Old 04-08-2013, 01:17 PM   #1
jeebus
Steering wheel not centered...
OK, so I had my BRZ on the alignment rack for the 4th time this weekend, lol. Each time it has been for valid reasons, btw. This time I was getting my toe where I wanted it after my RCE spring install. I had 0 toe set in the front and 1/32 toe-in per side in the rear.
But I noticed that my steering wheel is off center while driving straight. Not very far off center, it's very very slight. Maybe 1/4" or so, if that.
I have two questions: 1. Does this matter? I have to wonder if it affects the yaw sensors that effectively control the power steering. 2. Can I center it myself without throwing off the alignment?
jeebus is offline   Reply With Quote
Old 04-08-2013, 01:22 PM   #2
schtebie
Drives: CBS BRZ Limited
Might be a good idea to take it back to where you had it aligned and make sure the wheel centered during the alignment. I had a similar issue and it was driving me crazy because I swapped steering wheels to one with a slightly smaller diameter.
schtebie is offline   Reply With Quote
The Following User Says Thank You to schtebie For This Useful Post:
jeebus (04-08-2013)
Old 04-08-2013, 01:34 PM   #3
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
Our cars have a steering angle sensor so if it was an issue the abs light would trigger. If you need to do a zero point calibration and see if that helps. Alignment sounds good but if you are having trouble sleeping over a very sligh off center problem I would just take it somewhere else. Keep in mind you can't always get a steering wheel to be exactly perfectly centered. Best bet is to do the zero point.
20valvewynn83 is offline   Reply With Quote
The Following User Says Thank You to 20valvewynn83 For This Useful Post:
jeebus (04-08-2013)
Old 04-08-2013, 02:18 PM   #4
CSG Mike
CSG Mike's Avatar
If it's not pulling and it doesn't bother you too much, don't worry about it. Do you have a printout from your last alignment that you can post so that I can verify that you have no thrust that might cause wear from scrub?
-Mike
Ammunition (03-22-2019), jeebus (04-08-2013)
Old 04-08-2013, 03:44 PM   #5
jeebus
-Mike
I didn't get a printout this time. I was standing at the machine while it was being done and just letting him know when the toe was where I wanted it. My last alignment felt great, but I figured the toe was probably off since I did the springs. Nothing was really that far out. Had the pull the toe out a bit on one back wheel (it was at 5/32 in) and one front had a pinch of toe-in, the other front was already at 0.
Old 04-08-2013, 03:49 PM   #6
jeebus
how do you do the zero point?
Old 04-08-2013, 03:59 PM   #7
CSG Mike
CSG Mike's Avatar
If you have uneven toe on the axle, it should be pulling to one side.
I think by zero point, he means where the ECU reads steering angle to be zero. You can get the reading via OBD2.
Old 04-08-2013, 04:11 PM   #8
jeebus
It wasn't pulling before and it's not pulling now either. I looked up the zero point thing, not sure if our pin out is the same as the other Toyotas I see guides for though.
Old 04-08-2013, 04:51 PM   #9
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
If my wheel was off-center it would bug the living piss out of me.
The Following User Says Thank You to SloS14 For This Useful Post:
Ericc B (04-08-2013)
Old 04-08-2013, 04:52 PM   #10
CSG Mike
CSG Mike's Avatar
The wheel on the CSG BRZ always ends up "not straight" after a track day on a fresh alignment and set of tires, but it never pulls. I'm usually OCD about stuff like this, but I recommend that we leave it alone to see if it causes any issues (strictly informational), and it hasn't.
Not sure on pinout, but we're reading steering angle via OBD2 reader on a datalogger.
Old 04-08-2013, 04:58 PM   #11
jeebus
Good to know.
I haven't had my wheel end up this way after hard AutoXes. I did, however, have to get two wheels rebalanced after the last AutoX because I wore them funny enough and/or threw some weights.
Old 04-08-2013, 05:56 PM   #12
20valvewynn83
You need to take it into a dealership or anyone that has a scan tool with that capability
Old 04-08-2013, 08:02 PM   #13
jeebus
I've seen a handful of guides that just require shorting a few pins on the OBD2 port. I might just have to investigate this direction...for the good of us all.
The Following User Says Thank You to jeebus For This Useful Post:
20valvewynn83 (04-08-2013)
Old 04-08-2013, 08:17 PM   #14
CSG Mike
CSG Mike's Avatar
if you come up to OC, I can help you find it (although it wouldn't really do any good...)
WTB: Stock steering wheel (wheel not airbag) mobybrz Interior Parts (Incl. Lighting) 2 09-11-2014 03:23 PM
steering wheel help ft86me DIY (Do-It-Yourself) Guides 3 04-22-2013 05:26 AM
Steering Wheel Help switchlanez Cosmetic Modification (Interior/Exterior/Lighting) 12 03-22-2013 10:32 PM
Steering Wheel Off-Centered dco107 Scion FR-S / Toyota 86 GT86 General Forum 14 03-22-2013 05:51 AM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 01:16 AM
