Old 04-01-2013, 05:29 PM   #141
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by Adeets View Post
@Frs300 To prevent anything like this happening to another user, I could suggest if you don't know of a good aftermarket shop for the FRS/BRZ, watch for a highly modified Subaru during your daily driving, follow him til he stops* and ask what shop he uses, do it a couple times, and the first shop to get mentioned twice, get an address and go check them out.
I've lived in several Cities (28) and I do just that every time I'm in a new city, its worked every time, a lil scary stalkerish, but you cant ignore the results. The stalkee after you explain what you were doing normally laughs and helps you out.
*make sure to announce that your not armed and mean no harm when your following them into their driveway, didnt happen to me but a buddy got a gun pulled out on him when he did this in texas. (I've always owned a subaru so I dont know how they would take it if you follow a subaru in a non subaru vehicle, which is what my buddy did in texas.)
Also do you have anymore pictures of your engine?
April fools right?
If serious, I don't recommend people do this (following them into their driveway) unless you want to be shot/shanked/stopped by the police.
The Following User Says Thank You to sw20kosh For This Useful Post:
Sportsguy83 (04-01-2013)
Old 04-01-2013, 05:30 PM   #142
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Originally Posted by SkullWorks View Post
In one of your Pics you can see the top of the Wastegate the nipple is there, but it has no line on it...please tell me this isn't where the boost signal was attached to
you mean this pic?
Adeets is offline   Reply With Quote
Old 04-01-2013, 05:33 PM   #143
Adeets
OEDC
Adeets's Avatar
Originally Posted by sw20kosh View Post
April fools right?
Being in the navy means you have to adapt quickly, This by far is the quickest way to find a good shop. i Didnt say it was the safest way. and i also said there were issues with this in certain states, but I've never had an issue, and ive done it so many damn times i cant remember.
(I don't have a imposing visage, more of a computer/gear head nerd then a weight lifter. Lets put it this way, no one has ever said "MAN THIS SHIT IS HEAVY, lets get Deets to help us.")
Old 04-01-2013, 05:36 PM   #144
Frs300
Frs300's Avatar
Drives: Pile of junk
im about to click order on this crawford built block. unless someone has any other suggestions.
Frs300 is offline   Reply With Quote
Old 04-01-2013, 05:36 PM   #145
crook
crook's Avatar
Drives: storm black GT
Yep just went back and looked a that, if they hadn't connected your waste gate she'll be running as much boost as the turbo can push...
If you had it vent to atmosphere could you hear it open at all?
crook is offline   Reply With Quote
Old 04-01-2013, 05:38 PM   #146
Frs300
Frs300's Avatar
it was connected on the side....that nipple was venting to atmosphere
Old 04-01-2013, 05:40 PM   #147
jamesm
it's hard to argue that the shop should pay for this. i know it sucks, and i feel your pain, but once you're off the lot, it's all yours. unless you can prove without a doubt that something they did caused the failure (which is nearly impossible without pictures taken before the failure or something along those lines), the dealership can easily claim that the tune was to blame. they can also claim negligence on your part for not following accepted best practices (i.e. having a boost/afr gauge), or improperly breaking it in, any number of excuses.
ultimately, when we bolt this stuff onto our cars we accept the possible (unintended) consequences that come with all that fun. this is why it is so important to either know how to perform the work yourself, or know a good shop that you can trust to do quality work. dealerships generally aren't the spot.
i hope you get everything resolved in a manner that doesn't cause any hardship (financial or otherwise), but i'd be flat out shocked if you didn't end up paying the bill.
Old 04-01-2013, 05:49 PM   #148
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
OR, you can just join a local Subaru forum/ Facebook group and simply post a quick question "what is the best/most reputable shop in the area?" and you will get your response within a day.
The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post:
Adeets (04-01-2013), crook (04-01-2013), pyro530 (04-01-2013), sw20kosh (04-01-2013)
Old 04-01-2013, 05:53 PM   #149
Adeets
OEDC
Adeets's Avatar
Bahhh "Back in my day sonny there were no facebooks." but in all honesty that's probably a better idea now a days.
The Following 3 Users Say Thank You to Adeets For This Useful Post:
DriftEightSix (04-01-2013), Mr.Jay (04-01-2013), Sportsguy83 (04-01-2013)
Old 04-01-2013, 06:13 PM   #150
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
That is the way it is supposed to be.
Pull the wastegate and check the spring inside.
No Limit Motorsport is offline   Reply With Quote
Old 04-01-2013, 06:17 PM   #151
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
I'd wait until the engine is pulled down before going ahead with the purchase of a new shortblock. Once it's pulled down you will be able to assess the damage to the head/valves etc on the cylinder the rod snapped in.
You're not the first 86 owner to have a rod depart the side of the block. There has been quite a few throw rods now, not all get plastered all over the internet.
You should be able to get your hands on a lightly used long motor for ~$4K
JP is offline   Reply With Quote
Old 04-01-2013, 06:19 PM   #152
boost junkie
Drives: turbo
Dont be mistaken..30 psi on the basemap would put a hole in the block.
8psi boost limiter would have saved this motor.
Quoted for truth. OEM turbo installs have a boost fuel cut. It's there for a reason...
boost junkie is offline   Reply With Quote
Old 04-01-2013, 06:21 PM   #153
skatery1989
Drives: BRZ Limited
Ya don't let the dealer install it.
skatery1989 is offline   Reply With Quote
The Following 2 Users Say Thank You to skatery1989 For This Useful Post:
coyote (04-01-2013), Mr.Jay (04-01-2013)
Old 04-01-2013, 06:21 PM   #154
Sportsguy83
Drives: Limited BRZ
Care to elaborate?
Swapping the motor. Either 3uz or 2gr diss7 Engine Swaps 34 11-16-2015 05:31 PM
Motor swaps.. Brian S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-19-2012 05:18 PM
BMTV (Best Motor TV) HKS vs TRD vs 86 KyShro FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 05-09-2012 11:48 AM
Will Lotus use the FR-S motor? muffinman Other Vehicles & General Automotive Discussions 26 01-20-2012 10:24 PM
