go_a_way1
Old 03-15-2013, 01:19 PM   #953
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Originally Posted by itdansharpe View Post
Stock suspension?
Yay for my tire fitment calculator.. you just proved it worked!
Stock All Day Every Day ! Fitment Calculator was SPOT ON !
stay tuned for pictures and then you can go by the pictures and then the calculator and see how spot on it was
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 03-15-2013, 01:20 PM   #954
ScionFR-S
ScionFR-S's Avatar
God Bless Your Soul for making that calculator you just saved me alot of money and headaches if these didnt fit and i was just eyeballing the fitment
Old 03-15-2013, 01:21 PM   #955
itdansharpe
itdansharpe's Avatar
I just got a warm tingly feeling. Glad to help!
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
The Following User Says Thank You to itdansharpe For This Useful Post:
ScionFR-S (03-15-2013)
Old 03-15-2013, 01:39 PM   #956
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
I'll be test-fitting my setup again on the weekend on both front and rears. 18x9 +35 square
The weird thing is that according to your fitment calculator, I should be 4mm in, but instead I am about 20mm out. See pics.
I also know many others have fit 17x9+35 and also 18x9+35 without issue.
I going to recheck the offset and stamping on the wheels to be sure they are indeed +35.
There is about 15mm clearance inside to the strut which makes sense on a 9" wide +35. (I heard that a +45 almost hits the struts)
I guess we'll see.
Slick is offline   Reply With Quote
Old 03-15-2013, 06:12 PM   #957
ScionFR-S
ScionFR-S's Avatar
Make sure you have the front and rear input correctly bc the rear has more clearance room
Old 03-16-2013, 08:54 AM   #958
itdansharpe
Just finished installing Eibach Sport lines last night.. 265/35 18x9.5+45 r and 245/35 18x8.5+45 f. Fits great turns lock to lock no issues.
Question. I could only feel the gap between the strut and rim when at full lock and it was SMALL. Like 5-10mm... Does this gap change when the wheels are pointing straight forward?
Its not rubbing at all.. Does this gap ever change? My only concern.
Old 03-16-2013, 10:12 AM   #959
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
Front= 18x9.5
Rear= 18x10
Tires wise I want the stretch (not too stretched) and poke look as I am lowering my car about 1.5-2"
Not sure if I should go 235 on the tire.
Not sure about offset either.. 40?
I dont want negative camber, I MIGHT be able to stand -1. But mostly going for flush.
Don't know if I am forgetting anything..
VADER is offline   Reply With Quote
Old 03-17-2013, 05:07 PM   #960
Slick
Slick's Avatar
Just a follow-up to my post from a few days ago, I tested fitted my wheels again this time on both front and rear. (18x9 +35)
To give you a visual of how much camber you gain with crash bolts on the front suspension, here are some before/after shots. I didn't actually use crash bolts, I just pulled the OEM upper bolt out enough that the larger shank was out.
First 2 pics are before, next 2 are after the camber bolt adjustment. Spring is compressed to stock height both times for proper reference.
End result is that it will fit with the crash bolt installed.
Lowering springs should add a bit more camber that will also help for clearance. (ProKit on the way)
The Following User Says Thank You to Slick For This Useful Post:
djdnz (03-26-2013)
Old 03-19-2013, 08:33 PM   #961
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Should I go with a 17x8 or 17x9 wheel?
I plan to buy wheels soon, and I would like to see some opinions to help me decide which to choose. Tires will be Nitto NT05 in 235/40/17. The measure rim size is 8.5, and this would be ideal, but I can't find any inexpensive, lightweight (<16lbs) rims in 17x8.5, so do I go 17x8 or 17x9?
My priority is quick times and longer tire wear for the track. I may do an autocross or two this summer, but not seriously, so this is not a priority. I chose a 235 tire because my engine is currently stock and I think the extra weight and diameter (and expense) of a 245 would be too much. Nitto because I can get them really cheap and they are very light weight. I realize that the NT01 would be better for the track, but I need to be able to use the tire in (light) rain and on the street as well.
It is also important that the wheel fits the AP Racing Sprint brake kit, as I plan on this in the future. This is a bit of a non-issue though as all of the wheels I have found that fit my other criteria also clear the AP brake kit.
17x8
There are several good choices of wheels in this size:
Kosei K4R 17x8, 36mm offset, 15.8 lbs
Enkei RPF1 17x8, 45mm offset, 15.6 lbs
O.Z. Alleggerita HLT 17x8, 48mm offset, 15.8 lbs
The advantage of going with this size wheel is that I could use a 225 tire in the future without too much stretch. There are very few tires in 235/40/17; the 225/45/17 is much more common and could be less expensive. I like the looks of the OZ best (see here http://www.ft86club.com/forums/showt...lleggerita+235), but I like the price of the Kosei. Also, I prefer the offset of the Enkei and OZ.
17x9
I have only found one choice:
Enkei RPF1 17x9, 45mm offset, 15.8 lbs
The advantage here is perhaps better handling by stretching the sidewall a little more. Also, if I later add power (turbo???), it would be easier to fit a 245 or even a 255 to this rim.
Which would you choose? Help me decide.
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
Old 03-19-2013, 08:37 PM   #962
turbo_jimbo
Drives: 01 MR-s, 78 280z, 13 FR-s
17x9 use 245 40 and your speedometer should be mostly accurate still too.
turbo_jimbo is offline   Reply With Quote
Old 03-19-2013, 09:00 PM   #963
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
No limit motorsport has some 17x8.5 advans that are very light on special, i would check on those and see if they still got them.
Old 03-20-2013, 12:54 AM   #964
whataboutbob
AutoX-10/10ths every run
You can see my 17x9et35 RPF1s with 245/40R17 Z2s in my build thread. The normal RPF1s are 17x9et45. These will be REAL close to the stock struts with or without lowering springs (RCE) and camber bolts (Whiteline). If you are running coilovers there probably won't be any clearance issues with the 45 offset 17x9 RPF1s.
I AutoX on my setup and can say that 17x9 with 245/40R17 is awesome on this car.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Jay Jr (03-20-2013)
Old 03-20-2013, 01:24 AM   #965
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
You say that 17x9et45 are close, but what about 18x9et45?
Old 03-20-2013, 01:44 AM   #966
JoeBoxer
JoeBoxer's Avatar
Would be the same, the offset and width are issue you would want something like a +35 or +38 on stock suspension or drop springs.
The Following User Says Thank You to JoeBoxer For This Useful Post:
whataboutbob (03-20-2013)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
