Old 03-13-2013, 11:03 AM   #1
automatic
Drives: WRB BRZ
USB/Audio port shorting out iPhone?
Something strange happened with my BRZ the other day...
My friend and I were in the car and we started listening to music off his iPhone through an FM transmitter which we always used. Then I realized that I had a USB/Audio port to iPhone cable which we plugged into his iPhone.
Music started playing as expected but after about 5 minutes, the phone became disconnected and we tried to connect it again. It failed 2 more times so we tried to play music from his phone through the iPhone speakers. It didnt work. His phone only charges through the wall charger and not any other device such as a computer.
We talked about the possibility of the car shorting out the phone somehow. What is the feasibility of this claim? If it was somewhat feasible, how would I even get Subaru to diagnose this? They would need an iPhone to test on, which could possibly break...I doubt they have an iPhone at their disposal to test it on...If it is somehow determined that the car broke the iPhone, would they even compensate my friend for his broken one?
On a side note, another strange thing happened with my iPhone a day before this happened. I had it plugged into my computer...I then touched my iPhone, got shocked by it and my computer turned off.
Can anyone chime in on either situation?
automatic is offline   Reply With Quote
Old 04-10-2013, 03:49 PM   #2
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
When I bought my new FR-S in Feb 2013 my USB port didn't work from the get go. I had the technicians try various components to find the issue. They ended up ordering a new port and installing it free of charge since the car is under warranty. I would just go have it replaced. I've heard from a few others that they have had the same or similar issues.
shiro is offline   Reply With Quote
Old 04-10-2013, 04:37 PM   #3
Foobar
SLO NO MO
Foobar's Avatar
I suspect his iPhone had some flaky grounding problem to begin with given your shocking experience with it on your computer. I would be surprised, in any event, if Subaru compensates for this as there's no way to prove it was done by the car, unless the test the head unit and determine there's a short there.
Even if there was a short, I would think the iPhone itself has some ground fault type protection in that USB connection, no?
Old 04-12-2013, 11:10 AM   #4
automatic
Drives: WRB BRZ
I would be surprised if Subaru compensates as well because theres really no way to prove it except use another iPhone....and I dont really want to use mine to test it incase it breaks.
I'm not sure about the ground protection. I just found it odd that his phone shorted out, and my phone turned off my computer after a shock. Not really knowledgeable about the inner workings of electronics.
FR-S Audio Build - SQ (Illusion Audio/Mosconi) DekaMori Electronics | Audio | NAV | Infotainment 28 04-17-2013 05:34 AM
BRZ & USB Port brz007 Electronics | Audio | NAV | Infotainment 14 04-14-2013 09:06 PM
Does the BeSpoke audio system require an Iphone? Cj_Staal Electronics | Audio | NAV | Infotainment 4 02-17-2013 01:13 AM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 10:45 PM
is the BRZ audio compaitable with iphone 4S iOS 5.1.1 wu_dot_com Electronics | Audio | NAV | Infotainment 14 06-08-2012 03:32 PM
