Old 04-09-2013, 12:51 AM   #141
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by Chaetagnath View Post
If the dome light is working fine, and the line is going directly from the tap to the switch, then it must be the tap didn't work then. What kind of tap did you end up going with? Unsnap the tap and inspect the wire, it should cut through the rubber all the way to the wire. Try again either with a lower gauge tap, or try to really clamp it tight, and be sure the wire is sitting right in that metal groove. If this is your first time tapping you may want to practice on some spare wire first to get the hang of it.
So my diagram is correct tho?
And after it didnt work i didn't use a tap, we held wire to wire so it was a clear connection being made. That's wuts weird. Imma try and get my friends tester to see for sure wtf is up
lbroskee is offline   Reply With Quote
Old 04-09-2013, 01:10 AM   #142
Chaetagnath
Drives: Whiteout FRS
Diagram looks fine. Should work. By wire to wire do you mean you unplugged the connector, and stuck the wire in the pin for the pink wire? If so....be like super careful....that's exactly how ecus get fried if even a strand of wire crosses to the green pin.
Chaetagnath is offline   Reply With Quote
Old 04-09-2013, 01:15 AM   #143
Chaetagnath
Seriously, don't try using a tester on the connector itself. You most likely will fry the Ecu. Just plug it into the dome light assembly and turn it to the door switch. If the dome light works fine with the door open, then it is your tap, or the wire running from the tap, or the connector at the switch.
The Following User Says Thank You to Chaetagnath For This Useful Post:
lbroskee (04-09-2013)
Old 04-09-2013, 01:22 AM   #144
lbroskee
lbroskee's Avatar
ok ill test that out this weekend. just out of curiousity tho. since it sends the door signal too the door lights and i have the kit that has the wires runnin from dome to floors, why can i get the door signal from that wire since i know it clearly has power when the door is open
Old 04-09-2013, 01:48 AM   #145
Chaetagnath
If I read this right, you have the phasetek kit with the connector which slides into the bulb slot, and you want to know why you cannot simply run the ground from that to the switch so you don't need to tap the dome light? You can do that i think. I chose to tap the pink wire instead so that my floor well lights are completely independent of the dome light.
Old 04-09-2013, 02:09 AM   #146
lbroskee
lbroskee's Avatar
ya i want ur setup, but what i ment was since the pink sends the door signal to the dome, and that wire sends it to the footwells (OEM phasetek way), shouldnt i be able to just tap that instead of pink so as to not risk frying my ECU?
Old 04-09-2013, 03:52 AM   #147
joergasm
joergasm's Avatar
Drives: Subaru BRZ 2013 - SWP 6MT
Originally Posted by boredom.is.me View Post
Sorry for the crap pics. This was quick, simple, and did not require any kind of splicing or soldering to any wiring on the car. I simply tapped a fuse slot, then ran a cable under the head unit area.
Attachment 24391
Attachment 24392
Attachment 24393
Attachment 24394
Attachment 24395
can you PM what you did in detail + any pics you might have?
Thanks!
Also what stripes did you use? or what did you use for the lights?
joergasm is offline   Reply With Quote
Old 04-09-2013, 09:55 AM   #148
Chaetagnath
The way the oem phasetek is set up the outgoing wires are only connected when the dome light is switched to door or on. So, yes you can use the ground wire from that setup, but the footwells will only come on when the dome light is on. (Well at least the door open part of it). To get the floor well lights to work independently of the dome light when the doors are opened you have to tap the pink wire.
Old 04-09-2013, 05:21 PM   #149
lbroskee
lbroskee's Avatar
Can I tap the pink at the bottom of the a pillar by the harness instead? Seems easier and less wires to run
Old 04-09-2013, 05:56 PM   #150
Chaetagnath
Yes, that should work just fine.
Old 04-15-2013, 06:23 PM   #151
lbroskee
lbroskee's Avatar
Some are on all the time power, some are ign/acc only power. This photo is lousy, but I believe the slot with the arrow is only on when the key is in and turned.
finally got this all setup, but i dont recommend the ignition route. it's great since ur footwells will only use the stay on method when the key is in, but they dont work as door lights unless the key is in either. so i'd recommend sticking with the always power way and just dont be stupid and leave them on.
o and i found my issue. i was tapping the pink at the bottom of the harness, but it was the wrong pink (dark pink) didnt see the light pink in the back till today lol
Old 04-15-2013, 06:57 PM   #152
Chaetagnath
Awesome! Glad you got it all sorted out.
lbroskee (04-16-2013)
Old 04-15-2013, 08:29 PM   #153
JK_Fade
Drives: Black 13 GT86
Originally Posted by MrTranxD View Post
I did mine for about 10 bucks lol. And its wired to a switch so i can turn it off and on when i want.
where did you buy ur led and switch?
how long did it take to DIY?
thanks
JK_Fade is offline   Reply With Quote
Old 04-16-2013, 05:10 PM   #154
MrTranxD
MrTranxD's Avatar
Drives: Scion FR-S
thanks
Bought my leds from ijdmtoy. bought some cheap switch from home depot. took me about an hour honestly. taking apart the center consule took me the longest. just tapped into the cigarette lighter for power.
2013 Ultramarine FR-S 6MT
MrTranxD is offline   Reply With Quote
Differences In Types of Headlights/Lighting Asphalt Cosmetic Modification (Interior/Exterior/Lighting) 7 02-21-2013 08:49 AM
HID_Powerhouse offers HID kits and LED lighting for your FR-S/BRZ KI_ZN6 CANADA 2 07-27-2012 06:13 PM
interior lighting? fistpoint Scion FR-S / Toyota 86 GT86 General Forum 2 05-09-2012 02:52 AM
Stupid girl 2 foot driving GenkiElite Off-Topic Lounge [WARNING: NO POLITICS] 31 07-23-2011 09:33 PM
How much do you like heel-toeing or left foot braking? USMCMike Other Vehicles & General Automotive Discussions 20 01-15-2010 05:20 PM
