go_a_way1
Old 04-03-2013, 07:52 PM   #1121
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by Nukeeng09 View Post
What would the best offset to make an 18x8.5 flush without any camber or adjustments
Running on lowered Fortune Auto 500 coilovers
Why would you not tune the chassis if you're buying FA500 coiolovers???
There is no right answer. Study and make your own decisions. :-)
ill86 is offline   Reply With Quote
Old 04-04-2013, 08:31 AM   #1122
trinitron
Drives: gts 86
Hey guys
I'm going for this-
http://www.performanceplustire.com/b...milled-accents,
I've figured i am going for the 18x8, but unsure which offset, either 45 or 35.
trinitron is offline   Reply With Quote
Old 04-04-2013, 04:26 PM   #1123
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by trinitron View Post
Hey guys
I'm going for this-
Depends on what YOU want. Find some pics and go from there. It's only 10mm. This thread has a LOT of info plus the wheel pic thread.
I would pick 35.
The Following User Says Thank You to ill86 For This Useful Post:
trinitron (04-04-2013)
Old 04-05-2013, 07:57 AM   #1124
kioton32
kioton32's Avatar
Drives: 14' Monogram FRS, ulramarine, white
Here is my set up. A 1.2" drop on lowering springs... 19x8 fronts wrapped with 215/35r19 tires... 19x9.5 rears wrapped in 245/35r19 tires... Both front and rear are offset 40... All rubber is stretched 1.6 over for clearance. I'm thinking I might need to camber in just a little bit... Any suggestions on how much camber I am needing.
kioton32 is offline   Reply With Quote
Old 04-05-2013, 02:43 PM   #1125
ill86
ill86's Avatar
Drives: iG FR-S
I believe you will be fine without needing to tuck with camber. Good fitment. Post pics.
kioton32 (04-07-2013)
Old 04-05-2013, 04:56 PM   #1126
kioton32
kioton32's Avatar
I will post pics as soon as its done... Going to be ordering the parts in about a week or so...
The Following User Says Thank You to kioton32 For This Useful Post:
ill86 (04-09-2013)
Old 04-06-2013, 06:11 AM   #1127
normanb21
Drives: black frs
Hey guys
I'm going for this-
Any idea how much these wheels weigh?
normanb21 is offline   Reply With Quote
Old 04-07-2013, 09:11 PM   #1128
MrH
Drives: 20 Outback XT, 23 BRZ on order
I've only seen one post on RPF1s that are 17x9 +45 mm, and he was rubbing on his front sway bar. But he was also dropped 2-2.5"
Has anyone run a 17x9 +45mm with 245/40/17 either stock or a 1" drop? Any rubbing on the front strut? I saw someone had 17x9 +42mm and it was really close.
MrH is offline   Reply With Quote
Old 04-07-2013, 09:45 PM   #1129
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Will not fit with stock struts in the front, it's too close. It does rub the sway bar at full lock only. It doesn't matter how stock or low the drop is.
Pure Automotive is offline   Reply With Quote
Old 04-07-2013, 09:53 PM   #1130
MrH
Does a 3mm spacer fix this? Or do I need to go to 5mm?
Thanks!
Old 04-07-2013, 09:56 PM   #1131
Pure Automotive
To clear the shock, I would say 5mm, but even then I would definitely test that out first to make sure.
Old 04-08-2013, 06:40 AM   #1132
the_avatar
Drives: GT86
Can anybody tell me the EXACT offset from offset 0 (should be exact middle of the wheel/symmetric attachement; offset 0 represents the spot where you attach the wheels to your car, right??) to the spot on the fender at 50° front of wheel (when you draw a straight line from wheel center up to the fender and then use the position 50° to the front on the edge of the fender)?
Background is, that in germany the whole wheel has to be inside the wheel containment area below the fender and may not stand out at all at the points 30° to the back and 50° to the front of the fender above the wheel (you spot the points according to the degrees given with the explanation above). So I want to exactly know how many millimeters, combined of half wheel width and offset, I can go maximum with a guaranteed OK from TUEV.
I hope this doesnt sound too confused!! I am just trying to find out the maximum attributes that germans can get without having to do body work and getting a guaranteed OK from the TUEV (=german company that checks if your car is according to safety regulations, we have to do this here).
the_avatar is offline   Reply With Quote
Old 04-08-2013, 02:26 PM   #1133
MrH
I sent an e-mail to Tire Rack, and they're saying it will clear the front strut without spacers.
Is that your car pictures above? Did you try fitting this setup and it didn't work?
Old 04-08-2013, 04:20 PM   #1134
Pure Automotive
I fitted the wheel with no tire and it looked to me like it would absolutely hit, I tried to fit them with a 235/45/17 and it was laying on the strut.
Yes that's my car.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
