#183 |
Drives: Perrin/VORTECH Supercharger TestBRZ
I am glad you are enjoying the drift scene, that is awesome
Youre just feeding my point: should the car you purpose build for low grip be a daily driver? can you really control a low grip car in an emergency manuever, and will this be a detriment or an asset to your defense should you be involved, heaven forbid, in a tragic accident, and a lawsuit? that is what I mean by safety. There is nothing wrong with drift builds, that is what this car is for! I commend you for getting it on! I think your well thought out pics demonstrating its low grip at the track are great. This very facet of your build also helps most PI lawyers when it and if it comes to that on public streets(have family in law) nothing like a car thats been modded that crashed into another one. bigger the wing the better when its jury time. Insurance Adjusters field day. Lets stop for a moment & demonstrate unsafe vs safe tho before we even venture down the laptimes road okay? 1-Lets take your -5 camber daily drive drift car and do some 60mph to zero brake distance tests. Not only will a properly setup car out handle 'your setup' in corners and G force holding, um thats why youre DRIFTING , it will out do 'your setup' in power application and delivery on 0-60 acceleration, and if thats not enough, then lets test 60-0 brake distance, where the liability really counts, and I will show that factory camber with the same wheels and tires on YOUR car will perform better numbers than your -5 settings 2-lets record that data,post it online in this thread, shall we? all test by a 3rd party for measurement, we'll install a nifty doo-dad that will measure your in car Gs too. 3-lets take a factory car & alignment on your very same car and perform same stopping tests, not extra stiff in the rear for drift, I bet your setup looses, on your own car, in each and every category. You cant argue with faster, holds more Gs brakes better or can you? Its cool that your having fun, power to you, for real there. 4-after a major accident lets see how liability plays out in your drift car on a road incident setup out of factory spec, vs same accident your car not on 215s, stretched(lawyers field day) fwiw, as I am adding power to my car, I am having to dial back camber(-2 is too much for laying down the power I have on exit) on my rear end, but I am not trying to build a drift car. I'm also not advocating anyone run a setup that makes their car less safe on public roads, and be proud of it. I do it too, when I drive to the track with pads that arent warmed up, etc, so I dont want to pretend I'm any better than you-we car guys do all the same idiotic stuff, generally. Its great that you enjoy drifting and I totally dig your pictures, time at the track and your build. We can argue that high grip is safer than lo grip and you can tell me otherwise, I have no problem with you drifting, just supports safety/grip/adhesion points further tho! hella camber is hella less grip, stopping, going, carving. period. Enjoying lo grip is fine, lets not call that a safe setup if it proves worse result in all test categories... I've never related to making a machine grip worse, stop worse and accelerate worse, but wholly relate to you enjoying your car at the track any way you choose. That is our common denominator, and its all we need to be here in this forum. 13 years from now when you have alot more assets to loose, this nonsensical safe BS stuff will matter more, I promise CAPS ON WHY? IT WOULD BE JUST AS IRRESPONSIBLE FOR ME TO USE MY SLICKS ON PUBLIC ROADS(and why I have two sets of wheels, they too are a low grip tire till they reach the right heat range. As a tidbit of fact here,any of you who are 27 or younger this year needs to know I was 'drifting' when I was 13myself, on dirt tracks, at that time, you were in diapers) rest of you enjoy scrapin, stancin, and the like.. Keep it safe on the public roads...peace. Last edited by Huehuecoyotl; 04-17-2013 at 06:43 PM. |
| The Following 5 Users Say Thank You to Huehuecoyotl For This Useful Post: | 6-Shift (04-18-2013), ATL BRZ (04-18-2013), HotLeopardMama (04-22-2013), schlomo (04-18-2013), Sportsguy83 (04-18-2013) |
#184 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
[ame="http://www.youtube.com/watch?feature=player_embedded&v=EgY9SoWfwyM"]uykrtyh - YouTube[/ame]
| The Following 3 Users Say Thank You to ATL BRZ For This Useful Post: |
#185 |
SLOW BRZ
Drives: 2013 328i xDrive; 2013 BRZ
What if I tell you, you can drift a stock brz? Would that blow your mind?
