Old 04-08-2013, 10:19 AM   #365
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Sounds good. Then we all get to dyno on your freshly installed wife allowed dyno right?
I can arrange a dyno day in PHX for us all to enjoy 1500foot dynos on the same high end MAHA dyno I use...on 91 crappy AZ pump gas and see what the level playing field looks like, lets pursue the road trip to sedona~!
Huehuecoyotl is offline   Reply With Quote
Old 04-08-2013, 10:21 AM   #366
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I will bring 10 gallons of Florida 93 octane instead, haha.
Old 04-08-2013, 10:22 AM   #367
ft_sjo
Drives: GT86
You do realise dynos correct for altitude, so there's little point in mentioning it?
Old 04-08-2013, 10:28 AM   #368
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
Chris, unless you are running slicks, VHT will actually not help. It might actually hurt your launch by causing wheel spin. Superheating street tires doesn't exactly have the same effect as it does on drag tires.
Brian@Vortech is offline   Reply With Quote
Old 04-10-2013, 11:36 PM   #369
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
I think by now everybody is aware of what happened to Gem's unit. We still don't know a root cause but overfilling the unit with fluid is on the table and Vortech says many times this is bad.
Chris and I checked our units and we think ours are overfilled. Unfortunately its very hard to see the red fluid on the un-crosshatched portion of the dipstick. Using a towel we could see we were over.
The following picture is what we drained (plus the ton we got on a towel) to get the fluid to go down enough to leave 3mm from the full mark. I think this is a safe level to be at, the fluid should expand when it gets hot.
Keep in mind a full fill is 4oz.
20130410-VortechDrain-001 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
Old 04-10-2013, 11:57 PM   #370
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
^ Is that on the fill from the factory?
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 04-11-2013, 12:00 AM   #371
F1point4
Photo Specialist
F1point4's Avatar
Good question. No that was taken out of the 2nd fillup. We shipped our units to Vortech sans fluid so we had to fill them up when we got them back.
The Following User Says Thank You to F1point4 For This Useful Post:
civicdrivr (04-11-2013)
Old 04-11-2013, 07:44 AM   #372
F1point4
Photo Specialist
F1point4's Avatar
Gem, we appreciate you testing and bringing this to our attention. I'll take their advice into o consideration and jack up the rear and see if more comes out.
High temps to worry us too. How are you measuring them?
Old 04-12-2013, 02:53 PM   #373
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
Geez it's felt like a lifetime since the car has been on the dyno. The Viper is out of here so I'm going to throw it up there between now and Monday.
Viper btw with just a nitrous system and 100 shot yielded 719hp to the wheels and even more torque IIRC.
PhastekSport is offline   Reply With Quote
The Following User Says Thank You to PhastekSport For This Useful Post:
Sonolin (04-12-2013)
Old 04-12-2013, 06:14 PM   #374
Sonolin
Nice that thing must be a hoot to drive
Sonolin is offline   Reply With Quote
Old 04-12-2013, 07:17 PM   #375
F1point4
Photo Specialist
F1point4's Avatar
Did a long distance drive today.
247.6 mi
83F on the car thermometer.
Clear skies with sun beating on pavement
Average speed 85-90. Did 100 a few times
8.2 gallons of fuel used (thanks Torque app)
Oil temp read 240F
Map 3
30.2 mpg!!!! Can have FI and cake too!
The Following 3 Users Say Thank You to F1point4 For This Useful Post:
Pete (04-12-2013), RedAlert (04-12-2013), Sonolin (04-12-2013)
Old 04-12-2013, 07:55 PM   #376
2forme
247.6 mi
Oil temp read 240F
Map 3
Fill up to be sure
The Following User Says Thank You to 2forme For This Useful Post:
civicdrivr (04-12-2013)
Old 04-12-2013, 08:23 PM   #377
F1point4
Photo Specialist
F1point4's Avatar
Originally Posted by 2forme View Post
Fill up to be sure
Here are pump numbers
249.1 mi
8.839 gallons pumped
28.18 mpg. Still very high!
2forme (04-12-2013), RedAlert (04-12-2013), Sonolin (04-12-2013)
Old 04-14-2013, 07:57 PM   #378
F1point4
Photo Specialist
F1point4's Avatar
Return trip stats.
These are pump numbers
243.3 mi
8.889 gallons pumped
27.37 mpg
It said 83F on the car thermostat, not very humid. Kept it a bit more chill going 75-85 this time.
I think its safe to say we can still get good highway MPG numbers with this kit without having to drive it gently.
Oil temp
Used the torque app to keep an eye on things while I was driving back and forth. This time there isn't much science behind this text, just what I saw.
Oil temp is directly proportional to engine RPM. Continuously driving at 4000 RPM the oil temperature settled at 240 F. This is about 90 MPH. When going to 100 or backing off to 80, you can see the temp go up and down relatively quickly.
Since the temps change so quickly as you pickup or left off, I suspect the cooling system in this car is very efficient, even with a intercooler in the way of the AC condenser and radiator.
BTW i'm still using Amsoil 0W-20 without an oil cooler.
I was just speeding down the highway (90+ is a bit fast to be calling it cruising) keeping it around 4000 RPM in 6th. Therefore I still consider this to be daily driving the car. 240F is a bit hot in my opinion for daily driving so I'm prioritizing installing an oil cooler now. Just have to figure out placement
I also just recieved cases of Amsoil 5W-30 for myself, @Chris@Phastek, and @Pete, so we'll be using that too to help with lubrication under engine stress.
The Following 2 Users Say Thank You to F1point4 For This Useful Post:
Pete (04-14-2013), PhastekSport (04-14-2013)
ft86, perrin, phastek, supercharger, vortech
Visconti Tuning Vortech STG1 & STG1+ Supercharger Kits! Visconti Forced Induction 67 04-03-2013 03:56 PM
Vortech Supercharger Kits @Pure Automotive Performance Pure Automotive Forced Induction 25 01-15-2013 11:48 PM
