Old 03-31-2013, 11:02 AM   #15
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by Frs300 View Post
.. the wastegate was staying open at idle causing the car idle at 1k rpms and choke and die randomly....
The wastegate or the blow off valve?
I think your talking about the blow off valve because you sure as heck don't need a 12psi spring to keep a wastegate shut at idle...
Not trying to rub salt on your wounds or anything, i know how much is sucks when things go sideways like this, but you really should not have gotten in boost at all without a wideband and boost gauge installed so that you could verify everything was green. I'm sure you won't make that mistake a second time though and I hope you get everything sorted out quickly and with the least expense possible.
Old 03-31-2013, 11:02 AM   #16
FullBlown
FullBlown's Avatar
Drives: Scion FRS
I believe they had told him they would warranty the install. I don't think they defined what that all entails.
I was surprised myself that a dealership would accept a job like this.
FullBlown is offline   Reply With Quote
Old 03-31-2013, 11:04 AM   #17
Frs300
Frs300's Avatar
Drives: Pile of junk
if wrong/bigger spring was installed how was it staying open at idle? like i told you on the phone previously driving it around it didnt feel like it had 300 hp at all untill it blew. so something wasnt right from the get go. i had just left toyota when this happened to to tell them about the exhaust and the spring being shipped out.
im going to toyota tomorrow and im going to have them take all the lines off and inspect them and the wastegate while i stand and watch that way nobody can say anything was tampered with
Frs300 is offline   Reply With Quote
Old 03-31-2013, 11:09 AM   #18
Noob4Life
86 Noob
Drives: Firestorm FR-S
If this is true I hope that they find that they installed it wrong and caused the problem. I'd be afraid of them saying it was the tune that caused the issue and therefore they're not at fault.
Good luck and subscribed!
Noob4Life is offline   Reply With Quote
The Following User Says Thank You to Noob4Life For This Useful Post:
Skye (03-31-2013)
Old 03-31-2013, 11:15 AM   #19
Frs300
Frs300's Avatar
ya i ment bov sorry. im at work doing 100 things at once.
i was going to install my gauge pod that night. this dealership has done turbo/sc on trucks quite a bit. i should have drove to mn and had fullblown install it.
FullBlown you guys have the heads ready yet? i may need some lol
Old 03-31-2013, 11:21 AM   #20
jamesm
Man that sucks. Sorry to hear that. I'm going to be doing a turbo install soon, makes me nervous. I'm going to put some high temp loom over the wastegate line. Not sayin this was a wg line failure, but if it was that'd make two now.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
charged86 (03-31-2013), Skye (03-31-2013)
Old 03-31-2013, 11:22 AM   #21
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Make sure you snap a picture of the fuel pump assembly when they pull that out. I was thinking about all the possibilities and because you said that it did not feel right from the get go. I'm starting to think that the pump was installed incorrectly and bled off pressure in wot.
There is a in tank pressure valve that might of came loose or the o-ring never fully seated.
Old 03-31-2013, 11:25 AM   #22
mad_sb
ya i ment bov sorry. im at working doing 100 things at once.
Sounds like full blown is saying the dealer may have installed the wrong spring the wastegate which would cause it to run too much boost.
The wastegate spring determines the amount of positive manifold pressure required to open the gate and bleed off excess exhaust gas from the turbine which maintains boost at the desired pressure (spring pressure).
If a boost controller is involved, it's purpose is to bleed off positive manifold pressure before it reaches the waste gate pressure port allowing you to run boost higher than spring pressure.
The blow off valve being open at idle is NOT going to cause overboost, it will idle like shit and very rich but it will not cause over boost. A Vent to atmosphere blow off valve requires a spring stiffer than manifold vacume at idle to stay closed at idle.
Sounds like you needed a stiffer BOV spring AND the dealer cocked something up during the install. Probably plumbed something incorrectly.
The Following 3 Users Say Thank You to mad_sb For This Useful Post:
charged86 (03-31-2013), Synack (04-02-2013), tripjammer (04-15-2013)
Old 03-31-2013, 11:28 AM   #23
mad_sb
on a side note, @FA20Club.com is in florida
Old 03-31-2013, 11:31 AM   #24
Frs300
Frs300's Avatar
lets hope thats what it is. the new spring does me no good at this point in time lol
where in fl are they?
Old 03-31-2013, 11:39 AM   #25
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Ft. Lauderdale. I'm really sorry for your loss. I just finished installing my AVO kit yesterday. This thread gives me chills...
Old 03-31-2013, 11:41 AM   #26
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Originally Posted by Noob4Life View Post
I think you screwed yourself having toyota install your turbo kit. You should've taken it to a place with more experience on intalling turbo kits. Do you think toyota techs have ever installed a kit? My guess would be no unless you got a younger kid who does his own mods. Hate to say it but it sounds like the problem was self caused and has nothing to do with the way then engine can handle being boosted (which i originally thought it was)
I'm glad I can turbo it and feel okay still but sorry about your luck man. Next time DON'T USE A DEALERSHIP.
I do not think this has anything to do with the kit
This sounds like install errors,
why on earth would you let a dealership install a kit is my 1st question
there are qualified tuner shops, ecutek shops, why not find one of those?
Where are the motors from the wrecked car threads, are there donor used motors at shops? Or is the only option at this point something like a crawford block or dealer??
Its scary indeed, something to be aware of for any TC installer. Or anyone playing with extra boost levels.
Makes me reconsider my wanting to toy with the option of adding more complexity with a wastegate and more boost to my setup, maybe I should just hang out at 10psi and Keep it Simple and Stupid, and take this chance when I have new motor funds set aside...
Wasnt there a BOV or any protection in place?
Huehuecoyotl is offline   Reply With Quote
Old 03-31-2013, 11:43 AM   #27
skatery1989
Drives: BRZ Limited
I get how this could happen if the wastegate or BOV was installed wrong. Could you explain more on how this could have if the fuel pump was installed wrong.
skatery1989 is offline   Reply With Quote
Old 03-31-2013, 11:43 AM   #28
Foobar
SLO NO MO
Foobar's Avatar
Which Toyota dealership performed this install?
Swapping the motor. Either 3uz or 2gr diss7 Engine Swaps 34 11-16-2015 05:31 PM
Motor swaps.. Brian S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-19-2012 05:18 PM
BMTV (Best Motor TV) HKS vs TRD vs 86 KyShro FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 05-09-2012 11:48 AM
Will Lotus use the FR-S motor? muffinman Other Vehicles & General Automotive Discussions 26 01-20-2012 10:24 PM
