Old 01-22-2013, 09:32 AM   #15
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Coldest its been since owning the car this morning. About 10*F. Car started fine, immediately into cold idle and after a few seconds of running it backfired through the intake several times, or at least thats what it sounded like. Never touching the throttle. Ran fine after that and on the trip to work.
FRSFirestorm is offline   Reply With Quote
Old 04-13-2013, 04:55 PM   #16
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I've experienced this also. High load, low rpm pop. It can sometimes be replicated by coasting then stabbing the throttle when in 2nd or 3rd at 2,000rpm and below.
HRTROB is offline   Reply With Quote
Old 04-13-2013, 07:44 PM   #17
CTB727
Drives: 2013 Subaru BRZ
I've had the same problem happen to me only once at ~3,000 miles, during cold start. I'm now close to 5,000. Completely stock too.
CTB727 is offline   Reply With Quote
Old 04-14-2013, 12:36 AM   #18
romin
romin's Avatar
Drives: BRZ, STI, 535, Tiffin Allegro
I went to the dealership for an oil change and a routine inspection. While I was there they pointed out that I had this firecracker noise coming from my intake when the throttle was lifted off of idle. I had never heard this sound before but I had cleared a P0315 CEL a couple times.
To me it seemed that the CEL and the misfires were related so I upgraded all four coils and haven't had a problem since.
romin is offline   Reply With Quote
Old 04-14-2013, 02:50 PM   #19
g0lden
Drives: 2013 Scion FR-S Argento
Only time any of my 20 odd cars backfired through the intake was caused by improper timing.... seems quite odd on a new car.
g0lden is offline   Reply With Quote
Old 04-15-2013, 11:13 PM   #20
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Injector malfunction? These Direct Injectors having seal issues?
Coheed is offline   Reply With Quote
Old 04-15-2013, 11:22 PM   #21
FirestormFRS
I don't think it's a seal issue. Seems it's a no close issue. Probably not the direct injectors though, most likely (from experiance) it's the port injectors not fully closing.
FirestormFRS is offline   Reply With Quote
Old 04-16-2013, 08:29 AM   #22
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by Carwhisperer View Post
My injector had a leak from what the dealer found with the PO351 CEL.. the #1 cyl wasn't functioning correctly. That's going to most likely be the issue if you hear the new "intake backfire" issue people are having.
yup, most of the intake backfires i have seen were a result of a leaking port injector. My M3 used to do it on warm starts.... if it sat turned off long enough the fuel system would loose pressure and the leak would stop and the gas that was sitting behind the closed valve would evaporate so it would only do it on warm starts.
Exhaust popping is due to over run fuel lighting off in the exhaust and is nothing to be concerned about. If you want to hear it more, get a high flow 2ndary cat and an axle back or catback exhaust.
Old 04-16-2013, 08:50 PM   #23
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
The Teflon Seals on the Direct Injectors are leaking. Take it to the Dealership and have the tech call Technical Assistance / FTS. Toyota IS aware of the issue.
LavosTRD is offline   Reply With Quote
The Following 2 Users Say Thank You to LavosTRD For This Useful Post:
Laika (05-06-2013), peachch (04-21-2013)
Old 04-21-2013, 08:04 AM   #24
peachch
Drives: White 86 Sport Plus
Which parts should I replace?
peachch is offline   Reply With Quote
Old 04-22-2013, 10:23 AM   #25
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
Take it to your dealer.
Old 05-03-2013, 11:16 AM   #26
romin
romin's Avatar
A friend's engine was recently inspected and the dealer found an injector o ring leaking fuel. He said heat could have caused it to melt or it may have been defective.
Old 05-03-2013, 01:08 PM   #27
peachch
Mine also has the same issue. O-ring of 1st cylinder is completly gone. The picture is 1st and 3rd direct injectors. I just replaced all o-rings and insulators. I did not have chance to drive yet, but popping when cold start has gone.
The Following User Says Thank You to peachch For This Useful Post:
romin (05-16-2013)
Old 05-03-2013, 01:37 PM   #28
whtchocla7e
Drives: 2013 FR-S Hot Lava
Guys,
Are your popping sounds similar to mine?
[ame="http://www.youtube.com/watch?v=Ky_vDK4ePHI"]FR-S cold start - YouTube[/ame]
Live to drive another day
whtchocla7e is offline   Reply With Quote
The Following User Says Thank You to whtchocla7e For This Useful Post:
cobrabyte (06-06-2013)
Anyone heard any loud popping? Kimsey47 BRZ First-Gen (2012+) — General Topics 103 07-30-2013 10:27 PM
SOUND LEVEL TO LOW!! Not loud enough Hbomb Electronics | Audio | NAV | Infotainment 24 12-21-2012 10:02 AM
How loud? djliquidsteele Engine, Exhaust, Transmission 1 10-17-2012 11:43 AM
is anyone's frs competely free of the issues that seem to be popping up pr086 Scion FR-S / Toyota 86 GT86 General Forum 46 08-22-2012 05:31 PM
The number 86 popping up everywhere.. CSSM Off-Topic Lounge [WARNING: NO POLITICS] 19 06-19-2012 12:15 PM
