten about you!! Next tune John sends me, I'll do the pull.
Old 04-18-2013, 12:09 PM   #300
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Awesome. I am still working on my EBC settings to get the best curve I can. I am almost there.
Old 04-18-2013, 12:12 PM   #301
Sportsguy83
Drives: Limited BRZ
My MBC is kind of weird. More PSI every gear?? Its like doing boost by gear on its own.. LOLLL
7 and change psi in second, 8 + in third almost 9 in fourth and haven't checked more than that.
Old 04-18-2013, 12:24 PM   #302
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That seems very strange.
Old 04-18-2013, 12:26 PM   #303
Sportsguy83
Drives: Limited BRZ
The state in their instructions that you should check PSI at 3rd or 4th, because if you check in 1st or 2nd, PSI will be higher at higher gears, but I don't understand why.... Probably they designed it like that, but what have they done different than any other MBC and why did they do it like that.
I put the universally recommended half hole preload in the WG.
Old 04-18-2013, 12:38 PM   #304
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
If after you adjust the downpipe and overpipe and it still rattles try upgrading your motor mounts. The motor rocking around on the stock mounts will cause it to move. With the mounts all nice and solid it could fix it.
PrimeMotoring is offline   Reply With Quote
Old 04-18-2013, 12:44 PM   #305
Sportsguy83
Drives: Limited BRZ
I installed Perrin mounts last weekend mostly because I wanted to see if it cured this. It didn't, but I'm pretty certain the pry bar below and loosening the midpipe and turbo discharge pipe should work!
Thanks for the suggestion! On another note, I get compliments on the gauge cluster EVERYWHERE I go (well, except for user ft sjo LOL)
Hope everything is going good Mike!!
Old 04-18-2013, 12:51 PM   #306
BRZranger
Regarding the overpipe hitting the frame, running a 2.5" pipe through there was already a pretty tight fit (vs the 3" ). We ended up using the AVO 2.5" over pipe and have not had any issue with contact. But I have the auto which trends to have less engine movement during shifts.
BRZranger is offline   Reply With Quote
Old 04-18-2013, 12:55 PM   #307
Sportsguy83
Drives: Limited BRZ
It IS a very tight fit!!
Ihave the solution pictured in my mind, but the pain in the ass is going out and doing it LOL. Worst case scenario, a new 3" turbo discharge pipe an inch shorter will for sure do the trick.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
BRZranger (04-18-2013), ftc~brz (04-18-2013)
Old 04-18-2013, 02:52 PM   #308
AVOturboworld
It's not the MBC's fault, it has to do with engine load and turbochargers. Turbochargers respond better as the engine load goes up. The higher the gear, the higher the engine load due to gearing. Same reason a clutch won't hold in 6th gear, for instance, but would in 4th.
So generally, you'd see the turbo reaching peak boost in 1st and 2nd gear around 3000-3500 (assuming you even have time to pay attention), then dropping to 3000 in 3rd, then 2500-2800 in 4th, then even quicker in 5th/6th.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
Chewie4299 (04-20-2013), Sportsguy83 (04-18-2013)
alpinewuzhere, better than sti, custom turbo kit ftw, epic brz build, ftc~brz, gtx30 goodness, its certainly a car, king tut, nocornnocare, sportsguy83, superior orbital fellow, thewheelsonthebusgo
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 05:56 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 11:35 PM
Have You Had A Dream About Your Car? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 7 01-29-2013 03:38 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 08:10 PM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-13-2012 12:35 AM