| The Following User Says Thank You to Outlawstar98 For This Useful Post: | Jive Turkey (04-17-2013) |
#186 | |
Drives: 2006 STi
| The Following User Says Thank You to SLICVIC For This Useful Post: | HotLeopardMama (04-22-2013) |
#188 | ||
Drives: BRZ/E30/IS300/LS400
All of my cars drive great, I'm not going to argue whether one car will outhandle or out brake another because that's irrelevant. My "unsafe" drift cars will outhandle and out brake my previa, does that mean my previa is unsafe for the road? No. I've been in accidents with cars set up like this and never had issues with insurance, but then again, I've never heard of anyone call one of my cars unsafe, my insurance agent just asks how I keep my bumpers intact. My E30 and SC, were both made solely with the intention of being drift cars, and to get enough traction to handle higher horsepower... Neither one had over 3 degrees of negative camber in back, both had about 4 degrees in front, which is optimal for grip... Are you going to argue that negative camber in front is detrimental for handling? I won't argue that anything more than -2 or -3 in the rear will hurt the handling of a car, but make it unsafe? Hardly. 13 years from now what assets will I have to loose? Like 4 cars? A house? Because I've got all that now... Maybe you consider children an asset? I wouldn't drive one of my cars if it wasn't safe, but at the same time I have been known to street drift, which I suppose is not keeping it safe on public roads... No worries here though. Quote:
![]() The lexus has had 3 different bumpers on it in the last 7 years... With paint that's probably about $1500... Fenders haven't been changed.
RISKY DEVIL // ILL PHOTOGRAHY
#189 |
Drives: White Out FR-S
[ame="http://www.youtube.com/watch?v=VLhZ52vVK-I"]B.o.B - Haterz Everywhere [Feat. Rich Boy] (video) - YouTube[/ame]
| The Following User Says Thank You to ST185RC For This Useful Post: | SLICVIC (04-17-2013) |
#190 | |
I stand corrected, you probably dont fall into the category of folks highlighted in the 4rth video I posted, and theres clearly some logic, sensibility to your response. It aint between you and me man, I'm just saying what an old fart like me gonna say..like I said, we have a common denominator, and thats good enough for me. I get drifting. We cool, Ill. I still dont get too low,and too slow... |
#191 |
when people talk about dangerous and unpreditcable, this is what they are talking about
[ame="http://www.youtube.com/watch?v=UIueDNmSsow"]Lexus IS300 (Toyota Altezza) spins out and flips a truck over - YouTube[/ame] |
#193 |
Drives: Subarus
To the owner of the car, the wheels and rear stretch is not my cup of tea. But hey, it's your car.
Personally, I think balance is the key. Why does it have to be form > function or function > form. When done properly, why can't form = fucntion and function = form? I'm guilty of having run a small stretch (265/35 on a 10.5", 235/40 on a 9.5") on my track car because it reduces sidewall flex. My track car is also about 3" lower than factory and also runs -4 degrees of camber in the front and -2.5 in the rear because that's what worked for me. Ill Roller has plenty of experience around drift cars and knows what works and what doesn't; he also knows what he likes and does not. He tends to err on the side of form, whereas I tend to err on the side of function. Yet we both maintain balance. Please check the suspension model thread http://www.ft86club.com/forums/showp...3&postcount=69. The video backs up my point that they tend to understeer at entry. Granted that car probably only made like 90 HP (at best) lol. ![]() ![]() ![]() ![]() ![]() See, why does it have to be one or the other? I hate cars that are all about looks that don't work, but I also hate cars that are all about performance and look like crap. A well built car will be both good looking and work well. Last edited by EarlQHan; 04-18-2013 at 08:13 AM. Reason: pictures |
| The Following User Says Thank You to EarlQHan For This Useful Post: | SLICVIC (04-17-2013) |
#194 |
I don't dig the herrafrush look. So... in my case..
I prefer my cars to be fitted. Function>Form But if its cool knowing there's a community for those who like it. Just not something I'd like for my car. lol
I am the Ice Queen.
Logic > Emotion ┬──┬◡ノ(° -°ノ) Yashio Factory Pink adds +10HP to anything. TOYOTA FT-86 ![]() Last edited by Giccin; 04-17-2013 at 09:01 PM. Reason: added more |
| The Following User Says Thank You to Giccin For This Useful Post: | DaJo (04-18-2013) |
#195 | ||
#196 |
Drives: Subarus
The M3 is a street car, the Koenigsegg is also a street car, but point taken.
| What function can it be used for, the idle button place | yuli8466 | Cosmetic Modification (Interior/Exterior/Lighting) | 50 | 01-29-2013 03:17 PM |
| List of plug & play Recaro seats compatible w/heat function? | [Cyanide] | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 12-10-2012 11:50 PM |
| AG.Function Forged Wheels | Eric@GetYourWheels | Wheels and Tires | 22 | 08-01-2012 12:16 PM |
| In Stock Form: | hybrid4g | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 07-20-2012 06:44 AM |
| Roofline: Form over function. | ft86cbx | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 04-24-2011 12:27 AM |
