| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 | |
Drives: FRS
#16 |
Flat 4 Handyman
Drives: Firestone Red FR-S & WRB MY2002 WRX
Great to finally see these on a car. I've been rolling around the idea of getting them for awhile now, was wondering how they sat on the car. I think I'm finally sold. Thanks for being the test subject.
#17 |
Drives: 14 Porsche Cayman S
No, this car is on 100% stock suspension. The wheel gap looks to be gone in the picture above, that is just compressed suspension due to the left turn I am finishing.
Previous cars:
2013 Subaru BRZ (2012-2017) 2009 BMW135 6MT (2009-2012) 1999 BMW M Roadster (2000-2010) 2004 Audi A6 2.7T (2004-2007) |
#18 |
Drives: Asphalt FRS
I like simple setups like this. Looks really good. I might consider that same size. Do you have any plans for a drop?
#19 | |
This is a possibility in the future. I do think the car looks better with a slight drop.
Previous cars:
#20 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
How has your Stock/RTR running been with these?
#21 |
Drives: 15 Halo
So, I ordered a set from tirerack, and they didn't say anything about hub centric rings, and I'm not sure of the hub dimensions. Do they require them?
#22 |
Drives: Scion FRS
No rings required. Machined hubcentric for the car
We're not happy till you're not happy 2013 Scion FRS Whiteout 6MT SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover. |
| The Following User Says Thank You to SVThis For This Useful Post: | Apexer (04-20-2013) |
#24 |
Drives: 2002 BMW 325i
Thanks for the pics and the info - especially weights. This is one of the rims I'm considering for my GBS.
2013 Subaru BRZ Limited
Pioneer.Mosconi.Morel.Audible Physics.Ascendant Audio |
#25 |
Drives: RSX
Those are the wheels that I want. Just under 15lbs each. I was thinking of going with the Continental DWs with stock tire size. It would be a 34lb per corner setup. They're pretty good lightweight summer tires, I have them on my RSX. My RSX has RPF1 17x7 +45 but it's 5 x 114 bolt pattern, so they won't work.
Gonna have to sell them cause the RSX is gonna be the winter beater car now.Seeing how the offset is -6 per corner from stock, would this cause premature wear on the wheel bearings? Shouldn't mess with the suspension geometry right? I'm going to contact Enkei tomorrow and see if the PF01 centercaps fit in the RPF1s. Has anyone tried Toyota cenercaps to see if they fit the RPF1s? My Acura centercaps fit perfectly in the RPF1s, but I know Enkei makes most of Honda's / Acura's wheels. I'm just not a fan of the open center. Last edited by CyberCT; 09-03-2013 at 08:42 PM. |
#26 |
Drives: RSX
I just called Enkei and apparently the difference between the RPF1 and PF01 cenerbore is 4mm, so no the PF01 centercaps won't fit unfortunately
Gonna have to figure out a way to make it look nice and clean without the hole in the center.
#27 |
Drives: ‘16 4Runner, ‘19 Corolla HB
Anything ever come out for caps? Tire rack offers some, but they look pretty bad.
#28 |
/scion
Drives: '13 86 M/T
"Practice makes better. Only Senna is perfect." - CSG Mike
| The Following 5 Users Say Thank You to LOLS2K For This Useful Post: | D_Thissen (12-30-2015), Keenercarguy (01-01-2016), Lonewolf (01-31-2016), Mr.Impreza (12-17-2015), TofuJoe (01-23-2016) |
| Wheel Directory: Enkei RPF1 17x7.5 +48 | Guillaume | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 04-12-2021 04:30 PM |
| Wheel Directory: Enkei EV5 17x7.0 +38 | rikdrt1 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 12-17-2016 11:47 AM |
| Wheel Directory: Enkei RPF1 Type-II 17x7.0 +48 | hankster | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 33 | 10-05-2013 02:23 AM |
| Wheel Directory: Enkei FLC-01 17x7.0 +40 | Mr.Jay | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 07-09-2013 03:44 PM |
| Wheel Directory: Enkei WTE II 17x7.0 +41 | stout90 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 01-06-2013 10:18 PM |
