Old 03-18-2013, 08:28 PM   #57
2forty
Drives: 2002 rsx type s
ah IC, e85 and 17psi should be pretty quick. I just would really like to see some pump gas numbers is all. ie the pump gas limit on boost/whp.
2forty is offline   Reply With Quote
Old 03-18-2013, 08:47 PM   #58
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Don't take this as engraved in stone... around 10 to 12psi / 305whp +/-5%.
Without supporting mods -meth-water-ect.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 03-18-2013, 09:28 PM   #59
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
^^ im talking about his car and dyno of 310whp. Theres no way he's trapping 127 with 310whp.
Pump gas limit is going to be around 10 psi and about 330whp depending on setup, I highly recommend that if you are going to run more than 8psi having a full tune done, not just running the base map.
This car is making more than 310, its on e85 now, we haven't gotten on the dyno for long enough to get a complete number, we were having a couple of small issues and we were holding up the next person to get on the dyno. We'll have updated numbers soon, I will tell you its over 400hp though
Pure Automotive is offline   Reply With Quote
The Following 2 Users Say Thank You to Pure Automotive For This Useful Post:
NorCalRider (03-19-2013), SnapOv3st3r (03-21-2013)
Old 04-04-2013, 01:46 PM   #60
cdemaar
Drives: 2013 Scion FRS
So what ended up happening??
cdemaar is offline   Reply With Quote
Old 04-04-2013, 02:02 PM   #61
Pure Automotive
451hp on e85!
ftc~brz (04-04-2013), SnapOv3st3r (04-04-2013)
Old 04-04-2013, 04:40 PM   #62
Unleashed
Unleashed's Avatar
Drives: 13' WRX
451hp on e85!
Will I be able to hit 400whp on E85 with 550cc injectors? also how much could i turn it up on e85 base tune before needing full tune? thanks
Unleashed is offline   Reply With Quote
Old 12-31-2013, 08:19 PM   #63
youngbasedfrs
Drives: 2014 Scion FR-S - Raven - 6MT
Very late here, new member >.< I was also wondering what injectors you're running and if we can get any updated acceleration numbers?! Also, how's traction now with over 500HP?
Thank you!
- Matt
youngbasedfrs is offline   Reply With Quote
Old 12-31-2013, 08:39 PM   #64
ftc~brz
Done
Drives: WRB BRZ
^oh honey….late is an understatement
ftc~brz is offline   Reply With Quote
The Following 4 Users Say Thank You to ftc~brz For This Useful Post:
Darryljr11 (01-01-2014), King Tut (01-02-2014), mack4477 (01-01-2014), OrbitalEllipses (01-02-2014)
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
Full Blown Motorsports Stage 1 Turbo Kits PROVEN POWER!@ Pure Automotive Performance Pure Automotive Forced Induction 86 11-26-2013 09:27 AM
AVO Turbo Kit Stage 2 - work in progress AVOturboworld Forced Induction 202 06-18-2013 01:35 PM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Forced Induction 68 02-25-2013 01:06 PM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Mid-Atlantic 61 01-30-2013 09:38 PM
