#57 | |
I Love custom Turbo kits
Drives: Limited BRZ
#58 | |
Seems Legit
Drives: Toyota
Apologies if i'm stating something that has already been said.
Switched 12v can be found in the radio harness. In the white 10 pin plug, pin 3, red wire. I believe, I haven't checked, the radio is fused at 10 amps, there's no need to add an inline fuse, but you can if you desire. Illumination/Dimmer (+,-) can also be found in the radio harness. In the white 10 pin plug, pin 10; white 6 pin plug, pin 5. Purple (parking lights); Black/White (dimmer). Quote:
Once again, sorry if these were answered previously. |
#59 | |
Drives: Limited BRZ
The tach signal, it is strongly advised to not use the crankshaft sensor for it.
#60 | |
Seems Legit
Drives: Toyota
However, from my own personal experience, you can also use any fuel injector, which are pink, pink/blue, pink/black, or pink/green at the ECM behind the glove box, white 34 pin plug (D), pin 12, 22, 32, or 13. |
#61 |
Seems Legit
Drives: Toyota
I can get you a picture later today if that'll help any or if you have any help you can just meter it with your multimeter on AC volts. It should fluctuate as you press and depress the throttle.
#62 |
Drives: 2013 Scion FRS
picture attached, this is basically the side view at the passenger side.
Gonna just pull out my oscilloscope and test the pins at the gauge cluster this weekend if I still cant find it if I go that route ill be sure to post it too.
#63 |
Seems Legit
Drives: Toyota
lol I'll get you the exact position a little later...complete with pics
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
#64 |
Seems Legit
Drives: Toyota
I can't be any more explicit than this
#65 |
Thanks for the pics.
The reason why I am insisting on trying to find the tach output instead of with the fuel injector / crank shaft sensor is the fear of interfering with the signal. Had experience before with an impreza build where customers use those signals and keeps burning out / screwing with the engine. |
#66 | |
Seems Legit
Drives: Toyota
As many vehicles as I've worked on, I have not experienced an issue where one tach connection was any better over another, aside from convenience of location, and especially nothing noting fuel injectors weren't a reliable source for a tach signal. In fact, unless using a data module, most vehicles spec the uncommon color wire at the fuel injector to be used as the tach. At least in these vehicles, I don't have to go under the hood to get to it.
#67 |
NASA SpecE30 Racer
I don't know why we are over complicating this. The OEM wiring has two TACH signals and they are both available inside the car. Just tap into one of them. It is possible that @Lonely Sushi does not have the same certification ECU box as the US cars.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#68 | |
thats why I am thinking is it possible FRS and BRZ has slight different wiring? or I am just looking at wrong place for the tach output.
#69 |
NASA SpecE30 Racer
Now I am very confused. If your car is a US spec, then there should definitely be a thinner box than the ECU mounted in that same area with three connectors going into it. I can tell you that on my car it mounts to the dash frame with a bolt that is best accessed with the panel on the side of the dash removed (this panel is covered by the door when the door is closed). When you pull the panel off, you will see a 10mm head bolt for the mounting bracket of the certification ECU box. I can probably snap a pic tonight to show exactly where I tapped in for RPM.
- King Tut
#70 | |
Drives: Limited BRZ
I routed the cable but didn't have time to tap it.
| Tags |
| dash, gauge, gaugle cluster, pod |
| What is that blinking dash light when the car is off? | JayNutter | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-03-2014 10:59 AM |
| WTB: FRS instrument cluster | jabbajaw99 | Interior Parts (Incl. Lighting) | 3 | 02-14-2013 01:31 PM |
| surprised at how much MORE i like the frs dash cluster | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 12-07-2012 09:09 PM |
| Flashing Security Light in Dash? | ravenMTgirl | Electronics | Audio | NAV | Infotainment | 8 | 11-21-2012 03:25 PM |
| Scratches on my Cluster. | Superhatch | BRZ First-Gen (2012+) — General Topics | 5 | 08-21-2012 07:50 AM |
