Old 03-22-2013, 03:52 PM   #1
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Steering Wheel Help
Has anyone replaced their steering wheel? I spoke to a service advisor and they said it would require recalibrating the wheel. I think that's BS because per my understanding here there is just one way the steering wheel bolts on with no room for adjustment. Also, is it true that it's held on with just one center bolt? And I guess the airbag absolutley needs to be removed in order to replace the steering wheel, huh?
Old 03-22-2013, 03:54 PM   #2
DSOmegaX
DSOmegaX's Avatar
Yes airbag needs to come off. I think there's more than 1 bolt? I'll see. I'm replacing my steering wheel soon as well. I don't see why the wheel would need to be realigned
@dsomegax.cars
Old 03-22-2013, 04:06 PM   #3
OrbitalEllipses
Drives: Attitude
Airbag has to come off. Watch out for the clock spring, if you don't align it properly you'll lose ABS and TCS/VSC.
Old 03-22-2013, 04:09 PM   #4
switchlanez
Do you have more details on this clock spring? Where is it located/what's it look like/would I still need to align it if I can avoid touching it?
Old 03-22-2013, 04:21 PM   #5
OrbitalEllipses
Drives: Attitude
http://www.ft86club.com/forums/showp...9&postcount=22
http://www.ft86club.com/forums/showp...0&postcount=13
Got a shop manual?
Old 03-22-2013, 04:29 PM   #6
AtlasMick
Drives: FR-S 2013 Asphalt
Older models of cars, (without airbags), usually just had a center cap that covered a bolt to the steering column. That is just one bolt, and you can improperly align the steering wheel if you reinstall it incorrectly. If you are going to swap the whole steering wheel, including the airbag system then that will have to be removed. You can use a sharpie to mark where the very top of your steering wheel is to align it without its replacement.
However, if you are just replacing the outside part I think our vehicles have a couple bolts holding it to a plate behind the airbag that is in turn bolted to the steering column, meaning you only have to take a couple bolts off and no messing with the steering column bolt is required,.
AtlasMick is offline   Reply With Quote
Old 03-22-2013, 05:02 PM   #7
switchlanez
I don't have a shop manual but I'm starting to think I won't be messing with the clock spring if I don't need to remove the airbag mount (just removing the stock airbag, replacing the steering wheel, and reusing the stock airbag).
Yes, I would be doing the latter replacing the outside rim and keeping the stock airbag. So the wheel bolts onto the airbag mount and I'm guessing the airbag mount is the piece which would require re-calibration for the clock spring. Since I won't tamper with the airbag mount (just will be removing the airbag, not the mount), no re-calibration of anything would be necessary, yeah?
So that center bolt... I don't want to touch that then? I still wonder if I can remove the outer rim of the steering wheel by removing those two bolts you are talking about without removing the stock airbag.
Old 03-22-2013, 05:10 PM   #8
NemeGuero
gotta make sure you keep the spline teeth alignment the same. if you do that, you won't need to recal anything.
NemeGuero is offline   Reply With Quote
Old 03-22-2013, 05:31 PM   #9
AtlasMick
^^ this is what you have to keep aligned, the teeth are on the steering column if you take that bolt off, which you are saying you will not do.
I have seen the airbag removed with the steering wheel still attached. After removing bolts/clips? keeping it on it is just unplugged *make sure you detach the negative battery post and leave it off for at least 15 minutes. I do this to avoid blowing the bag, it will allow the capacitors that fire the airbag to fully drain (it won't take the full 15 but just to be EXTRA safe since they are pricey.)
Old 03-22-2013, 05:43 PM   #10
switchlanez
Yes, I would just be replacing the outer steering wheel and reusing the stock airbag. So from what I gather, I would need to remove the airbag to be able to unbolt the steering wheel from the airbag's "mounting plate" via two or more bolts/clips (NOT the center bolt which keeps the "mounting plate" aligned to the steering column via splined teeth). Good call on discharging the caps @AtlasMick; I'll do that. Thanks for all your input guys.
Old 03-22-2013, 06:06 PM   #11
OrbitalEllipses
Drives: Attitude
Unbolt negative battery terminal, step on brake pedal. That should get rid of most of the residual charge.
Old 03-22-2013, 08:20 PM   #12
FRS-Jonathan
FRS-Jonathan's Avatar
Drives: 2013 6spd manual Scion FRS
or unbolt terminal and wait 5-10 minutes, and make sure that if there is steering angle sensor it does not go out of whack or you might need to get it re-calibrated!
FRS-Jonathan is offline   Reply With Quote
Old 03-22-2013, 09:32 PM   #13
disgruntld
Less than pleased...
disgruntld's Avatar
Drives: '13 BRZ Ltd SSM 6MT
Stumbled on this in the DIY section http://www.ft86club.com/forums/showthread.php?t=12257
disgruntld is offline   Reply With Quote
WTB: Stock steering wheel (wheel not airbag) mobybrz Interior Parts (Incl. Lighting) 2 09-11-2014 02:23 PM
Different Steering Wheel?- NOT? BRZfan Cosmetic Modification (Interior/Exterior/Lighting) 10 03-07-2013 09:01 PM
FS: FRS OEM Steering Wheel (with airbag) NRG x FRS Interior Parts (Incl. Lighting) 2 01-18-2013 07:25 AM
anyone thought of doing something with the steering wheel? chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 11 01-08-2013 10:21 AM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 12:16 AM
