Old 02-24-2013, 11:53 AM   #197
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by robispec View Post
well I did a STUPID experiment with aero and ended up with a melted bumper..
So I'm in the market for one!
Oh no! How did that happen? Exhaust flow was directed upward toward bumper? Exhaust piping too close to bumper? This is a constant concern for me as I install my diffuser.
Old 02-24-2013, 12:17 PM   #198
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Originally Posted by sw20kosh View Post
teaser
Looks awesome man. That's exactly what I had in mind 7
Can anyone guess what car this diffuser came off of? I made the grill and brackets to attach it but the diffuser itself is from another sports car an actually fits under the 86 perfectly.
Elise!!
kask2_6.0 is offline   Reply With Quote
Old 02-24-2013, 01:57 PM   #199
sw20kosh
Elise!!
Actually it is a tiny bit short. Ill just fab up ~6" worth of aluminum sheet to close off the rest of the gap so it sits up against the rear axle/subframe
Old 02-24-2013, 02:28 PM   #200
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Is that the OEM diffuser or a difflow? Can't wait to see how it looks on the car
Old 02-24-2013, 05:10 PM   #201
sw20kosh
Oem. Got it used for $150. $35 for grille sheet. $20
for odds and ends and aluminum for brackets. $800 Custom exhaust.
Ok this isn't done, but here is another teaser. Need to get black bolts to replace those shiny ones, get some weatherstripping for the grille edges so it looks more finished. Need the exhaust. etc.
This is a photoshop I made of my car that I am using as my inspirational guide:
or
Old 02-24-2013, 05:15 PM   #202
Captain Insano
It looks like the exhaust will melt the plastic above... with ur black car that is nice though as exhaust carbon would be imperceptible. I love the work so far man. Pretty awesome custom work.
Captain Insano is offline   Reply With Quote
Old 02-25-2013, 01:47 AM   #203
OrbitalEllipses
Drives: Attitude
Very interesting @sw20kosh.
Old 02-25-2013, 07:46 AM   #204
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Have you considered using a Perrin exhaust? The design of the muffler/ pipe routing looks like it would work perfect for this. The muffler inlet is in the center and out of the way. Also pretty small and sits more toward the front of the car. The only modifications needed would be to cut off the outlets and move the bends closer to the muffler. May be a little more tweaking than that but it would be an excellent starting point and there is a GB for $770 shipped or something.
Old 02-25-2013, 07:54 AM   #205
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Could offer a few different options pretty easily. Just and idea.
Old 02-25-2013, 09:35 AM   #206
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Honestly not sure if there's enough room... but could a mufller fit longitudinally?
If you size the muffler properly, a quick bend behind the differential, fit the muffler front-rear tilted upwards, tips installed on the outlets.
The minimum size Mangaflow offers has a case length of 14". Total length with inlets and outlets is 20". I imagine that might fit with some coercion. LINK
With regard to melting things, it's simple enough to cut the mesh and weld a ring into place that leaves sufficient room for the tip to jiggle (3/4" clearance or so, if mounts are fairly solid). Heat shields or a wrap would be nice, but it may not be necessary with how open that design is. We shall see.
Thanks for being innovative, @sw20kosh !
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 02-25-2013, 10:15 AM   #207
OrbitalEllipses
Drives: Attitude
I'm relatively certain there's no way to fit an off-the-shelf exhaust to that diffuser without hacking up the diffuser OR the exhaust, so you might as well go custom.
Old 02-25-2013, 10:40 AM   #208
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
$770 + custom re-working = more than $800
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-25-2013, 11:27 AM   #209
sw20kosh
As a few have pointed out, no point in hacking up a brand new exhaust. It would need lots of manipulation. I thought a lot about the exhaust and its design for this.
With the diffuser brackets and the Y pipe in the stock muffler compartment it is not feasible to have a muffler back there. My exhaust man and I decided to put a nice long cylindrical race magnaflow muffler under the middle of the car sort of like the borla set up.
There are some trick race magnaflows that are 6" in body length and 4" or 6" in diameter. Very compact. I initially thought about using these in stock location.
To have the exhaust exit like I want it to the bumper beam will need two holes cut into it. Alternatively I could use the hole in the diffuser which was originally intended for exhaust on the Elise/exige. I just don't like that location because it defeats the point of a diffuser...
Old 03-21-2013, 10:45 PM   #210
Hancha Group
FT86Club Official Vendor
Hancha Group's Avatar
Drives: Subarus
We just got done creating a new, and more accurate CFD model for the FRS. This will be used for our development of the car. Below are some post-processing pictures of a stock FRS with Rota Grids.
Cheers,
Paul Lucas
paul@hanchagroup.com
Hancha Group is offline   Reply With Quote
Front aerodynamics... need help! TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 16 10-23-2012 09:27 PM
Interesting aerodynamics differences between USDM, JDM, etc. yargk Scion FR-S / Toyota 86 GT86 General Forum 25 09-20-2012 04:00 PM
Coefficient Drag & Aftermarket Aerodynamics FT-86GOD Scion FR-S / Toyota 86 GT86 General Forum 1 06-28-2012 01:20 AM
Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained Moshpit37 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 19 06-26-2012 09:19 PM
Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained Moshpit37 BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-21-2012 12:47 PM
